Like Tree36Likes
 Old 10-20-2012, 07:57 PM   #41
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
Originally Posted by pinkcheese View Post
No it cannot, I talked to their new customer rep about this 4-5 days ago through emails and he specifically stated they will not sell it outside the kit. Which is redicilus to offer a Manifold with such good quality and only want to sell the DP in a incredibly overpriced kit.
That's rediculous.
Not that it matters to me now because I got some custom made but it's been a lot of headache getting everything together along the way. They let me buy the Tial manifold earlier this year but now they won't let me buy the downpipe to go with it.
Tomas, Tial has a twin scroll v-band hotside in the works it was at SEMA this year. So if CPE decides to re-cast the manifold in a twin scroll configuration then you are set.
I don't think the EFR turbos are all that great to be honest. Perrin tested them back to back and unless you get a larger frame it's not better than the GTX units. At least you can buy the GTX units.
I guess now it's the race to who releases the intake manifold.
Fueled by the haters.
The Following 5 Users Say Thank You to Celestspeed3 For This Useful Post:
Easter Bunny (10-21-2012), phate (10-24-2012), Realgib3 (10-24-2012), Tokay444 (10-21-2012), Tomas (10-20-2012)
 Old 10-20-2012, 08:06 PM   #42
Alpha's Avatar
Posts: 3,711   (View Stats)
Materials, reliability, repsonse, spool, broader power band... Not to mention they're in stock as we speak.
Everyone has their opinion, just be sure and drive an EFR based car before you "Decide" there's no difference.
Back on topic... Shiny kit! Not really down with a vband mounted turbo to manifold or EWG, but it's cool.
The Following 2 Users Say NO Thank You to Alpha For This Un-useful Post:
86AmishMs3 (10-22-2012), Easter Bunny (10-21-2012)
 Old 10-20-2012, 08:22 PM   #43
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
The tial hot side gtx turbos are very very nice. I think the kit is a great price but most people already have half of those parts. I nearly bought a cpe vband mani but I backed out because of the dp fab work, my car has been down since june already.
Whoever makes the ebay dp needs to make another knockoff dp, I think cpe has the best high hp mani on the market right now and the price is very reasonable.
2006 Mazdaspeed 6
The Following 4 Users Say Thank You to 06Speed6 For This Useful Post:
802MS3 (10-21-2012), atvfreek (10-22-2012), RichieRichness (10-23-2012), SilverDemon (10-20-2012)
 Old 10-20-2012, 08:33 PM   #44
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
I am aware Tial doesen't produce TS housings = don't use Tial.
Strongly disagree the small frame EFR turbos can not benefit from a TS housing. You can flow all you want with a large enough compressor wheel
but if you chock the exhaust you are gonna limit the engine's potential.
You don't want TS for faster spool only. You also want it for less backpressure given that you usually use a higher AR with a TS.
that is y you run a big w/g it bypasses the turbo so it controls boost and extra exhaust pressure is also relieved ..........
their is a hundred ways to do it
i prefer smaller hot side, bigger w/g for better spool
at 104000 2 bent rods
tuned by nishan
 Old 10-20-2012, 08:35 PM   #45
thehead's Avatar
Posts: 1,141   (View Stats)
thehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the world
Groans: 143
Yeah i know. Im one of those paranoid people that never goes wot under 3k unless its for logging
Just got a reminder last weekend of how important it is to upgrade the rods.. An 2010 MS3 blew a hole through the bottom
just because you don't go WOT under 3k doesn't mean that you're not going to blow, take me for example, my piston/rod went through my block at 5k rpm. upgrade your rods before bt. piston going through block is bad.
2016 BMW M235i
[Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles
Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals
Electrical - GS EBC - Cobb AP Richtune in progress
Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's
Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40.
thehead is offline   Reply With Quote
 Old 10-20-2012, 08:54 PM   #46
Zimmo's Avatar
Posts: 53   (View Stats)
Zimmo has a reputation beyond reputeZimmo has a reputation beyond reputeZimmo has a reputation beyond reputeZimmo has a reputation beyond reputeZimmo has a reputation beyond reputeZimmo has a reputation beyond reputeZimmo has a reputation beyond reputeZimmo has a reputation beyond reputeZimmo has a reputation beyond reputeZimmo has a reputation beyond reputeZimmo has a reputation beyond repute
4.5K looks like a good buy, now to find the monies..... my crack for rent again i guess!!!
