| HOCKEYNUBE | 04-26-2016 08:25 AM | CP-E motor mounts should you buy? So I'm going to swing a little bit from CP-E's nuts here but I want to get this out there.
A long long long time ago when I was "fully bolted" and "stage bro" I heard CP-E made good products but I couldn't see myself spending 6-700 bucks on motor mounts while other companies such as JBR and CS had more affordable mounts.
I purchased the JBR trilogy set up and at the time I knew it vibrated a lot but I was okay with it for the most part.
Fast forward to building the motor and installing a 5862, and a very important detail this was around the time JBRs crap started to surface about mount failures. So I got rid of those mounts as fast as I could.
Bought a CP-E stage 2 RMM, CS PMM, and a CP-E TMM. Again it vibrated a lot but it wasn't so bad (keep in mind I have no balance shaft at this point) (also keep in mind I didn't drive the built motor on JBR mounts) I loved the set up the way it was for the most part, wasn't unbearable to drive with the vibrations BUT something with having the CS PMM and the CP-E TMM my motor sat at like a 5* angle, nothing crazy but it was noticeable enough that people could point it out and ask why my motor is on an angle.
So another fast forward to pulling the motor, cleaning the bay and putting on a 6266. At this point I had gotten rid of my CS PMM and bought a CP-E PMM. (so now I am aware of the vibs of other mounts without a BS)
I will say that "the settling period" of all three CP-E mounts was quite rough longer than having different mounts but after this period of time the vibs became less and less noticeable even with a BSD. Was in love with them!
Now for the reason you read all this, I got into my buddies car down a the dragon during ENM and he had some of the above mentioned mounts but he did have a CP-E gen 1 mount in the rear. But holy mother of god I don't know how he can drive this car on a daily basis, its almost painful (he is BT and has a build motor with a BSD, almost the same exact build as me, hell its my old turbo haha)
So moral of the story is CP-E motor mounts are way over engineered to work with the movement of the motor while other companies mounts actually try to fight it creating a very uncomfortable drive.
If you look at other mounts VS the CP-E mounts you will see what I mean, the poly is in the perfect spots on their mounts. So they can use a little lighter duro on their bushings but since they are well placed they are more effective than other companies hard ass poly bushings.
YOU PAY FOR GOOD ENGINEERING! bottom line you wont regret the extra money they charge. |
