> MazdaSpeed 3 - How-To's
  • 1 Post By Haltech
 Old 11-05-2010, 06:53 AM   #1
FUB4R3D's Avatar
Posts: 145   (View Stats)
FUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the worldFUB4R3D is the leader of the world
Default Step by Step Brake Job from Grassroots Motorsports
Someone posted this before we went back in time (I don't recall who, so claim it if its yours), but I found it to be a good read for anyone doing their first bit of brake work on their Mazda.
Step-by-Step Brake Tech for Our Mazdaspeed3: 2008 Mazda Mazdaspeed3 Project Car: Grassroots Motorsports Magazine
FUB4R3D is offline   Reply With Quote
The Following 25 Users Say Thank You to FUB4R3D For This Useful Post:
2007speed3 (11-06-2010), 2008speed3 (11-08-2010), Addikted To Boost (12-09-2010), Arnie1229 (01-13-2015), AZSPEED3 (03-23-2012), breakfstincluded (10-04-2011), chomorro (10-25-2013), dsb_chicago (01-15-2013), I Love Brownies (11-05-2010), J-villa (02-07-2011), JacksonMS30 (11-05-2010), jack_hammer (01-14-2012), JohnMS3 (12-20-2010), kabobulate (11-07-2010), kgb (12-21-2010), labikesrcool (11-09-2010), madjon (11-08-2010), Mortose (04-11-2012), MS3 Ventura (11-06-2010), Night Wolf (12-14-2010), Notorious AMA (02-25-2014), novice_01 (11-08-2010), roguemazda (12-11-2015), SIXual Panda (12-10-2010), zpele (07-11-2011)
 Old 11-05-2010, 06:55 AM   #2
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
Thanks for reposting this. I subscribed to it and then it disapeared along with a lot of other useful stuff I had recently subscribed too.
2008 MGM MS3 GT
- HTA3586-
- P.E.R.M Twisted Top Mount -
- P.E.R.M.Tuning -
 Old 11-05-2010, 07:04 AM   #3
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
ha guess we should make this a sticky again...
'08 CWP MS3 w/ T3 3071r
 Old 11-06-2010, 12:44 PM   #4
Biggs's Avatar
Posts: 212   (View Stats)
Biggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the worldBiggs is the leader of the world
bookmarked the link thanks.
09 TR MS3
Cp-e Nano SRI | Cp-e TIP | Cp-e RMM 75d | Cobb catted 3" DP | Cobb AP - Jorge Carrillo protune
NGK Iridium IX 6510 plus | PTP HPFP upgrade (internals)
TrMotorsprt MT1 18x8.5 +48 | Dunlop Direzza Sport Z1 Star Spec 235/40/18 | Mutegi Black Lug nuts
Hawk HPS Pads | Ate Super Blue | Techna-Fit SS lines
Hella Supertones | JBR Heavy Shift Knob
Biggs is offline   Reply With Quote
 Old 11-06-2010, 12:45 PM   #5
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
why does he have 2 sets of gloves???
and matt dammond had done one also
 Old 11-06-2010, 01:13 PM   #6
2007speed3's Avatar
Posts: 1,486   (View Stats)
2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world
Groans: 70
so as a ratard how much more work is involved in removing the rotors?
the pads themselves seems like a simple task!
2007speed3 is offline   Reply With Quote
 Old 11-06-2010, 01:19 PM   #7
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
On a 3 zero work.
Once you have removed the caliper the rotor comes right off, you may need rubber mallet or similar the first time.
On a 6 there is a screw to remove I believe (can be a bitch if it is rusted)
Suspension:
The Following User Says Thank You to FreeFlyFreak For This Useful Post:
 Old 11-06-2010, 01:26 PM   #8
rossisboss07's Avatar
Posts: 249   (View Stats)
rossisboss07 is the leader of the worldrossisboss07 is the leader of the worldrossisboss07 is the leader of the worldrossisboss07 is the leader of the worldrossisboss07 is the leader of the worldrossisboss07 is the leader of the worldrossisboss07 is the leader of the worldrossisboss07 is the leader of the worldrossisboss07 is the leader of the worldrossisboss07 is the leader of the worldrossisboss07 is the leader of the world
^if there is a screw and it's rusted, apply PB blaster. then get a screwdriver that fits tight and you can beat on... apply turning force and hit the screwdriver at the same time to attempt to jar it loose... or get an impact driver so the hammer hit applies the twist for you, those things are great for rotors secured by screws.