New Zealand - Mazda3 MPS Gen2
195kw atw
Current Mods:
GFB - GFB9002 BOV | Torque Solution - Shifter bushings/ short shift plate | Whiteline - Front and rear sway-bar | CP-E - RMM & both side mounts | MazdaEdit - Tune by Torque Performance | JBR - Full Intake | CP-E - Topmount | Ebay - Testpipe | CS - Rice scoop | Autotech - Internals | Denso - ITV22 | Hardrace - Rear Camber Arms
Zimmo is offline   Reply With Quote
 Old 10-20-2012, 10:41 PM   #47
About time CP-e builds something we can use.. Im all for moving away from ATP's garbage and fucking people over who got the GTX's that failed. Bravo Cpe
They should offer that downpipe separate though.
pinkcheese and cshunter like this.
The Following 4 Users Say Thank You to Haltech For This Useful Post:
86AmishMs3 (10-22-2012), atvfreek (10-22-2012), cshunter (10-21-2012), Downmented (10-23-2012)
 Old 10-20-2012, 11:19 PM   #48
Zimmo's Avatar
Maybe they will sell the DP if there is enough group pressure?? Does sound like they are punishing the people who have already purchased the manifold.
There is sooo much to buy..... this forum is going to make me poor but happy!
pinkcheese likes this.
195kw atw
Current Mods:
 Old 10-21-2012, 08:30 AM   #49
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
think cp-e would back the GTXs if they failed, or would they bitch out like ATP?
08.5MS3 likes this.
'08 CWP MS3 w/ T3 3071r
08.5MS3 (10-21-2012)
 Old 10-21-2012, 08:46 AM   #50
pinkcheese's Avatar
Posts: 339   (View Stats)
pinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the world
We should put pressure on them, if they sold the DP Seperate they would see a higher manifold selling rats too. The DP fab as someone put it is the thin holding people back from what is the best quality manifold right now. Which is sad CP-E has a gold mine at their finger tips and they don't realize it. Hell if they just slapped a standard 2bolt flange on their downpipe they would have two communities to sell this setup to.
pinkcheese is offline   Reply With Quote
 Old 10-21-2012, 02:22 PM   #51
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Looks like a pretty nice setup.
If I was starting from scratch, I would probably buy it...
The Following 2 Users Say Thank You to cld12pk2go For This Useful Post:
86AmishMs3 (10-22-2012), Tokay444 (10-21-2012)
 Old 10-21-2012, 02:29 PM   #52
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
But, if you bought the manifold 6 months ago, before there was even a DP that would work for it, and then they turned to you and said you couldn't have one that DOES fit, would you not be pissed?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 10-21-2012, 02:40 PM   #53
Eth/Meth Junkie
cld12pk2go's Avatar
But, if you bought the manifold 6 moths ago, before there was even a DP that would work for it, and then they turned to you and said you couldn't have one that DOES fit, would you not be pissed?
Of course I would be...
I would expect it to eventually be available separately, but not initially due to all going to the full kits...nothing unusual about that marketing/manufacturing plan.
If they don't do that, then well...they kind of suck.
 Old 10-21-2012, 02:43 PM   #54
Lawl
bstover17 (10-21-2012)
 Old 10-21-2012, 02:50 PM   #55
Tokay444's Avatar
Groans: 793
cp-e doesn't back shit they make themselves, let alone shit they don't make.
see "broken cp-e mazda 6 exhaust".
Demodded.
The Seals
 Old 10-21-2012, 06:04 PM   #56
Don't even get me started on that $3000 adventure.
 Old 10-22-2012, 01:10 PM   #57
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
DP will be offered separate if you bought the manifold before the kit was released. Price TBD.
Website: www.cp-e.com
The Following 11 Users Say Thank You to www.cp-e.com For This Useful Post:
86AmishMs3 (10-22-2012), atvfreek (10-22-2012), breakfasteatre (10-22-2012), daafisch (10-22-2012), Downmented (10-23-2012), Easter Bunny (10-22-2012), EdgeAutosport.com (10-22-2012), MS3-a(sore)ASS-rex (10-23-2012), Realgib3 (10-24-2012), silvapain (10-22-2012), Voltwings (10-22-2012)
 Old 10-22-2012, 01:14 PM   #58
Tokay444's Avatar
Groans: 793
good.
