 Old 06-19-2014, 11:09 AM   #1
mike16241's Avatar
Posts: 46   (View Stats)
mike16241 is a glorious beacon of lightmike16241 is a glorious beacon of lightmike16241 is a glorious beacon of lightmike16241 is a glorious beacon of lightmike16241 is a glorious beacon of lightmike16241 is a glorious beacon of light
Default Cp-e fmic review
Well got my cp-e fmic installed. By far the most simple fmic install I have done so far. No cutting or fabrication required. The crash bar is beefy and stiffens up the front end. The core bolts up to the crash bar and one of the under tray bolts. The piping is bead rolled so you can really clamp down on it to prevent any leaks. And gor those of you worrying about boost lag on the ko4 its really not noticeable. My boost temps have dropped considerably. I absolutely love this kit for ease of install, amazing quality and performance its well worth the buy. Im hoping a redesigned ms6 fmic kit comes out from these guys because I'll want the first one
mike16241 is offline   Reply With Quote
 Old 06-19-2014, 11:10 AM   #2
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
what ? no pics?
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
86AmishMs3 (06-20-2014)
 Old 06-19-2014, 11:11 AM   #3
Big Dog's Avatar
Posts: 730   (View Stats)
Groans: 89
Groaned at 9 Times in 9 Posts
I'd second a redesign/re-release of the kit for the MS6!
Us MS6 guys need a quality FMIC option.
 Old 06-19-2014, 02:36 PM   #4
TheRoyceWay's Avatar
Posts: 224   (View Stats)
TheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the world
I'd just appreciate the option to buy a replacement intercooler core mounting plate/bracket thing...
TheRoyceWay is offline   Reply With Quote
 Old 06-19-2014, 05:33 PM   #5
bryancregger's Avatar
Posts: 205   (View Stats)
bryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant futurebryancregger has a brilliant future
What gen is this on? I question the effectiveness of a FMIC on a pu because of the limited opening in the grill. I would really enjoy seeing the CP-E TMIC vs FMIC on the same car, preferably a pu beacuse the juan's actually have a reasonable opening for a fmic.
______________________
___________________________________
\\ 2010 MS3 \\ BNRS3 \\ Cobb SF Intake \\ CP-E TMIC \\ Corksport TIP \\ Cobb AP v2 \\ Autotech HPFP \\ ACT Clutch \\ JBR PMM and RMM \\ Corksport TMM Insert \\ JBR SSP \\ Corksport Catch Can \\ FREEKTUNED \\ Cobb 3 Port EBCS \\ Stoptech Slotted Rotors \\ JBR EGR Delete \\ 3 Bar MAP \\
bryancregger is offline   Reply With Quote
 Old 06-19-2014, 08:04 PM   #6
shadesofgray19's Avatar
Posts: 794   (View Stats)
Full-Race, expensive but the best by far and you get a crash bar.
 Old 06-20-2014, 03:50 AM   #7
dale_gribble's Avatar
Posts: 4,720   (View Stats)
WTF is this? Is this Amazon.com? This isn't another website where non-data reviews mean anything. How is boost lag not noticeable? Did you do data logs? How are boost temps better? Did you do data logs? What conditions? What temps? How did you quantify that the crash bar stiffens up the front end? Did you do an autocross event and land faster lap times?
pffft.
EDIT: I wrote this when I was drunk last night. I didn't mean to be a total dick, but I'm just saying, challenge yourself to create data and quantify your gains. We are a technical forum and data is king.
MINI H1 6.0 - CAR LED TAILS
agentgordon27 (06-21-2014), Benis (06-20-2014), chaser27 (06-23-2014), Hammology (06-20-2014), jdmage_mx5 (06-21-2014), MS3Shadow (06-20-2014), TheRoyceWay (06-20-2014)
 Old 06-21-2014, 03:14 PM   #8
Wildchild76's Avatar
Posts: 92   (View Stats)
Wildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant futureWildchild76 has a brilliant future
Groaned at 6 Times in 2 Posts
I put mine on last month. I like it a lot, but the elbows seem to create a kink in some places, especially coming out of the turbo, which wouldn't seem to allow good air flow.
Autotech Internals, HTP 4" Intake, OCC, BSD, Oil pan baffle,egr delete, Turbosmart Bpv, AP 3, JBR 88 Duro Mounted & Shifter Bushings, CP-e DP, CS Catback, CS front and rear sway bars, JBR rear camber arms, CS BBK w/ EBC Yellows, Koni Yellows w/ GC Coilovers, Stoptech slotted rotors w/EBC yellow stuff pads, Braided brake lines, DOT 5 fluid, CPe FMIC, CPe Turbo Mani, Precision BB 5858, Tial 44mm WG, JM Fab v1 IM, Cobb EBCS, Rolling on XXR 527s wrapped in Toyo R888's, Purple Drank Tuned Waiting to be installed: SP63 5th & 6th PI
Wildchild76 is offline   Reply With Quote
 Old 06-21-2014, 04:48 PM   #9
griffeyfan25's Avatar
Posts: 83   (View Stats)
griffeyfan25 has a reputation beyond reputegriffeyfan25 has a reputation beyond reputegriffeyfan25 has a reputation beyond reputegriffeyfan25 has a reputation beyond reputegriffeyfan25 has a reputation beyond reputegriffeyfan25 has a reputation beyond reputegriffeyfan25 has a reputation beyond reputegriffeyfan25 has a reputation beyond reputegriffeyfan25 has a reputation beyond reputegriffeyfan25 has a reputation beyond reputegriffeyfan25 has a reputation beyond repute
Groaned at 42 Times in 17 Posts
Default Reply
I'd like to see a picture of what this setup looks like from the front of the car. I remember years ago their shit was off center and it looked weird.
griffeyfan25 is offline   Reply With Quote
 Old 06-21-2014, 06:18 PM   #10
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
It is centered now.
 Old 06-21-2014, 06:31 PM   #11
yourname2221's Avatar
yourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the worldyourname2221 is the leader of the world
Installed: JBR SSP/RMM/RSB
Cobb APv3/EBCS
AT Internals
Bilstein Coilovers
SPC arms
UR
TP/DP
BNR S4, JBR Undermount w/TR8, 3.5" intake
OBX CBE
For dat racecar: Gold Caliper Paint
yourname2221 is offline   Reply With Quote
 Old 06-23-2014, 08:43 AM   #12
Default Reply
It is centered now.
Good to know thanks.
 Old 06-23-2014, 09:54 AM   #13
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
pffft.
hahahaha. this ^
Maybe he has an extremely accurate and calibrated butt dyno. We just need to take his word for it.
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
Review of UR FMIC for Genpu dMuze Ultimate Racing 65 06-03-2014 07:18 PM
Corksport FMIC w/ Ram air Review MS309 2010 MS3 - Turbo Induction 38 04-30-2013 07:42 PM
Review: Review: Need For Speed: Most Wanted [w/video] Haltech Automotive News 0 11-08-2012 01:20 PM
Page generated in 0.33401 seconds with 32 queries