Note. if just changing pads was all you wanted, then you can skip on removing the caliper bracket with the caliper like he did in the back... just need a 7mm allen, pop the little covers off and remove just the caliper. I've always at least machined the rotors when changing pads though.
A BMW owner amongst Mazda owners.
rossisboss07 is offline   Reply With Quote
 Old 11-06-2010, 01:28 PM   #9
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
same procedure for every car
The Following User Says Thank You to forcedinduktion For This Useful Post:
rossisboss07 (11-06-2010)
 Old 11-06-2010, 01:28 PM   #10
2007speed3's Avatar
Groans: 70
Thanks, i think i need to do a brake job soon. 60k miles on the original pads and rotors i assume at least the pads need to be replaced.
how does one tell if the rotors need to be replaced too. There is at least a penny sized lip on the edge of the rotors so i could they still be turned instead of getting new pads or what?
 Old 11-07-2010, 12:21 PM   #11
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
i need to change mine today
2015 Mazda 6
 Old 11-07-2010, 12:43 PM   #12
rotors have a spec for thickness, that when reached, they need to be discarded, if the grooves or warping can be machined out without going below this "minimum machining" spec then you can get them turned on a lathe... if not, you need to replace. Idk the MS3/6 min. machining specs.
other things that would make me want to replace them are, excessive warpage, rotor thickness getting close to min. (thinner rotor warps easier again) or if the pads cut grooves into the rotor, grooves can take a lot to machine out, so sometimes it's easier to just replace them.
as an example, I did 2 pad changes on my MS3 (within 23k miles from new) first from stock to HPS pads up front, turned front rotors, rears were OK still.
second pad change I put Carbotech bobcats on all 4 corners, rears were excessively warped but had good thickness, so I turned them (warped from setting parking brake tooo soon after heavy braking), the HPS was easier on the front rotors than stock and I only had to turn off a few thousandths.
of all the average cars brake jobs that I do, I'd say I replace rotors due to rusting, warping, and grooves from running out of pad more than anything else. I only turn rotors every once in a while, because most people don't seem to pay attention to the squeaker on the pads to tell them when it's time to check pad thickness... so I end up replacing the rotors 'cuz they ground the hell out of them with the pad backing.
 Old 11-07-2010, 12:53 PM   #13
The Kamikaze King!
Groans: 754
For the 3
Minimum front disc plate thickness
23 mm {0.91 in}
Minimum front disc plate thickness after machining
23.8 mm {0.94 in}
Minimum read disc plate thickness
9 mm {0.35 in}
Minimum rear disc plate thickness after machining
9.8 mm {0.39 in}
Suspension:
rossisboss07 (11-07-2010)
 Old 11-07-2010, 12:56 PM   #14
kabobulate's Avatar
Posts: 1,146   (View Stats)
kabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the worldkabobulate is the leader of the world
Panning on this soon, thanks for the post.
2012 CWP MS3: Tuned by Phate - 50/50 E85 | Cobb AP | SURE Intake, TIP | Corksport Racepipe, TMM Inserts | ITV22's | AT Intl's | ACT Sprung 6Puck & Prolite Flywheel | CP-E Stg2 RMM | JBR SSB, EGR Plate
2008 Silver MS3: Sold
kabobulate is offline   Reply With Quote
 Old 11-07-2010, 01:06 PM   #15
Qtip's Avatar
Posts: 410   (View Stats)
Qtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond repute
This is a great guide, but having done this a few times on the Speed3, what seems to be missing is applying brake grease to the back of the pads.
I find that I get squealing from the pads without some sort of brake grease.
Qtip is offline   Reply With Quote
 Old 11-07-2010, 01:32 PM   #16
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
anybody use the EBC yellow or any other color pads, impressions?
 Old 11-08-2010, 08:34 AM   #17
FUB4R3D's Avatar
I'll be doing EBC Reds on Thursday, I'll let you know what I think compared to stock when I am done.
The Following User Says Thank You to FUB4R3D For This Useful Post:
Dano (11-08-2010)
 Old 11-08-2010, 09:50 AM   #18
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Subbing for a good write up. Gonna have to do brakes eventually.
this forum serves 2 purposes
 Old 11-08-2010, 10:25 AM   #19
Trail of Fail
Dano's Avatar
Are the Reds more of a track compound?
 Old 11-08-2010, 11:47 AM   #20
FUB4R3D's Avatar
From what I have read, the Reds are a street compound. First time installing brakes on the speed, and with my old car I never ran anything special, so this should be interesting. I'm all for the lower dust levels compared to stocks.