Demodded.
The Seals
www.cp-e.com (10-22-2012)
 Old 10-22-2012, 01:14 PM   #59
Default Introducing the cp-e MazdaSPEED3 Atmosphere Turbo Kit
So you’ve got the bolt-ons, you’ve got the tune, but it still just isn’t enough, right? Don’t let this keep
you up at night, because your desires can now be completely fulfilled. Here at cp-e™ we know that
you don’t want to go faster, but instead you need to go faster. That need is why countless hours in
R&D have been spent to develop the last turbo kit that you will ever need to look at for your
MazdaSPEED3.
Introducing the new MazdaSPEED3 Atmosphere™ Turbo Kit by cp-e™. This ultimate big turbo
upgrade for your MazdaSPEED3 application includes everything you need to take care of your need
for speed and take your car from a stock turbo to a new Tial Stainless Steel Big Turbo.
MSRP: $5999 GT/ $6350 GTX
PART NUMBER: MMSP3TUK
Kit Includes:
• cp-e™ MZR DISI 2.3 =LRTmani™ Turbo Manifold
• cp-e™ MazdaSPEED3 DownScream Downpipe
• cp-e™ XcelXL Intake with Filter
• cp-e™ Nviscid Big Turbo - Turbo Inlet Pipe
• Tial MVR External Wastegate
• Wastegate coolant lines
• Oil circulation lines
• Necessary gaskets, screws, clamps, couplers, and fittings
Kit Options:
• Tial VBand Turbine Housing
• GTX 2867
• GT 2871
• GT 3071
• GTX 3071
• GT 3582
• GTX 3582
• Optional Wastegate colors
This kit comes with an exhaust manifold specifically designed with Tial flanges to fit Tial VBand Turbine Housings from GT28-GT35, and Tial MVR External Wastegates. The =LRTmani™ Turbo Manifold is a stainless steel exhaust manifold that comes in a cast 304 stainless steel, and is designed to allow for the most efficient exhaust flow possible.
A common setup for the turbo bypass is to use a screamer pipe, which dumps the exhaust to the atmosphere immediately after the exhaust manifold. This practice is lackadaisical at best, so cp-e™ has taken the extra time and effort to divert the exhaust correctly. The cp-e™ DownScream diverts gases straight into the exhaust pipes to be expelled out of the rear of the car. Having this setup keeps your high boost events quietly intense, rather than noisy and agonizing. cp-e™ has designed this downpipe to keep your system within a legitimate decibel range.
The shining piece to this kit is by far the cp-e™ MazdaSPEED3 DownScream. Made with 3” 304 stainless steel, this downpipe eliminates both stock catalytic converters to allow for smooth exhaust flow and transition. Not only is this downpipe designed to give a free flowing exhaust from your turbo, but it is also designed to attach to the Tial MVR External Wastegate. The wastegate actuates at high pressure and causes the system to divert the engine exhaust away from the turbo.
Also included is the cp-e™ XcelXL™ Intake and Nviscid™ Turbo Inlet Pipe that will give your engine the air it needs when it demands it so that your MazdaSPEED3 can reach higher horsepower ranges. No turbo kit would be complete without the proper coolant and oil lines. cp-e™ has done it right once again by also supplying you with steel braided –AN lines for your coolant and oil routing that will fit right in with your new setup. We’re even giving you a CNC lathed –AN adapter for the oil feeder hose to allow you to attach to your MazdaSPEED3 with no worries.
A/R's for the GT's:
2871- .86
3071- .63
3582- .82
Mod's if you could please merge this thread here it would be most appreciated.
http://www.mazdaspeedforum.org/forum/foru...bo-kit-127950/
Last edited by www.cp-e.com; 10-22-2012 at 01:14 PM. Reason: MSF Database - Automerged Doublepost
The Following 4 Users Say Thank You to www.cp-e.com For This Useful Post:
Realgib3 (10-24-2012), rfinkle2 (10-22-2012), RichieRichness (10-22-2012), zkrick (10-22-2012)
 Old 10-22-2012, 01:15 PM   #60
Mods could you please merge this thread with the one we posted in our section:
It would be most appreciated.
