Closed Thread
 Old 03-28-2011, 07:17 PM   #1
nick779's Avatar
Posts: 215   (View Stats)
nick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud ofnick779 has much to be proud of
Default acceptable LTFT's with CP-E Nano
i installed my nano today, and drove around for roughly 25 miles, and im seeing LTFT's from +3 to +12.5
and thats my only mod
is that normal? should it go down maybe after more driving?
'11 Speed 3 Black Mica (Sold unfortunately, going back to school)
'12 3 Skyactiv- its slow as hell but getting 38mpg makes it somewhat worth it
Licensed PA State Inspection and Emissions Tech
nick779 is offline
 Old 03-28-2011, 07:31 PM   #2
0187
esr010's Avatar
Posts: 486   (View Stats)
esr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the worldesr010 is the leader of the world
Groaned at 9 Times in 5 Posts
Did you disconnect the battery so the ecu can relearn the trims fresh? It's not required but it will get them learned quicker I believe. What were your trims before?
Those aren't too bad though. They will continue to adjust.
esr010 is offline
 Old 03-28-2011, 07:35 PM   #3
nick779's Avatar
yea the neg was disconnected the whole 30-45 mins it took me to install,
and my ultragauge showed all LTFT's zeroed out when i restarted the car, and i checked every connection before i closed the hood including the turbo inlet
hopefully me getting into boost a few times around 10 miles(after install) didnt hurt anything
nick779 is offline
 Old 03-29-2011, 08:38 AM   #4
the_caruch's Avatar
Posts: 698   (View Stats)
the_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the world
that seems about right for those values.
cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC
the_caruch is offline
 Old 03-29-2011, 03:58 PM   #5
nick779's Avatar
really? because i read +/- 8 is where it should be at
this morning they hit +13.5 at idle (22 degrees) after a 12 mile drive, and this afternoon they hit +14 (45 degrees) but after sitting at idle for a minute or 2 it hit +13 with a STFT of 2
all my LTFT's go down as throttle increases to about +5
still sound right?
and at what point does a CEL get thrown? +/- 25?
nick779 is offline
 Old 03-29-2011, 04:13 PM   #6
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
+ / - 8 at WOT, not sure about normal driving.
860whp/677wtq
2.7 V6 Ecoboost
PapaSmurf is offline
 Old 03-29-2011, 04:34 PM   #7
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
still sound right?
I think around +/- 16 points you get a too rich or lean at idle code. Sb is wacky with trims sometimes. Give it a good 100miles and see where you're at.
NJSPEED3 is offline
 Old 03-29-2011, 04:59 PM   #8
wankular's Avatar
Posts: 4,343   (View Stats)
I don't think he has a standback unless I missed that part. With my Cobb intake I was seeing 13-14% and never below 10 no matter how many times I unplugged my battery. You probably need to start tuning your MAF. I got mine down to 3%.
I thought the +/- 8% was for normal driving and at WOT it should be zero?
2009 MS3 sport MGM
wankular is offline
 Old 03-29-2011, 05:05 PM   #9
Spoolme's Avatar
Posts: 1,041   (View Stats)
Spoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the world
Groans: 54
+/- 10 cruising and yes it should zero out short and long term at wot. Give it some miles though and key cycles.
Parting out!
http://www.mazdaspeedforum.org/forum/forum/f229/spoolme-parting-out-76016/
Spoolme is offline
 Old 03-29-2011, 05:50 PM   #10
nick779's Avatar
how do you tune your maf without using something like AP and im not paying $600 for an AP
nick779 is offline
 Old 03-29-2011, 05:55 PM   #11
Not to be a smart alec, but you won't be able to tune your maf without atr. You could send your map to someone with atr, have them alter the trims for you and then e-mail it back and reflash.
Those trim numbers are definitely a bit high , but before doing any maf calibrations, try to drive @ least 10 city miles (optimal = 50 miles).
rfinkle2 is offline
 Old 03-29-2011, 06:05 PM   #12
the_caruch's Avatar
still sound right?
well +13 at idle isn't the greatest. but it's not terrible.
without a tuning solution you can't do anything about it though.
The Following User Says Thank You to the_caruch For This Useful Post:
rfinkle2 (03-30-2011)
 Old 03-29-2011, 07:48 PM   #13
nick779's Avatar
im not really worried about idle if its correcting itself, im just concerned with WOT when trims are ignored.
actually, now that i think about it, whats so bad about having trims not around 0, i mean the ecu is compensating for the additional air right? just not at WOT
nick779 is offline
 Old 03-29-2011, 09:17 PM   #14
Spoolme's Avatar
Groans: 54
but it does not carry throught the entire rpm range. So you run the risk of leaning out. At idle is not a problem, not saying that you want +/- 13. Wot is a problem.
Parting out!
Spoolme is offline
 Old 03-30-2011, 05:00 PM   #15
nick779's Avatar
well weird thing is, at idle the trims today were at 12.5 with a consistent stft of -3.6
and cruising was at about 8 with stfts jumping around, and it maintained the 8 even at higher rpms at a higher load with boost...
although i remember even stock, my ltfts were from 4.8 to 10,
maybe it just needs a few more days to settle
ill try to scan it and do a few pulls to see what my afr is, provided i can view a pid for it
nick779 is offline
 Old 03-30-2011, 05:25 PM   #16
wankular's Avatar
If you've recently reconnected the battery the STFT's will be all over the place for the first 50 or so miles while it's learning. At certain intervals those values will be saved into LTFT's. Not sure what those intervals are.
2009 MS3 sport MGM
wankular is offline
 Old 03-30-2011, 05:38 PM   #17
rtabagaboy's Avatar
Posts: 363   (View Stats)
rtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the world
Groaned at 7 Times in 3 Posts
Your values are normal for an SRI. I think mine where about 10-13 from idle thru part throttle (Read MAP/MAF voltage) that is what the LTFTs are for. They are there to calibrate the incoming air to correctly adjust AFRs.
However during WoT I "believe"(someone correct me) that the calibration (LTFTs STFTs) are ignored and just a (MAF/Fueling)table is used. So if your LTFTs(read calibrations) are not 0 then the WoT will be running lean/rich from the nominal design... If you LTFTs are positive your MAF +10 you sensor is low and need to be increased to account for the correct amount of air... so during WoT you might be running a little lean...
At least this is what I think happens... I have been wrong before... correct me ?
2008.5 BlackMica Mods:
- Cobb SRI, Turbosmart BPV, CPE RMM 60d, TRZ TMM, TopSpeed PMM, HTP Turbo Inlet... I'm workin' on it.
AZ Status!
rtabagaboy is offline
 Old 03-30-2011, 08:06 PM   #18
nick779's Avatar
its been 3 key cycles and about 68 miles
from what ive read, your right, i just wanna know HOW lean lol, if im below a 11.3 A/Fr, i dont care, i just dont wanna be running too lean at WOT
nick779 is offline
Closed Thread
A/F ratios and ltft's dread
Cobb ATR Support
7 05-01-2009 05:37 PM
Streaming mad: $206 in urine-soaked coins is not acceptable payment for a speeding ticket in Washington Haltech Automotive News 0 03-26-2009 12:20 PM
Acceptable knock? pwrful4
Cobb Access Port/Maps
13 01-20-2009 07:23 PM
STFT's and LTFT's 802MS3 MazdaSpeed 3/6 - ECU Computer Tuning 3 01-20-2009 06:34 PM
Knock count: what is acceptable? ericm979 MazdaSpeed 3/6 - ECU Computer Tuning 10 10-31-2008 07:58 PM
Page generated in 0.38202 seconds with 28 queries
