 Old 03-07-2014, 06:06 AM   #1
Polish_Eagle's Avatar
Posts: 408   (View Stats)
Default CDFP Question
My CDFP isn't covered by your warranty since I'm not the original owner, but I have a question about disassembly. My pump is dirty on the inside and needs to be cleaned, but when I went to use an 18mm socket to remove the internals it didn't fit. So I was wondering if you could let me know the socket size needed to remove the internals.
I tried different metric sockets that I have, but I don't have a 20mm. From the looks of it, it appears to be a 20mm socket but I want to get confirmation before I order the socket (20mm isn't readily available).
 Old 03-07-2014, 06:10 AM   #2
pwdunmore's Avatar
Posts: 368   (View Stats)
How-to: Install your Autotech fuel pump internals
Says 18mm in that How to. Maybe your socket wasn't deep enough to clear the spring inside of it.
My car thread:
 Old 03-07-2014, 06:20 AM   #3
That's what I thought too after reading all the how to's, but 18mm doesn't work. I also went to the autoparts store and tried varying heights of 18mm and non worm. I then tried 13/16 by hand and it fits over but too loose for me to want to even try it. When I checked wrench sizing charts, the next step down is 20mm.
 Old 03-07-2014, 06:24 AM   #4
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
I believe cpe uses a larger nut in there pumps not 100 percent on that . The how to is for installing internals in a stock pump not a cpe pump. 20mm sounds right just get a deep socket that is 20mm all the way not one that reduced diameter to a stud size hole inside.
MECP
2012 BM
Rfinkle tune in progress
 Old 03-07-2014, 06:28 AM   #5
pwdunmore's Avatar
5doors is prolly right because it's a CPe pump which I didn't notice in your signature, do you have any measuring calipers to get an exact size on the nut because that would conclude this mystery lol.
My car thread:
 Old 03-07-2014, 06:30 AM   #6
I had a caliper, but can't recall where it is. I was using it in school last semester for my engineering design class but don't know it's whereabouts.... Lol
 Old 03-07-2014, 06:37 AM   #7
pwdunmore's Avatar
Sounds like something that happens to me all the time... lol.
I still can't find my work headset that I was using less than a month ago... and now I'm working on a computer and making calls so it would be perfect. Fuck murphy's law...
I don't think have a 20mm deep socket either otherwise I would just let you use it lol. I will check when I get home but as you said it's an odd size to get in a set. I know my normal set jumps from 19mm to 22mm but my other set might have it with any luck.
I'll let you know if I do.
My car thread:
The Following User Says Thank You to pwdunmore For This Useful Post:
Polish_Eagle (03-07-2014)
 Old 03-07-2014, 06:39 AM   #8
Groans: 74
Put 2 flat thooth pics on eather side of the nut and use a ruler to measure the nut diameter and convert to mm useing google. If u want to be anal u can subtract out the thickness of the thoothpics but u get the idea. Good luck dude.
MECP
2012 BM
The Following 2 Users Say Thank You to 5doorsoffury For This Useful Post:
Polish_Eagle (03-07-2014), pwdunmore (03-07-2014)
 Old 03-07-2014, 06:45 AM   #9
Haha, love it. I'll see if CPE can confirm before I finish my classes today, if not I'll do that.
The Following User Says Thank You to Polish_Eagle For This Useful Post:
5doorsoffury (03-07-2014)
 Old 03-07-2014, 01:24 PM   #10
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
good luck getting that info readily from cpe
chaser27 (03-07-2014)
 Old 03-07-2014, 01:46 PM   #11
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
First time I ever did it, I forgot to compress the spring (by just pushing on it with whatever you're using, impact gun/ratchet). I thought the same thing: "The fuck? My 18mm deep well isn't deep enough?". It is a spring, and it does compress lol
Yes I admit to being a noob once upon a time.
 Old 03-07-2014, 04:54 PM   #12
LMAO, oh I know. I was just hoping since they won't warranty my fuel pump with their "Lifetime Warranty", that they would at least help me out by saying the nut size.
 Old 03-07-2014, 10:25 PM   #13
Love the support, you can always count on cpe.....
 Old 03-09-2014, 05:48 PM   #14
Decided to just buy a new caliper today and measured the nut. The caliper said it's 19.8mm, which means I indeed need a 20mm socket.
Thought I'd post it here since cpe is the least bit helpful and other users could potentially benefit from this.
The Following 3 Users Say Thank You to Polish_Eagle For This Useful Post:
86AmishMs3 (03-10-2014), Nitr0EngiE (03-11-2014), Snip (04-08-2014)
Brownie CDFP question metalgear386 2010 MS3 - ECU Computer Tuning 13 09-02-2013 03:08 AM
CP-E cdfp install question llescaflownell MazdaSpeed 3 - Engine, Transmission & Driveline 27 07-11-2011 03:34 PM
Question on installing CDFP internals ElBartoRex MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 19 02-22-2010 09:11 AM
cdfp question itzl0l MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 2 12-25-2008 08:52 PM
AWE CDFP SpdFreak MazdaSpeed 3 - Engine, Transmission & Driveline 27 12-24-2008 02:17 PM
Page generated in 0.35266 seconds with 24 queries