To get track/street compound, you'll need yellows or blues.
 Old 11-08-2010, 12:17 PM   #21
Tommy's Avatar
Posts: 2,309   (View Stats)
Groans: 155
I've had the EBC Red's for over 1k miles now and I like them. Plenty of bite and there is less dust - not no dust but less.
 Old 11-08-2010, 12:27 PM   #22
Trail of Fail
Dano's Avatar
Street compound should suffice for me as well.
Thanks
 Old 11-08-2010, 12:30 PM   #23
Ur moms boyfriend
Groans: 70
anyone running hawk hps ?
 Old 11-08-2010, 04:36 PM   #24
Meder's Avatar
Posts: 1,065   (View Stats)
Meder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the world
I am on hawk hps. They work well and are a killer price but they tend to have quite a bit of a soft spot at the start of the pedal travel. They are comparable to stock pads without the initial bite.
If you're not worried about losing that initial bite the hawk hps are a killer deal. I'll be going to something new next change.
Meder is offline   Reply With Quote
 Old 11-08-2010, 04:45 PM   #25
novice_01's Avatar
Posts: 92   (View Stats)
novice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud ofnovice_01 has much to be proud of
Very nice post, tyvm.
JBR SRI+TIH
JBR SSP+Shift Knob
CP-E 60D RMM
Autotech HPFP
AP V3 S-OTS 2 map
novice_01 is offline   Reply With Quote
 Old 11-11-2010, 08:21 AM   #26
FUB4R3D's Avatar
Well, after having done my brakes last night, I can easily say that those rears have the most asinine bolts that I have ever had to remove... Bottom one was OK, just took a little while to come out after I broke it loose, but the top one hiding behind the e-brake cable and brake line
+1 from the review for there being sharp bits and flying anti-rattle springs.
One tool I might add to a list would be a 1.5 ft/2 ft breaker bar to get the bolts loose if its the first time since the factory (This tool is completely useless on the rears). A flexible extension might also make life easier, but I have never used one and can't say how good it would be.
So far I'm happy enough with the EBC reds, but I am still just breaking them in so I cant give a really accurate description of them yet.
 Old 12-08-2010, 05:47 PM   #27
Bujwazay's Avatar
Posts: 486   (View Stats)
Bujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the worldBujwazay is the leader of the world
Thanks for the post...gonna be doing this at some point in the next few weeks!
Bujwazay is offline   Reply With Quote
 Old 12-09-2010, 07:37 AM   #28
Tommy's Avatar
Groans: 155
I used a 3" extension piece with a regular 12" flex head ratchet and had no problems at all getting those bolts out.
 Old 12-10-2010, 03:27 AM   #29
Z-Indy's Avatar
Posts: 1,815   (View Stats)
Z-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the worldZ-Indy is the leader of the world
Groans: 35
Subbing for when I need to do mine.
Thanks for posting.
2008.5 Black Mica MS3
Cobb AP and 30% E85 Dizzy Tune - Cobb SRI - CP-e RMM - JBR SSP & Solid Shifter Bushings - E4 heavy shift knob - Denso ITV22 plugs - 6000K HID lows - 3500k HID fogs - Ford XT-M5-QS Tranny fluid - RX8's (PC'd Anthracite) - Rubber hatch tray
It's not my fault I'm this way, I was homeschooled.
Z-Indy is offline   Reply With Quote
 Old 12-20-2010, 01:04 AM   #30
JohnMS3's Avatar
Posts: 754   (View Stats)
JohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the world
Thanks for the link. will be using it in a few days
-John
| Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns |
JohnMS3 is offline   Reply With Quote
 Old 04-27-2011, 10:00 AM   #31
jpasterjak's Avatar
Posts: 1   (View Stats)
jpasterjak has a spectacular aura aboutjpasterjak has a spectacular aura about
Hi everyone...
Just stumbled across this thread. Thanks for the link!
To answer a couple of questions in some of the replies...
I've been running the yellows as my only pads since I installed them. Good street pad, good track pad. They don't take much heat to work just fine, and they don't make any noise on the street. Only downside is they're dusty, but that' s the price for most good pads. Grey wheels hide that nicely.
And as for changing gloves mid-shoot, that's mostly because the numerous razor-like edges on this car make latex gloves worthless. I simply can not overstate the amount of sharp edges and point on the undersides of these cars. My wife and I have five parrots, and between their boxcutter beaks and the MS3, my hands constantly look like I'm involved in some adult knife-fighting league at the post-apocalyptic community center.
