Like Tree3Likes
  • 1 Post By Gr8Speed
  • 2 Post By mituc
 Old 09-18-2014, 11:37 AM   #1
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Default cp-e™ Redesigned Nviscid™ Turbo Inlet Pipe
For more information visit: Mazda MZR 2.3 DISI Nviscid? Turbo Inlet Pipe for Stock Turbos | cp-e?
There was no issue with the old design so owners of the previous design need not worry. We incorporated the Mazda fix for the smoking turbo.
Website: www.cp-e.com
Poohster (09-18-2014)
 Old 09-18-2014, 11:44 AM   #2
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
"Reinforced silicone for maximum durability"... I thought there wasn't an issue with the silicone?
LumberJack likes this.
Jtaylor (09-18-2014), LumberJack (09-18-2014)
 Old 09-18-2014, 03:23 PM   #3
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
So, upgrading to a CPE tip means no more smokey turbo???
The Following User Says Thank You to SarcasticOne For This Useful Post:
 Old 09-18-2014, 03:35 PM   #4
BlackFlag's Avatar
Posts: 596   (View Stats)
I believe it can incorporate one of the Mazda "fix" mods.
Your username has me guessing the intentions of your question lol.
The Following 5 Users Say Thank You to BlackFlag For This Useful Post:
Easter Bunny (09-19-2014), everton99 (09-19-2014), LumberJack (09-18-2014), Voltwings (09-19-2014), Yousuf (09-22-2014)
 Old 09-18-2014, 03:57 PM   #5
Everybody and their uncle has an aftermarket intake + there are already many choices yet for some mysterious reason cp-e chooses to spend time on this re-design bullshit rather than focus on the intake manifold, beats me....
The Following 6 Users Say Thank You to Code Monkey For This Useful Post:
1cms1 (09-18-2014), Easter Bunny (09-19-2014), Gr8Speed (09-18-2014), JSmith (09-18-2014), Lakespeed6 (09-19-2014), Voltwings (09-19-2014)
 Old 09-18-2014, 04:08 PM   #6
Gr8Speed's Avatar
Methinks it might have something to do with my email correspondence with them about mine disintegrating from I think- oil (no catch can) after 60,000~ miles. I went to install my meth kit and pulled the intake off to find it had turned into jello on the inside.
I then sprayed pre-turbo meth and it literally started launching chunks of itself into my turbo.
Chemical resistant silicone? LOL.
Plus all of the competitors have done redesigns recently. That makes sense.
Last edited by Gr8Speed; 09-18-2014 at 04:08 PM. Reason: MSF Database - Automerged Doublepost
Easter Bunny (09-19-2014), Voltwings (09-19-2014)
 Old 09-18-2014, 05:04 PM   #7
Your username has me guessing your intentions of your question lol.
Hehe, mostly tongue in cheek :p
It MAY help to mask the issue, but at the end of the day, you still have a smokey turbo
 Old 09-19-2014, 12:59 AM   #8
Thepedigree13's Avatar
Posts: 608   (View Stats)
Groans: 64
$210 is kinda high for just the TIP considering a full 3" intake from another vendor is only $75 more.
Although i do like the game called "just the TIP".
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
Snip (09-19-2014)
 Old 09-19-2014, 04:26 AM   #9
Snip's Avatar
Posts: 329   (View Stats)
@www.cp-e.com;
What exactly is redesigned?
As an owner of the previous Nviscid, is there something I should be worried about in the near future, like @Gr8Speed; mentions?
Is the silicone used for this TIP different from the previous one?
MazdaSpeed3 GT '07
AccessPort V2 Self tuned
 Old 09-19-2014, 08:17 AM   #10
The redsign was mainly to incorporate the mazda fix for the smoking turbo.
There is nothing wrong with the previous design or the silicone. The Silicone in both designs is the same.
The Following User Says NO Thank You to www.cp-e.com For This Un-useful Post:
Gr8Speed (09-19-2014)
 Old 09-19-2014, 08:29 AM   #11
Gr8Speed's Avatar
So you lied in the advertising materials?
The Following 3 Users Say Thank You to Gr8Speed For This Useful Post:
Easter Bunny (09-19-2014), Jtaylor (09-19-2014), kRs2PhO (09-21-2014)
 Old 09-19-2014, 11:15 AM   #12
shadesofgray19's Avatar
Posts: 794   (View Stats)
The advertising material is not noting the elements that have been redesigned, just the features of the TIP. It is just stating that the TIP is constructed of reinforced silicone for maximum durability, no lie there. The advertising would note that additional reinforcing was added for increased durability if that was the intent and part of the redesign.
Incorporating the Mazda smoking turbo fix is just changing the design to match the GenPu stock tip. To GenPu's this is not a fix and how it came. So it only makes sense to revise the TIP to match OEM setup. We know this is not a true fix for a smokey turbo.
The Following 5 Users Say Thank You to shadesofgray19 For This Useful Post:
CWP_MS3 (09-22-2014), daafisch (09-22-2014), Easter Bunny (09-19-2014), forcedinduktion (09-22-2014), Thepedigree13 (09-19-2014)
 Old 09-19-2014, 11:18 AM   #13
Gr8Speed's Avatar
I can see that is what the response will be. It is still a bit misleading. When you note something as "redesigned" and then have 3 bullet points after, deduction would say they would explain the redesign.
shadesofgray19 (09-19-2014)
 Old 09-20-2014, 01:45 PM   #14
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I think Mazda redesigned the factory TIP and moved the PCV closer to the turbo. They can't redesign this completely and have a vacuum pump, so they're using the turbo as a vacuum pump.
So yes, with the redesigned TIP there are less chances for your turbo to start smoking. The oil/gas vapors will be sucked into the engine faster and will not clog on the turbo upsetting its balance which later results in failed seals or even failed shaft.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Yousuf (09-22-2014)
 Old 09-22-2014, 05:01 AM   #15
Yousuf's Avatar
Posts: 1,398   (View Stats)
Groans: 128
hows the scene in romania?
Mod-bug's back...
The Following 2 Users Say Thank You to Yousuf For This Useful Post:
Mauro_Penguin (09-23-2014), mituc (09-22-2014)
 Old 09-22-2014, 07:37 AM   #16
mituc's Avatar
Groans: 111
Pretty much like everywhere else, we like to kill everybody in the parliament/government and the people who are running their business on masses cash and helped by the other thieves in the parliament/government/administration, but we will give them our vote anyway at the next election just to have somebody else to blame and to think about killing... It's just the number of figures in our salaries that differ from the "so called" better places to live.
Mauro_Penguin and Yousuf like this.
The Following 3 Users Say Thank You to mituc For This Useful Post:
Mauro_Penguin (09-23-2014), TMOtester (09-25-2014), Yousuf (09-22-2014)
 Old 10-10-2014, 12:55 PM   #17
darkstar5440's Avatar
Posts: 477   (View Stats)
CPE makes all these big power mods and it still boggles me how the largest intake they make is 3.25".
OMWTFYB
 Old 10-10-2014, 12:59 PM   #18
mituc's Avatar
Groans: 111
Did you manage to max the MAF on one of those?
darkstar5440 (10-10-2014)
 Old 10-10-2014, 01:00 PM   #19
I did and I had to buy a HTP
OMWTFYB
Product Release! CorkSport Redesigned Turbo Inlet Pipe CorkSport CorkSport 8 02-13-2012 02:57 PM
Page generated in 0.39658 seconds with 31 queries