Thanks!
The Following 2 Users Say Thank You to www.cp-e.com For This Useful Post:
atvfreek (10-22-2012), rfinkle2 (10-22-2012)
 Old 10-22-2012, 01:22 PM   #61
Notes:
-Trick EWG plumb back that will keep the EWG noise down (if that is what you'd like and would be my preference)
-No creep issues on this set-up (see above)
-All feed and return lines included
-All gaskets included
-Everything you need to go BT EWG (without the EWG volume)
-$4500.00
IMO, a pretty nice turn key solution with lots of turbo choices.
(The DP availability may be due to the plumbing for the EWG... not 100% sure, but it may be a limiting factor).
The Following 6 Users Say Thank You to rfinkle2 For This Useful Post:
86AmishMs3 (10-22-2012), atvfreek (10-22-2012), daafisch (10-22-2012), Grumpyjap (10-22-2012), trf5000 (10-22-2012), triphop631 (10-22-2012)
 Old 10-22-2012, 01:35 PM   #62
Karmat's Avatar
Posts: 1,179   (View Stats)
So what's the word on MS6s.
MS3s get a downpipe for the cp-e manifold so I assume there is one in the works for MS6 as well?
2002 Corvette Z06 (Black)
The Following User Says Thank You to Karmat For This Useful Post:
speed23 (10-22-2012)
 Old 10-22-2012, 01:45 PM   #63
BoominChu's Avatar
Posts: 188   (View Stats)
BoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond repute
Groaned at 7 Times in 5 Posts
the lunacy and retardation aren't in offering a new kit. that's fine. awesome even.
the lunacy is not offering the downpipe to the people who already bought their manifold that doesn't work with any other dp. that's what's retarded.
Full-Race EM > CP-e EM
EFR > GTX
If the CP-e kit is $4500, then I can see the value. Not for $6000 though.
Tapadatass
do you 2 ever like anything? you're like divorced 45yr old women, its like u hate life, you don't like it move on but building a BT kit from scratch, you will nickel and dime your way to the 5k mark before you know it. why not buy the full kit the community deserve with out having to rummage around looking for this that and the third.
Downmented likes this.
BoominChu is offline   Reply With Quote
The Following 3 Users Say NO Thank You to BoominChu For This Un-useful Post:
Easter Bunny (10-22-2012), silvapain (10-22-2012), Tokay444 (10-22-2012)
 Old 10-22-2012, 01:47 PM   #64
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
You keep buying shit off the shelf. I'll keep pushing the platform to be the best it can be.
The Following 7 Users Say Thank You to silvapain For This Useful Post:
ASHMS3 (10-22-2012), breakfasteatre (10-22-2012), Deldran (10-22-2012), Keko (10-27-2012), skiptowncat (10-22-2012), tddvrrn (10-22-2012), Vader (10-23-2012)
 Old 10-22-2012, 02:07 PM   #65
BoominChu's Avatar
my point is the platform like all other platforms need solutions, here is one and its not ghetto rigged. hmmm let me bash it because I'm cheap, or better yet cuz it is fun to hate.
 Old 10-22-2012, 02:14 PM   #66
Volcom8190's Avatar
Posts: 448   (View Stats)
Volcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the world
if they remake it with a twinscroll tial when that comes out and consider putting a cat option for the down pipe, I think this would be a good option, and quite frankly something I would consider, yea the price is a little high, but it has literally everything but a tune.
2010 - BMW 335i M-Sport - Lemans Blue Metallic
2005 - Kawasaki ZX-6R 636 - Magma Red
Volcom8190 is offline   Reply With Quote
 Old 10-22-2012, 02:18 PM   #67
Tokay444's Avatar
Groans: 793
My problem was never "I don't like the kit."
It was that the rumor was if you bought their manifold, back when they didn't have a dp solution until now, that you weren't going to be able to get the dp outside of this kit.
That rumor has since been falsified, and I no longer have a problem. Now go brown somewhere else.
Demodded.