Again, thanks for the plug. I need to go browse the rest of the forum now. Cool stuff here...
jg pasterjak
Grassroots Motorsports magazine
grassrootsmotorsports.com
jpasterjak is offline   Reply With Quote
The Following 3 Users Say Thank You to jpasterjak For This Useful Post:
aromig (06-01-2015), breakfstincluded (10-05-2011), Tommy (04-27-2011)
 Old 05-06-2011, 04:36 PM   #32
Soriku1489's Avatar
Posts: 24   (View Stats)
Soriku1489 will become famous soon enoughSoriku1489 will become famous soon enough
221702_220642701285702_100000199217775_997795_207227_s.jpgMy new rotors and brakes. Just put them on today.
Soriku1489 is offline   Reply With Quote
 Old 08-02-2012, 03:48 PM   #33
dar_vedar's Avatar
dar_vedar is an unknown quantity at this point
Step by step brakes
guys this link does't seem to work...
dar_vedar is offline   Reply With Quote
 Old 08-04-2012, 10:02 PM   #34
Intruder's Avatar
Posts: 144   (View Stats)
Intruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud ofIntruder has much to be proud of
Here: Step-by-Step Brake Tech for Our Mazdaspeed3: 2008 Mazda Mazdaspeed3 Project Car: Grassroots Motorsports Magazine
2010 Mazdaspeed3
Intruder is offline   Reply With Quote
 Old 08-04-2012, 10:28 PM   #35
I updated the link. Thanks
dar_vedar likes this.
dar_vedar (03-06-2013)
 Old 11-07-2013, 10:32 AM   #36
chomorro's Avatar
Posts: 667   (View Stats)
chomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the worldchomorro is the leader of the world
I just did this last night. Replaced front and back rotors and pads.
Forget about using the needle nose pliers for the rear caliper, its a huge pain in the ass!! Took almost 30-45 min to get one piston pushed in and it keeps popping out of the holes........ Hands hurt so i went to local auto store and rented the disc brake caliper tool, they put $55 bucks on hold on your card but the rental is FREE for two day, you get your money back when you return it. The other caliper took less then two min to push in using this tool. Also makes the front pistons cake!
On the peske rear caliper bolts I just used a 14mm wrench and a 15mm wrench on the end as an extension and they broke loose easily. I know its not "safe" but i do it all the time with gloves and make sure nothing is in the way of any body parts when the wrench makes a full turn. I used to have a metal tube that fit over the wrench shaft to use but i couldnt find it....
2009 Subaru WRX STI Hatchback
2007 GTI - Package 2 w/ Nav - Dieselgeek Short Shifter / TWM Weighted Etched Shift Knob / AWE 2.5" Turbo Back Exhaust w/Metal Cat / APR Stage 2+ Tune / APR Flapper Delete / APR HPFP / Vogtland 2" Springs / R8 Coils / NGK Iridium / P3Cars Digital Vent Gauge / 18" OEM Detroit Rims (SOLD)
2007 Speed 3 - Stratified Tuned with bolts ons (SOLD)
chomorro is offline   Reply With Quote
 Old 06-14-2014, 03:08 PM   #37
Shawn_Diggidy's Avatar
Posts: 45   (View Stats)
Shawn_Diggidy is a splendid one to beholdShawn_Diggidy is a splendid one to beholdShawn_Diggidy is a splendid one to beholdShawn_Diggidy is a splendid one to beholdShawn_Diggidy is a splendid one to beholdShawn_Diggidy is a splendid one to beholdShawn_Diggidy is a splendid one to behold
Used this how to for my front brakes and rotors the other day. Easy peasy, hardest thing was breaking the bolts loose that were holding the calipers on.
Shawn_Diggidy is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/step-step-brake-job-grassroots-motorsports-63702/
I don't remember Pokemon looking like this (14 Photos) : theCHIVE This thread Refback 01-21-2011 03:06 AM
my cx-7 tuning step buy step ro-bi CX-7 > Turbo Induction & ECU Tuning 84 04-25-2017 12:21 PM
Cut It Out: Toyota's recalled pedal modification remedy detailed step-by-step Haltech Automotive News 0 12-18-2009 12:10 PM
Grassroots Motorsports $2008 Challenge is in the books Haltech Automotive News 0 10-10-2008 07:50 AM
Grassroots Motorsports $2008 Challenge headed to Florida Haltech Automotive News 0 09-23-2008 02:20 PM
Page generated in 0.57190 seconds with 47 queries
