| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() Join Date: Aug 2013 Location: Mentor, Ohio
(Thread Starter) | Not Ranked : 0 score A long long long time ago when I was "fully bolted" and "stage bro" I heard CP-E made good products but I couldn't see myself spending 6-700 bucks on motor mounts while other companies such as JBR and CS had more affordable mounts. I purchased the JBR trilogy set up and at the time I knew it vibrated a lot but I was okay with it for the most part. Fast forward to building the motor and installing a 5862, and a very important detail this was around the time JBRs crap started to surface about mount failures. So I got rid of those mounts as fast as I could. Bought a CP-E stage 2 RMM, CS PMM, and a CP-E TMM. Again it vibrated a lot but it wasn't so bad (keep in mind I have no balance shaft at this point) (also keep in mind I didn't drive the built motor on JBR mounts) I loved the set up the way it was for the most part, wasn't unbearable to drive with the vibrations BUT something with having the CS PMM and the CP-E TMM my motor sat at like a 5* angle, nothing crazy but it was noticeable enough that people could point it out and ask why my motor is on an angle. So another fast forward to pulling the motor, cleaning the bay and putting on a 6266. At this point I had gotten rid of my CS PMM and bought a CP-E PMM. (so now I am aware of the vibs of other mounts without a BS) I will say that "the settling period" of all three CP-E mounts was quite rough longer than having different mounts but after this period of time the vibs became less and less noticeable even with a BSD. Was in love with them! Now for the reason you read all this, I got into my buddies car down a the dragon during ENM and he had some of the above mentioned mounts but he did have a CP-E gen 1 mount in the rear. But holy mother of god I don't know how he can drive this car on a daily basis, its almost painful (he is BT and has a build motor with a BSD, almost the same exact build as me, hell its my old turbo haha) So moral of the story is CP-E motor mounts are way over engineered to work with the movement of the motor while other companies mounts actually try to fight it creating a very uncomfortable drive. If you look at other mounts VS the CP-E mounts you will see what I mean, the poly is in the perfect spots on their mounts. So they can use a little lighter duro on their bushings but since they are well placed they are more effective than other companies hard ass poly bushings. YOU PAY FOR GOOD ENGINEERING! bottom line you wont regret the extra money they charge.
__________________ 2010 MS3 Black mica|Custom head gasket|Custom timing cover gasket|Keyed crank|Manley H-Beams|Manley 88mm Pistons|Supertech valve spring kit|Balance shaft delete|ACT 6 puck sprung clutch|Streetlite flywheel|PNP stock Intake manifold|PNP cylinder head by Realgib3|custom 4" intake pipe|HKS SSQV|CPE Stage 2 RMM|CPE TMM|CPE PMM|Custom Cat Back|Custom Long Downpipe|TRE 1045 FMIC|JBR oil catch can|Sonic Tuning coilovers|SS Brake lines|Blank rotors|hawk HPS pads|6th port w/ 2 2200 cc injectors|PTE DBB 6266 Gen 2 v-band all the things|Homemade Tubular Exhaust Manifold|Tuned by Realgib3|SP63 Aux Fan controller |
Groans: 438
| Not Ranked : 0 score This will probably get deleted since it's in CP-e section, but it's obvious you haven't tried the Damond Motorsports mounts, they are better in every way. I was fully mounted with CP-e (S2 RMM and 60a TMM/PMM), have no complaints, they worked great. But less nvh, vibration, shaking, noise, and a better feeling all around ride with the DM mounts.
__________________ 2010 MS3 Black mica|Custom head gasket|Custom timing cover gasket|Keyed crank|Manley H-Beams|Manley 88mm Pistons|Supertech valve spring kit|Balance shaft delete|ACT 6 puck sprung clutch|Streetlite flywheel|PNP stock Intake manifold|PNP cylinder head by Realgib3|custom 4" intake pipe|HKS SSQV|CPE Stage 2 RMM|CPE TMM|CPE PMM|Custom Cat Back|Custom Long Downpipe|TRE 1045 FMIC|JBR oil catch can|Sonic Tuning coilovers|SS Brake lines|Blank rotors|hawk HPS pads|6th port w/ 2 2200 cc injectors|PTE DBB 6266 Gen 2 v-band all the things|Homemade Tubular Exhaust Manifold|Tuned by Realgib3|SP63 Aux Fan controller | |
Groans: 143
__________________ 2007 Mazdaspeed3 GT | |
![]() EDIT: Not to mention I am FFSing at 8000 RPM, sometimes more if I want to drag the gear out more
Groans: 143
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score Damn. Who built that motor? What's in your head?
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
(Thread Starter) | Not Ranked : 0 score I built my own motor, and the head is ported by a local that had it on his car. have super tech springs and stock cams, 8k isn't pushing anything really, especially when you cant tune past 7k anyways..... fucking cobb
| The Following User Says Thank You to HOCKEYNUBE For This Useful Post: | WetzMS3 (04-27-2016) |
Groans: 33
| Not Ranked : 0 score I've asked for proof several times from the fb-jbr-haters but have still seen nothing about failing jbr mounts other than a few bushing failures (uncommon). Most just ride the bandwagon without personal experience. Maybe I missed a thread on here if there is any but I would really like to see some actual pictures of catastrophic failures Cpe has quite a few failures themselves but that's mostly bushing related. To be a little more safe I plan on installing the White widow FMM
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor | |
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
| Sure Motor mounts | Noodlesincup | Gen2 MS3 General Discussion | 5 | 08-15-2014 08:22 PM |
| motor mounts | LiEast | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-13-2009 06:34 AM |