The Seals
The Following 7 Users Say Thank You to Tokay444 For This Useful Post:
ASHMS3 (10-22-2012), atvfreek (10-22-2012), Don06speed6 (10-22-2012), Easter Bunny (10-22-2012), rfinkle2 (10-22-2012), silvapain (10-22-2012), tddvrrn (10-22-2012)
 Old 10-22-2012, 02:26 PM   #68
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
anyone else think that compressor outlet is too damn close to the fuckin manifold flange? that's just me, but DAMN.
07 MS3
The original Genpoo Hater
 Old 10-22-2012, 02:27 PM   #69
BoominChu's Avatar
lol, i giggled.
 Old 10-22-2012, 02:29 PM   #70
silvapain's Avatar
Groans: 136
And a FMIC or upgraded TMIC, which would be required. And a HPFP. And an AP.
But yes, this is the most complete kit you can buy right now. Most everyone looking to go BT will already have a new intercooler, HPFP upgrade, and an AP.
ASHMS3 (10-22-2012), Easter Bunny (10-22-2012), rfinkle2 (10-22-2012)
 Old 10-22-2012, 03:29 PM   #71
Tokay444's Avatar
Groans: 793
The full race kit also has an fmic and a intake.
For two grand more.
As much as I knock it, that full race kit it baller.
They just need to hurry up and get some higher flowing turbos.
lol, i giggled.
Seriously though, if you can't see why I, or the people who actually already own the manifold would be upset, then I can't help you.
Demodded.
The Seals
Last edited by Tokay444; 10-22-2012 at 03:29 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-22-2012, 04:05 PM   #72
surebOOst's Avatar
Posts: 1,795   (View Stats)
surebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the world
Groaned at 61 Times in 40 Posts
This is nice to see!
2006 Evolution IX RS
ER Built 2.3l
On jackstands
awaiting parts
surebOOst is offline   Reply With Quote
 Old 10-22-2012, 04:40 PM   #73
CP-E... if you are checking in on this thread, this is a great opportunity for you to help us out with something.
We desperately need a separately purchasable v-band dp and one that is affordable would be a really good seller, imo.
ASHMS3 likes this.
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
ASHMS3 (10-22-2012), atvfreek (10-22-2012), DaDoctor (10-22-2012), magicka (12-18-2012), Tokay444 (10-22-2012)
 Old 10-22-2012, 05:50 PM   #74
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
I would get this if it was available for my 6.
Some advice to cp-e:
1. Include Catted option (people really need it to pass emissions)
2. Keep the price where it is... The "MSRP $5999/$6350" price is waaay too much cash. Then people will just fab their own EWG DP/wastepipe. Everybody's loss
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 10-22-2012, 06:06 PM   #75
+ How hard it is to simultaneously post the new kit here and on the cp-e website instead of folks discovering the new kit a few days before the official announcement here and the ensuing shit storm?
 Old 10-22-2012, 06:11 PM   #76
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
so is this 5999 or 4500?... is the 4500 an intro price?
 Old 10-22-2012, 06:15 PM   #77
triphop631's Avatar
Posts: 1,191   (View Stats)
triphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the world
Groans: 30
4500 for gt and 4850 with the gtx from what I see on their website.
Sent from my Nexus 7 using Tapatalk 2
I haz Partz!!!!!!!!!!
triphop631 is offline   Reply With Quote
 Old 10-22-2012, 06:19 PM   #78
exentix's Avatar
Groans: 46
then why advertise the msrp price on here of 5999?
 Old 10-22-2012, 06:27 PM   #79
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
very nice looking piece
+ 1 on the MS6 version.
 Old 10-22-2012, 07:01 PM   #80
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
To make it look like you're getting a deal.
Beanfab / Tuned by Nishan
The Following 7 Users Say Thank You to doubleflusher For This Useful Post:
ASHMS3 (10-22-2012), bstover17 (10-22-2012), Davsetz (10-23-2012), Don06speed6 (10-22-2012), KusteLokal (10-23-2012), Realgib3 (10-24-2012), silvapain (10-22-2012)
venting to atmosphere X lady killer X CX-7 > Engine, Transmission & Driveline 14 04-02-2011 10:28 AM
Geneva Preview: Techart to debut 911 Turbo, Turbo S Haltech Automotive News 0 02-16-2010 03:20 PM
Page generated in 0.63929 seconds with 44 queries
