Closed Thread
 Old 03-30-2011, 08:06 PM   #1
nick779's Avatar
Posts: 215   (View Stats)
nick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud of
If you've recently reconnected the battery the STFT's will be all over the place for the first 50 or so miles while it's learning. At certain intervals those values will be saved into LTFT's. Not sure what those intervals are.
its been 3 key cycles and about 68 miles
Originally Posted by rtabagaboy View Post
Your values are normal for an SRI. I think mine where about 10-13 from idle thru part throttle (Read MAP/MAF voltage) that is what the LTFTs are for. They are there to calibrate the incoming air to correctly adjust AFRs.
However during WoT I "believe"(someone correct me) that the calibration (LTFTs STFTs) are ignored and just a (MAF/Fueling)table is used. So if your LTFTs(read calibrations) are not 0 then the WoT will be running lean/rich from the nominal design... If you LTFTs are positive your MAF +10 you sensor is low and need to be increased to account for the correct amount of air... so during WoT you might be running a little lean...
At least this is what I think happens... I have been wrong before... correct me ?
from what ive read, your right, i just wanna know HOW lean lol, if im below a 11.3 A/Fr, i dont care, i just dont wanna be running too lean at WOT
'11 Speed 3 Black Mica (Sold unfortunately, going back to school)
'12 3 Skyactiv- its slow as hell but getting 38mpg makes it somewhat worth it
Licensed PA State Inspection and Emissions Tech
nick779 is offline
Closed Thread
A/F ratios and ltft's dread
Cobb ATR Support
7 05-01-2009 05:37 PM
Streaming mad: $206 in urine-soaked coins is not acceptable payment for a speeding ticket in Washington Haltech Automotive News 0 03-26-2009 12:20 PM
Acceptable knock? pwrful4
Cobb Access Port/Maps
13 01-20-2009 07:23 PM
STFT's and LTFT's 802MS3 MazdaSpeed 3/6 - ECU Computer Tuning 3 01-20-2009 06:34 PM
Knock count: what is acceptable? ericm979 MazdaSpeed 3/6 - ECU Computer Tuning 10 10-31-2008 07:58 PM
Page generated in 0.23151 seconds with 21 queries
