| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() Join Date: Oct 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
(Thread Starter) | Not Ranked : 0 score Since MSF blew up I will post this info again. Enjoy! I have had issues with my TPMS going off for no reason especially when it first gets cold. My TPMS goes off sometimes when all of my tire pressures are perfectly fine. When these issues happen it is because the threshold on one or more of the sensors needs to be adjusted. Here is how to adjust it. 1. Before you start your car, make sure your tires are at your cold pressure setting then start her up and take her out for a drive. 2. After the drive (must be at least a mile), park your car and make sure to leave it running for this entire process. 3. Deflate each tire by 10 psi within 30 seconds to start the training sequence. 4. Fill each tire back up to the operating pressure and have all four done within 2 minutes. Note: The TPMS light will come on when your pressure drops 25% below the pressure you set. 5. Take the car out for a spin and enjoy your new thresholds. Note: Before you perform these steps make sure that your TPMS is linked up with your ECU. To do this, follow the steps in your users manual that talk about installing a new TPMS sensor.
__________________ 2007 Cosmic Blue Mazdaspeed 3 GT Last edited by RichB; 11-10-2010 at 07:13 AM. |
| The Following 2 Users Say Thank You to RichB For This Useful Post: | bertrand_CX_7 (05-24-2011), labikesrcool (11-03-2010) |
| The Runner ![]() Join Date: Feb 2010 Location: Santa Ana, CA
Rep Power: 140 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 353
| Not Ranked : 0 score Um when it gets cold the pressure drops so there was a reason yours was it was probably semi-low so when it got cold it would set it off. Either way if this works then good job. I'm getting new tires soon so ill try this.
__________________ '09 Black Mica [MURDERED] MS3- HyperTech Tuned, CPE rear and side motor mounts, COBB TIP, JBarone Short Shifter Plate and Heavy Shift knob, SU Shifter Bushings, CPE Nano SRI, AWR End Links. WANTED- Radar Detector, Down Pipe, DashHawk, Forge BPV. |
(Thread Starter) | Not Ranked : 0 score Nope, not true. I checked all of my tires and they were at 33psi. Now the light comes on at 27psi like it is supposed to.
__________________ 2007 Cosmic Blue Mazdaspeed 3 GT |
| The Following User Says Thank You to RichB For This Useful Post: | FreeFlyFreak (11-03-2010) |
| Banned ![]() Join Date: Feb 2010 Location: Waste Milford North JerZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,140
Groans: 444
Groaned at 154 Times in 97 Posts
| Not Ranked : 0 score my tpms has been going off for the past 3 days.. i havent checked pressure yet tho -- maybe i'll do this today thanks |
(Thread Starter) | Not Ranked : 0 score If you find that one or more tires are low and at a pressure you want the sensor to notify you, then you should be good to go. Can't hurt to go through the process though to make sure it is all set up correctly. Good luck.
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
| Not Ranked : 0 score Thanks. I'm gonna try this, mine goes off all the time for no reason. Usually after driving up and then down a hill. Goes off on the down side.
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. |
(Thread Starter) | Not Ranked : 0 score I made updates to this procedure. I found out about a key step to start the training process for each sensor. Steps 3 and 4 have changed. I also added step 5. Enjoy!
| Not Ranked : 0 score lol wtf theres a time limit? i feel like thats gona be rushing it.
(Thread Starter) | Not Ranked : 0 score Your telling me. You pretty much need a compressor to do this.
| Not Ranked : 0 score lol how the fuck else would u do it? bike pump? ive never used anything other then a compressor and i still feel like i would be rushed. where did u get the times from?
(Thread Starter) | Not Ranked : 0 score When I say compressor, I mean like a 10 gallon one to speed up the process. Don't knock the bike pump. I used one for a while when my cheap portable inflator broke. Worked like a charm too, plus it was a great workout.
| The Following User Says Thank You to RichB For This Useful Post: | M4Nathan (11-25-2010) |
![]() Join Date: Mar 2008 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
Groaned at 14 Times in 4 Posts
| Not Ranked : 0 score Resurrecting an old thread because my TPMS light came on and all the tires have the right pressure in them. Could it possibly be this? I'd try it, but if I understand the instructions, you have to let the air out of four tires within 30 seconds?!?! Huh? I hope he meant to say 30 seconds per tire. Has anyone done this? |
(Thread Starter) | Not Ranked : 0 score You only need to let at least 10psi out of each tire within 30 seconds. Once all four have been deflated, you have 2 minutes to inflate all four back to the PSI you desire. If you have been running fine for a while and you all of a sudden get the light with no PSI issues, you either need to re-sync your sensors or one or more of them have gone bad. This how-to is for those of us that get warnings when the tire pressure drops to 30psi and we want the warning psi to be lowered to a setting that makes sense...
| Setting up for STU | RacerX78 | Auto-X / Road Racing / Time Attack | 63 | 02-20-2012 09:34 AM |
| Ally eases credit threshold for Chrysler leases | Haltech | Automotive News | 0 | 08-04-2010 05:10 PM |
| FIA considers re-instituting 107% qualification threshold to keep out the riffraff | Haltech | Automotive News | 0 | 05-20-2010 07:00 AM |
| Setting up MAF.. | taf0422 | MazdaSpeed 3/6 - ECU Computer Tuning | 23 | 04-18-2010 08:04 AM |
| Amp setting/Line out converter setting? | 2k6speed6 | MazdaSpeed 3/6 - Car Audio & Electronics | 0 | 07-31-2009 12:10 PM |
