| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() Join Date: Jul 2008 Location: Houston
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
(Thread Starter) | Not Ranked : 0 score Quick question. Going big turbo, I know that CPE makes an inlet pipe and a 3.25" MAF housing. But, the inlet pipe, while offerring a 4" turbo end, seems to only be 3" on the other end. At least that is what it seems from the product description on the CP-E site. I'm just wondering why it isn't 3.25" to match the XcelXL MAF housing? I know that there are some guidelines as to how much power you can make based on the diameter of the MAF housing. Though, I don't happen to remember what those are. So, what are the stats of 3" vs. 3.25"? I happen to have a currently unused ATP 3" MAF. I was thinking I might just use that and CPE's 4" to 3" inlet pipe if the XcelXL won't really do me much difference. I am now built with new rods/pistons, I just haven't yet decided what turbo to go with. P.S. What is the AFE filter part number that the XcelXL comes with? I might try to find a 3" version of it to use with my ATP MAF. |
Groans: 60
| Not Ranked : 0 score The 3.25" MAF and flash is necessary tlo stop you from pegging the OEM MAF at higher boost levels...
(Thread Starter) | Not Ranked : 0 score Yeah, I got that. The questions I had were, what's the power difference between 3" and 3.25"? I've got the ATP 3", and wondered what the difference in power limits between the two. Secondly, if 3.25" is necessary, shouldn't their inlet pipe for big turbos be 3.25" also? It doesn't seem to make sense to me to have a 3.25" MAF, to squeze it down to 3" and then balloon back to 4". |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
| Not Ranked : 0 score Just do it right the first time and get the stuff you need. 3.25 maf and flash.
__________________ 2012 WRX HB w/mudflaps yo! |
| The Following User Says Thank You to spnkr21 For This Useful Post: | 11cruzito11 (05-10-2010) |
(Thread Starter) | Not Ranked : 0 score Oh, and, by the way, the stock MAF housing is something like 2.62 or 2.65, I believe. The ATP according to my calipers is about 2.9" ID. So, the ATP is in the .25 to .3" bigger than stock. The CPE is, presumably something less than 3.25" ID, in order to use 3.25" hose, so, I presume about 3.15" ID or so. AUTOMERGED FOLLOW-UP POST:
My basic question here is, it doesn't seem to make sense to me that they made their BT inlet pipe 3" if their MAF housing is 3.25". So, if I use the CPE MAF, with their inlet pipe, then I'd need a 3.25" to 3" reducer which doesn't make sense to me. Last edited by Speedie6; 05-10-2010 at 01:39 PM. Reason: MSF Database - Automerged Doublepost | |
Groans: 60
The TIP is only 3" because it was made before the MAFXL, there is hardly enough room for the 3", going to 3.5" would necessitate moving the battery/ECM on the MS3, and not many are going to do that just for a big TIP...
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
| The Following User Says Thank You to SSinstaller For This Useful Post: | xcoldricex (05-11-2010) |
But, I guess not. So, I guess that's that. | ||
Groans: 60
There is no air straightener in the CP-E MAF, but it was designed to be used with their flash and filter--most report fuel trims that are dead on or very close running the CP-E setup..
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
| Not Ranked : 0 score just get the 3.25 maf and call it a day. hahaha, people just skim and don't read the question - i don't know the power limits of 3" vs. 3.25" - but if you're getting it cobb tuned you can't get the flash... but i'm pretty sure you can just calibrate your maf tables? i'd just keep the atp if it's already 3in. because yeah, you'll have the 3" restriction anyway if you go with the cp-e combo. alternatively you could make a new 3.25" inlet and slap on a 4" to 3.25" coupler, coupled with the XL intake- you were the one that made inlets before right? |
![]() Join Date: Apr 2008 Location: Utah
Rep Power: 573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
| Not Ranked : 0 score If your going cobb just stick with the 3" ATP. |
And, yeah, I could make a 3.25" if I wanted to. But it would be aluminum and I'm thinking I might as well just get CPE's silicone one. I'm just kinda baffled at why CPE made the inlet 3" and their MAF 3.25". I've already got an AP, and Cobb Tuning built my engine. So, yeah, I sticking with Cobb I think for the tuning. I know that CPE has had some breakthru that they are getting more power out of our cars than anybody else, but, I'm just not in the mood to switch teams. I do have a lot of CPE stuff, like towplate, DP, gaugepod, etc. And will get their inlet. But, I don't feel like switching to them for tuning at this point. | |
| Not Ranked : 0 score i for one prefer aluminum TIPs... just because of the sound |
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
| Not Ranked : 0 score Good luck making power with that tune ![]() Off to my wedding |
Groans: 60
| Not Ranked : 0 score Congrats!!! Er, I'm sorry??? However you want to take it...LOL Wish you the best..
(Thread Starter) | Not Ranked : 0 score Well, like I said, I've already kinda picked the Cobb horse for tuning. I understand you guys have found some stuff they haven't. But, I'm just not, at least for now, changing horses. I do have a lot of your stuff. I have the DP, tow plate and gauge pod. Well, not sure about that. The Cobb SRI has a velocity stack and air straighter. Last edited by Speedie6; 05-13-2010 at 05:19 PM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Nov 2008 Location: Irving, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,506
Speedie, I'm really looking forward to seeing what your car can do with a proper turbo. I was at Cobb when your car was on the dyno. There is a lot of potential there.
__________________ 2008.5 Crystal White Pearl MS3 A lot of mods Check out my big turbo build! | |
| The Following User Says Thank You to senor blanco ms3 For This Useful Post: | zx2man (06-15-2010) |
| PG Inlet Pipe Install | manofhonor24 | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 06-17-2009 10:55 PM |
| Stage 2 with an inlet pipe | Stan-O | Cobb Access Port/Maps | 13 | 03-19-2009 02:54 PM |
| ATP turbo inlet pipe? | JimmyMac | Mazdaspeed3/6 General Discussion | 3 | 05-30-2008 12:02 AM |
