  • 1 Post By Poohster
  • 1 Post By www.cp-e.com
 Old 02-23-2016, 08:21 PM   #1
Poohster's Avatar
Posts: 353   (View Stats)
Default Big Thanks to CP-e to Installation Work
I wanted to thank CP-e for great job they did on my MS6. They installed:
ATP GTX2867r
CP-e Ceramic coated LTRmani
Damond Motorsports TB spacer
CP-e custom Oil return line
Kozmic Oil feed line
Corksport 3.5 Bar MAP
Snow Performance Stage2 with safeinjection, flow gauge
Water Meth Alcohol Injection 3 gal tank
Hawk pads, SP Peformance slotted rotors, braided lines
CP-e xflex diff mount
Grimmspeed 3 port boost controller
Dyno tune (nice conservative tune)
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
 Old 02-23-2016, 08:23 PM   #2
Police - Grammarhead
Vansquish's Avatar
That looks like an awfully low power output for that turbo, even on the MS6.
The Following 5 Users Say Thank You to Vansquish For This Useful Post:
CWP_MS3 (02-24-2016), g00s3y (02-25-2016), MD1032 (02-29-2016), Polish_Eagle (02-24-2016), SofaKingAwesome (02-24-2016)
 Old 02-23-2016, 08:50 PM   #3
Yeah, that's very low, probs would be cheaper and better with a etune.
sent from my Nexus 6P
Easter Bunny (02-24-2016), Vansquish (02-24-2016)
 Old 02-23-2016, 09:00 PM   #4
Poohster's Avatar
It's on mustang dyno. Traditionally reads lower than jet dyno. Not looking for mad hp but safe reliable tune.
 Old 02-23-2016, 10:06 PM   #5
broda's Avatar
Posts: 375   (View Stats)
If you're happy that's great. Those numbers could have been hit for much, much less. That's what they're trying to get at.
The Following User Says Thank You to broda For This Useful Post:
Poohster (02-24-2016)
 Old 02-24-2016, 06:24 AM   #6
Vansquish's Avatar
That makes a lot more sense. When I use the Mustang correction factor in Vdyno, I see about 300awhp/330awtq, so you and I are in the same place now. So...looking good! There's definitely more in that turbo if you want to go looking for it, though :-)
The Following User Says NO Thank You to Vansquish For This Un-useful Post:
Novej (02-27-2016)
 Old 02-24-2016, 06:35 AM   #7
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Who actually tuned the car?
And I can tell you from watching quite a few cars get onto CP-e's dyno; its a cruel sumbitch. His car most likely over 300whp.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 2 Users Say Thank You to CWP_MS3 For This Useful Post:
Easter Bunny (02-24-2016), Poohster (02-24-2016)
 Old 02-24-2016, 07:13 AM   #8
Poohster's Avatar
Sander, CP-e. He also did some diagnostics on some ignition issues.
 Old 02-24-2016, 08:56 AM   #9
dale_gribble's Avatar
Posts: 4,720   (View Stats)
With meth injection and that setup, you have an easy 40-50whp on the table there when you are ready to start exploring. You guys have decent pump gas out there too. It looks in your sig that you have a built motor also, so even 350whp is still very conservative.
Man, I really want to know what you paid them to do all that, but you probably don't want to share and I understand that.
MINI H1 6.0 - CAR LED TAILS
 Old 02-24-2016, 10:26 AM   #10
Poohster's Avatar
Probably more than I should have but well worth my time and effort. I am older and have seen better wrenching days years ago. Need to spend time with family and not messing up the driveway and garage. Wife would kill me. Simple (relative) bolt-ons and oil changes are about the only time I have time for.
Thanks for the info on power potential. Since racing is not really my scene, that's enough power to make me smile every now and then.
 Old 02-24-2016, 10:49 AM   #11
CPe's dyno is definitely a heartbreaker, can you post a log so that it can be run through vdyno for comparison?
 Old 02-24-2016, 11:22 AM   #12
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Yeah their dyno will take your hopes and dreams and just shatter those bitches.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 02-24-2016, 12:53 PM   #13
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
+1 to CP-e's dyno being harsh. I believe its generally accepted that it even reads a bit lower than other Mustang dynos with the way they calibrated it.
'08 CWP MS3 w/ T3 3071r
 Old 02-24-2016, 02:09 PM   #14
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Mustang dyno is definitely a heart breaker.
We were happy you came to us for install/tuning. Thank you!
Website: www.cp-e.com
The Following 6 Users Say Thank You to www.cp-e.com For This Useful Post:
impossible (02-25-2016), InkedInspector (02-24-2016), Mazdazilla6 (02-25-2016), Poohster (02-24-2016), silvapain (02-29-2016), Vansquish (02-24-2016)
 Old 02-24-2016, 05:12 PM   #15
Poohster's Avatar
Dynos are just a way to gauge effectiveness of tuning. That is what I took away and a verified log of it. The numbers are consistent with others and I am content with that.
