 Old 01-06-2016, 09:41 PM   #1
chapy18's Avatar
Posts: 159   (View Stats)
chapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the worldchapy18 is the leader of the world
Default Anyone running the Stage 3 Pistons?
I got a set of new cp-e stage 3 pistons at a steal and a spare long block to sleeve and put them in. Just looking for someone running these to get some feedback.
Sent from my SM-G925V using Tapatalk
2006 Black MS6 GT
For POWER!!!! - Cobb AP V3///HTP 3.5" Intake///Sure Test Pipe//Magnaflow CBE///Freek Tune///CS HPFP
For Looks - CS Shift Noob, Aftermarket Steering Wheel, CS LED Interior Light kit, 15% window tint all around, 70% window tint on windshield
For Handling - CS Front Upper Control Arms, CS rear Camber Arms, CS Sprtings, Whiteline Rear Sway Bar, AWR End links, JBR Trilogy Mounts, CPE rear diff mount, Turbine Tech Front Diff mount, Konig Backbone 18X8.
Big Build in the Works
chapy18 is offline   Reply With Quote
Anyone running CP-e Stage 3 Pistons? chapy18 MazdaSpeed 6 - Engine, Transmission & Driveline 0 01-04-2016 12:37 PM
Stage 2 Pistons NCspecV81 Custom Performance Engineering (cp-e.com) 12 05-23-2014 08:24 AM
Page generated in 0.21875 seconds with 20 queries
