Closed Thread
 Old 10-29-2008, 01:31 PM   #1
Kennosuke's Avatar
Posts: 55   (View Stats)
Kennosuke will become famous soon enough
Default Cool Airbox and Snorkle re-route
On my way home from work, I had an odd thought. For those with the SRI and FMIC, if CPE does make the cool airbox for us, is it possible to make a re-route of the TMIC snorkles directly into the cool airbox? The idea popped into my head after seeing a hayabusa on the road. I remembered how the busa gains an extra 5~10HP at the top speeds due to the forced induction of its snorkles. I'm not sure of the actual effects it might have on our DISI engines at speed, but theoretically, would it not reduce backpressure slightly as the turbo can spin a little easier if air is being helped to push through via simply driving forward?
Just an idea, as those with FMIC render the snorkles useless.
~ "I simply do what I can, when I can, with what I've got."
Kennosuke is offline
 Old 11-01-2008, 04:24 PM   #2
bombdotcom's Avatar
Posts: 816   (View Stats)
bombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the world
Groaned at 40 Times in 20 Posts
thats a good idea
(RIP) 08' MS3---MODS:COBB AP- COBB SRI AND TIP- COBB RSB- COBB KNOB- CP-E TMIC- LIMITED EDITION HKS BOV- CORKSPORT DP AND TP- TRZ REARMOUNT- MD OCC- PTP IM COOLER KIT- COSWORTH BSD- EIBACH PROKIT- TWM SHIFTER BUSHINGS- JBR SHORT SHIFT KIT-
13' CWP MS3
bombdotcom is offline
 Old 11-01-2008, 11:05 PM   #3
kingpin748's Avatar
Posts: 2,611   (View Stats)
Groans: 78
Can't hurt I guess. But that whole ram air concept was really for NA engines and as you mentioned it's not much use under 200km.
In reality I love lenny
kingpin748 is offline
 Old 12-21-2008, 12:27 AM   #4
Kennosuke's Avatar
Well, aside from pushing air into the intake from the snorkels for HP, the other theory would be that this would bring in cooler air from outside of the engine bay directly into the cool air box, effectively making the SRI as effective and/or more effective than a CAI that brings in air from below. Besides, if the road you are traveling is a blacktop...and its the summer, I would expect the air at street level to be hotter than the air at hood level (even if barely).
 Old 12-21-2008, 07:51 PM   #5
Teacher's Avatar
Posts: 38   (View Stats)
Teacher has a brilliant futureTeacher has a brilliant futureTeacher has a brilliant futureTeacher has a brilliant futureTeacher has a brilliant futureTeacher has a brilliant futureTeacher has a brilliant futureTeacher has a brilliant futureTeacher has a brilliant futureTeacher has a brilliant futureTeacher has a brilliant future
Groaned at 5 Times in 2 Posts
Look at the Corksport FMIC design. They do exactly what you are talking about.
Teacher is offline
 Old 12-22-2008, 07:46 AM   #6
DeadWayt's Avatar
Posts: 186   (View Stats)
DeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the world
Well if you're going to do a SRI and a cool air box with a snorkle, it seems like you might as well just do a CAI to begin with.
'08.5 MS3 GT -- Metropolitan Grey
www.speedsportlife.com
DeadWayt is offline
 Old 12-22-2008, 10:47 PM   #7
Kennosuke's Avatar
Well, the major drawback of CAI is the fact that they draw air from the road (which can be fairly warm during the summer) and there is the potential to suck up water during the rainy season. SRI solves the problem of sucking up water by staying in the engine bay, but the air in the engine bay is hotter than outside, so the snorkel idea was to bring air from outside the engine bay to the SRI contained in the cool air box, but if Corksport already does that, then oorah. ( : I'll check it out.
**EDIT**
Well, I just took a look at the CS FMIC setup, and I find it odd that it is around $200 cheaper than the CS TMIC. I don't understand why. / : Installation photos appeared to show a full length CAI hooked up to the RAMAIR. I REALLY want to use the CPE Nano with a cool airbox...so I think I might go custom job on this project. However, thanks for the info, Teacher. ( :
Closed Thread
Going back to Stock airbox, for a day Doc MazdaSpeed 3/6 - Turbo Induction 0 08-24-2008 03:31 AM
Penske Racing transporter goes up in flames en route to Infineon Haltech Automotive News 0 08-21-2008 09:50 AM
2008 Dodge Challenger SRT8 en route to dealers Haltech Automotive News 0 05-28-2008 06:10 PM
Page generated in 0.27974 seconds with 24 queries
