| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() Join Date: Dec 2010 Location: Huntsville ont
Rep Power: 0 ![]() ![]() Thanks: 2
(Thread Starter) | Neutral : +1 score |
![]() Join Date: Jun 2010 Location: corpus christ, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,316
Groans: 68
| Not Ranked : 0 score you dont need engine internals if all your going for is 350-400. for tune get a perm tune
__________________ 2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC |
![]() Join Date: Jul 2008 Location: Tucson, AZ
Rep Power: 739 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 517
| Not Ranked : 0 score ask around your hood for an engine builder. since you dont have a location, no one but you knows where the hell youre at. read up on some how to threads for engine building/tuners/tunes. ultimately, your budget is your limit on brands.
__________________ JDMFresh.com 1990 Mazda Miata NASA Time Trials/Time Attack, Global Time Attack A miata may be gay, but its probably faster than your car around a track. That's pretty gay. |
(Thread Starter) | Not Ranked : 0 score Thanks ya sorry i forgot to add my location im in muskoka but i would have no problem bringing my engine to toronto my buddy got his subi built at gord bush racing and he seemed pretty knowlegable. And as for leaving the internals stock i really would like to forge the pistons and rods so if i decide i want to go to 450-500 whp down the road all i would need is a tune |
(Thread Starter) | Not Ranked : 0 score I havnt been able to find anything on injectors Either any suggestions? |
![]() Join Date: Dec 2010 Location: Albuquerque, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,614
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score Your internals are already forged. There are no good options for injectors right now. (unless something changed in the last few weeks) But a few people are working on it. Perm tuning is the best way to go. As far as parts... @JP@edgeautosport.com or @eric@edgeautosport... These are the guys to go through... Best customer service and prices!! Eric knows quite a bit about BT builds too
__________________ 2009 MazdaSpeed 3 Spy Hunter Smoke Screen Mod Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760. |
| The Following User Says Thank You to RayRay For This Useful Post: | Alpha (12-22-2011) |
![]() Join Date: Apr 2010 Location: Columbia, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,756
Groans: 97
| Not Ranked : 0 score There aren't any and people run that power on stock internals. |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score whats the point of 450-500whp? thats nothing but tire fire. you dont need internals
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
Groans: 68
| Not Ranked : 0 score you already have some pretty good mods for what you want, all you really need is an exhaust mani but if you have a turbo with the atp housing it will bolt to your stock mani.
(Thread Starter) | Not Ranked : 0 score I thought that crank was the only thing that was forged?? So the rods and pistons are factory forged?? And yes i was planning on getting a aftermarket cast manifold thanks for the advice guys!!!! |
| Not Ranked : 0 score Yep! Right now there are probably 20+ MS3's and 6's running 450+hp. Almost all with stock internals. I think there are a few well over 500. Power isn't the problem. Traction is!! Being able to use that power anywhere under 50mph is the real quick!
| The Following User Says Thank You to RayRay For This Useful Post: | IshiKage (12-23-2011) |
(Thread Starter) | Not Ranked : 0 score Well thats wicked guys maybe i will run the gt30 on the stock internals for next summer then so where it goes from there! Whats involved in changing the turbo and exhaust mani???? When i put my DP it was tight enough under the car lol |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score fuck stock internals save your block and time and spend the extra cash now. all those stock blocks will blow eventually the stock rods are garbage casted low grade metal imo vs the bulletproof chromolly billet like my pauter rods if you would compare youll see my rods will be the last thing to give way. get the arp studs and cometic head gasket and fresh bearings. |
![]() Join Date: May 2012 Location: AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
Groans: 43
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score Only pistons are forgedd
__________________ 2012 black mica MS3 ; 3.5 HTP/ Catless DP/ AT HPFP/ APV2/ FMIC/ GFB BOv/ 3" CBE/ RMM/ XXR 530(18x9 +33)/ NT05 245/40/18/ 3bar map/ 3 port EBCS/ bnrs3/ DO stg2 dvc30/ REAR swaybar/ EBC Yellow/ CS Inj seals/ PNP IM/ Manley H-Beam/ Manley platinum piston 87.5/ soon...... PI+ BNRs6+ 44mm TIAL+ ACT 6 puck ![]() E35 meth d012 26psi ![]() 420/451 self tuned/built |
Groans: 43
| Report: Bugatti to build 1,000+ Galibier sedans starting next year? | Haltech | Automotive News | 0 | 08-01-2011 08:10 AM |
