| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
__________________ 2008 TR MS3 Sport[/B]:Cobb Sri,AP/Corksport Dp/Vibrant Dp Back/Pg HF CDFP/SU Boost Tubes/TRZ Poly MM/TWM STS, Shifter bushings/DashHawk/Turbosmart DualPort BOV/15,35% Tints/AutoExe Shift Knob/ Redline Shifter,E-brake Boot Future Mods[/B] auter Rods/CP pistons/PTP SST K04/PG Tubular Manifold EWG/Turbo XS Dp/Cobb TIP/HKS Plugs/Perrin OCC/Devils Own WM Injection/BC Racing Coilovers/Hotchkis H&R Sway Bars/Rotora F&R slotted Rotors/EBC Red stuff Pads/Goodridge Stainless Brake Lines/ACT Street clutch and flywheel/Cobb FMIC/Tial 38mm v-band and screamer pipe/SU Side Mounts/8000k HIDs/PTP BS delete,WT/rx8 wheels/samco silicone hoses/235-40-18 Falken Azenis RT-615/P&L Motorsports ATP or ATR tune we will see though although 350whp is the goal! |
| Banned ![]() Join Date: Dec 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 131
| Not Ranked : 0 score i don't know how much it is, but it comes with an ECU flash. i do know that they are in stock so randy should be able to get it to you quickly. i'll try to find some pics, but it is nothing special really. it's a tube with a MAF adapter on it. it is designed to be able to be used as is, or you can cut it up and weld it to some piping for a totally custom application. crazyitalian used some silicone to mate it up to the cp-e TIP. |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score jordan sent this pic to me. i believe its robbies car. i paid $250( i think this is the intro price) for the big maf and the flash is seperate. another $35.
__________________ |
| The Following User Says Thank You to johnac08 For This Useful Post: | phailerider (05-18-2009) |