I will see if I could get vdyno done. (have figure out how )
Just happy to get the work done and proud to have gone to CP-e. thanks
www.cp-e.com likes this.
The Following User Says Thank You to Poohster For This Useful Post:
www.cp-e.com (02-29-2016)
 Old 02-24-2016, 06:30 PM   #16
sheston's Avatar
Posts: 1,847   (View Stats)
I think you would be very happy with the big jump you got from an e-tuner, or by playing with it yourself.
I make more on my K04, by quite a bit, and the 2867 should make a lot more
 Old 02-25-2016, 10:03 AM   #17
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Did you read ANY of the replies in this thread?
The Following 2 Users Say Thank You to impossible For This Useful Post:
Easter Bunny (02-29-2016), Poohster (02-25-2016)
 Old 02-25-2016, 12:18 PM   #18
Does your dyno have a power absorption unit or is it an inertia unit?
 Old 02-25-2016, 12:21 PM   #19
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Congrats bro glad to see you still upgrading your ride. Long time no see!!!
track weight 3220
street weight 3370
The Following User Says Thank You to qtrmile beast For This Useful Post:
 Old 02-29-2016, 09:09 AM   #20
dyno jet is an inertia dyno and will give you high numbers
Mustang dynos, like the one we have are load based so they will typically read lower. There are calibrations we can use to give the dynojet numbers, but those calibrations aren't always 100% accurate. We like to give our customers the actual readings rather than padding it to give higher numbers. This is always explained to the customers when they question the numbers. The main purpose when we get customers in for tuning and/or installs is the difference in power, before/after. That is the number that's most important.
Mazdazilla6 likes this.
The Following 5 Users Say Thank You to www.cp-e.com For This Useful Post:
Code Monkey (02-29-2016), Mazdazilla6 (02-29-2016), Poohster (02-29-2016), silvapain (02-29-2016), WAMBUSHHHH! (03-01-2016)
 Old 02-29-2016, 06:03 PM   #21
I'm fairly well versed with dynos. Spent all last semester on the Superflow unit at school. I like to see what shops are using. After using the Superflow and seeing all that it can do I'm not a huge fan of inertia dynos. That's not to say they're not a great option for a small company who can't afford a nice dyno with all the bells and whistles.
 Old 02-29-2016, 07:03 PM   #22
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
I had my car dyno'd at CP-E and honestly I think the biggest problem they have there whether they are willing to admit it or not is their fan setup. They have this outrageously loud fan setup that they claim simulates 85 MPH winds or something ridiculous, however I have never seen BATs as high as I saw in these logs in any WOT log I have ever taken...even 3rd gear ones where I was really heatsoaked from sitting on the side of the road flashing maps. I think the problem stems from the fact that the fans are only at operating speed when the dyno is physically rolling (possibly because they consume huge amounts of electricity, or the fact that they are absurdly loud).
Here are my dyno results and the three logs are attached. The car at the time had a K04, ebay downpipe, CP-E TMIC, 3.5" intake, and a half-baked 2 gallon in-tank methanol tune.
On the same tune I vdyno'd 290 at CF=1.01 so the dyno seems accurate to me. My thinking here is that the problem with the fan setup would be magnified on an MS6 which not only lacks a hood scoop but has terrible under-hood ducting. I think if OP took a good 4th gear log with their CP-E tune on the highway, they might see higher numbers.
2007 Mazdaspeed3 GT
The Following 4 Users Say Thank You to MD1032 For This Useful Post:
Boost_creep (03-01-2016), Easter Bunny (03-01-2016), Poohster (03-01-2016), robbspeed (02-29-2016)
 Old 03-01-2016, 08:24 AM   #23
Our fans are set to be at the same wind speeds as if you were driving down the road at that particular MPH this giving the most accurate reading as if you were on the highway, but we should look into a secondary fan to run while the car is idle on the dyno. Thanks for pointing that out.
The Following 3 Users Say Thank You to www.cp-e.com For This Useful Post:
derek13p (03-01-2016), robbspeed (03-01-2016), WetzMS3 (03-01-2016)
VVT Installation pure2k7 CX-7 > Issues & Troubleshooting 4 06-27-2011 09:52 PM
RMM Installation lerly1 MazdaSpeed 3 - Engine, Transmission & Driveline 1 11-24-2010 07:52 PM
HID installation....HELP! ILoveSpeed Exterior 12 03-02-2010 06:21 PM
MBC Installation How To Ghetto Mods MazdaSpeed 3/6 - Turbo Induction 6 04-25-2008 07:49 PM
Page generated in 0.42714 seconds with 35 queries
