> MazdaSpeed 3 - How-To's
 Old 06-20-2018, 05:35 PM   #1
Jasonstacy74's Avatar
Posts: 5   (View Stats)
Jasonstacy74 is an unknown quantity at this point
Default Strut mount problems !!!
Mazdaspeed 3 Gen 2
I recently bought the corksport strut and spring combo set. Got them installed by my local shop with new monroe strut mounts and bearings. Two days after getting them installed I noticed a metal to metal contact noise coming from the top of the struts. So i took my car back and they replaced the strut mount and bearings on both sides. NOISE GONE!!! Well a week later the noise is back. Im not made of money so 3 months pass with the noise getting louder. So I bought the factory strut mounts and bearings and put them on my self. The same damn thing happens, noise is back and still to this day. All corksport had to say is send pictures and ive been trying to get my car on the lift. Just wanted to see if y'all could help me out on this one or give me advice. Yes my car has been aligned every time after.
Jasonstacy74 is offline   Reply With Quote
 Old 06-20-2018, 07:36 PM   #2
Solarsurge's Avatar
Posts: 577   (View Stats)
There are quite a few threads with people complaining about extremely quick failures of aftermarket mounts. While some of these maybe installer error, the general consensus is if you want to be sure you're getting a quality part that won't fail prematurely, just go with OEM mounts/bearings. Regardless of which mounts you use:
1. If the top nut on the piston is not properly torqued it does not properly pre-load the spring. As the spring settles in it can get pretty loose, causing it to move around. It should be torqued to around 40-45 lb-ft.
2. Strut Mounting bolts should be torqued to 30 lb-ft.
 Old 06-21-2018, 05:34 AM   #3
Bingo's Avatar
Posts: 740   (View Stats)
Groaned at 9 Times in 7 Posts
at least on my Koni FSD's, the top but on the strut has a slot for an Allen key on the top to prevent the strut from rotating while you torque. This means I cannot get a torque wrench on it and I actually have no idea how to properly torque it, I've screwed this up twice now and ruined 2 mounts
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A.
 Old 06-21-2018, 11:35 AM   #4
Solarsurge's Avatar
Aside from the many strut nut tool kits you can get (most likely available for rental for free from a local auto parts store), there are also hundreds of pass through ratchets and wrenches. Keep center rod from rotating with Allen bit, torque nut down with pass through wrench.
Since spring clamps are recommended to get the mount off the OEM strut without launching the mount into your face or across your garage, the spring is obviously meant to be pre loaded. Tighten that sucker down.
 Old 06-21-2018, 11:56 AM   #5
Bingo's Avatar
Ya, I understand the process (now), but I've not heard of a pass-through torque wrench. I now have welded a socket to a metal rod as my make shift pass-through wrench (I wanted to learn to weld), but I have no way to measure the torque. I just crank down on it now.
 Old 06-21-2018, 12:17 PM   #6
Solarsurge's Avatar
If you want to be 100% sure:
J-42468 Front Strut Mount Nut Wrench Set
Otherwise, most of us just use wrenching experience and the mystical powers of the wrench gods to know what 40-45 lb-ft feels like because we don't want to spend $80 on a tool for a job we may only do once.
There's also this, which comes with a 17mm socket, and it's cheaper:
https://www.ebay.com/i/132275671163?chn=ps
Last edited by Solarsurge; 06-21-2018 at 12:17 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Solarsurge For This Useful Post:
Bingo (06-21-2018)
 Old 06-21-2018, 01:28 PM   #7
Bingo's Avatar
Ya...that's exactly what I've never heard of. Thanks.
 Old 06-21-2018, 10:14 AM   #8
Db09ms3's Avatar
Posts: 536   (View Stats)
I used O'Reilly/Checker top hat mount and bearing with Sach's shocks and struts because I'm cheap like that. No problems. I am suspecting install error. Google the thread on the front strut install for a reference. I got 25k miles on my mount and bearings so far.
Stockish
 Old 06-21-2018, 10:19 AM   #9
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Did you accidentally leave any parts out? Sounds like the insulator is missing or its not properly tightened. I have an MS6 however I installed strut mounts from Rock Auto and no issues.
 Old 06-24-2018, 07:24 PM   #10
sorry for getting back so late been working a lot. But im sure im not leaving parts out. Here are some pictures of the passenger side and driver side. To me it looks bent at an angle.
Strut mount speedo MazdaSpeed 3/6 - Suspension & Brakes 28 06-11-2013 04:54 PM
Where can I buy ms3 strut mount? clash0901 MazdaSpeed 3/6 - Suspension & Brakes 12 01-06-2012 04:00 PM
Page generated in 0.30947 seconds with 25 queries
