  • 1 Post By 08.5MS3
 Old 11-10-2011, 07:21 PM   #1
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Default CP-E Stage 2 motor mount still rubber?
https://www.cp-e.com/products/featur...e-engine-mount
Kinda cool, but why still using rubber instead of longer lasting urethane?
The Following 2 Users Say Thank You to breakfstincluded For This Useful Post:
ak_spray (02-06-2012), skeeter149 (11-10-2011)
 Old 11-10-2011, 07:28 PM   #2
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
gotta see that installed cant wrap my head around it. i get the concept but wonder if it works or will fail.
 Old 11-10-2011, 07:31 PM   #3
At least it looks shiny lol, I'd like to see what JBR thinks of this design...
lol someone try the stage 2 half of this with JBR RMM
Yeah I had to look at the JBR RMM installation guide to see what that new part is.
 Old 11-10-2011, 07:35 PM   #4
Jake_MS3's Avatar
Posts: 859   (View Stats)
Jake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the world
Better question is why is this $198. I can understand the cost of machining and aluminum, but damn, still seems a little steep
2009 Mazdaspeed 3
Jake_MS3 is offline   Reply With Quote
The Following User Says Thank You to Jake_MS3 For This Useful Post:
AZSPEED3 (11-10-2011)
 Old 11-10-2011, 07:38 PM   #5
skeeter149's Avatar
Groans: 91
extra shiny brackets mean extra shiny moneys i guess with them
 Old 11-10-2011, 07:40 PM   #6
Jake_MS3's Avatar
Shiny makes racecar?
2009 Mazdaspeed 3
 Old 11-10-2011, 07:40 PM   #7
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
They include their RMM. The other part is that triangular mount that bolts to the transmission. Looks as though they upgraded the rubber within that piece as well. Interesting, would like to see a review, but that is probably not going to happen.
Monotonous ONE likes this.
The Following 2 Users Say Thank You to 08.5MS3 For This Useful Post:
jeymz (11-28-2011), Monotonous ONE (11-10-2011)
 Old 11-10-2011, 07:42 PM   #8
From the other pics it looks like there's only a duro rubber piece on that triangle part now, and the usual RMM inner rubber part is solid. Th description says something about reducing movement from L-R U-D to just up and down with the new design
 Old 11-10-2011, 07:55 PM   #9
Jake_MS3's Avatar
Are you sure it includes the RMM? If it did, wouldn't there be a spot to select which duro you wanted for the RMM? Another thing, if in fact it was a package price for $198, wouldn't you think they would have it sold separately so people who just want that part can buy.
2009 Mazdaspeed 3
 Old 11-10-2011, 07:59 PM   #10
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
This is fucking awesome. I really like this idea.
Pair it with a dogbone for ultrasex
The Following 2 Users Say Thank You to Monotonous ONE For This Useful Post:
08.5MS3 (11-11-2011), SSinstaller (11-10-2011)
 Old 11-10-2011, 09:17 PM   #11
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
I like this MUCH better than the oem setup...
They need to make this for the MS6.
 Old 11-10-2011, 09:30 PM   #12
bms3mtb's Avatar
Posts: 442   (View Stats)
bms3mtb is the leader of the worldbms3mtb is the leader of the worldbms3mtb is the leader of the worldbms3mtb is the leader of the worldbms3mtb is the leader of the worldbms3mtb is the leader of the worldbms3mtb is the leader of the worldbms3mtb is the leader of the worldbms3mtb is the leader of the worldbms3mtb is the leader of the worldbms3mtb is the leader of the world
Groaned at 21 Times in 9 Posts
Think I get it.
So this has a solid piece of metal where the rubber is on the "Stage 1" mount, hence no choice on Duro there.
Then it also replaces the 3bolt piece the Stage 1 mounts to with a new CP-e bracket that has the rubber there - thus the rubber piece is no vertical, instead of horizontal.
If that's the case - this is baller. May have to swing by to look at one first hand - think I may be selling a RMM haha.
2010 Black Mica
Stage 2 :: Going back to stock - Part out coming soon.
bms3mtb is offline   Reply With Quote
The Following 3 Users Say Thank You to bms3mtb For This Useful Post:
08.5MS3 (11-11-2011), Grumpyjap (11-11-2011), Jake_MS3 (11-10-2011)
 Old 11-10-2011, 09:36 PM   #13
Jake_MS3's Avatar
Originally Posted by bms3mtb View Post
Think I get it.
Ok so after reading your post and then looking at the picture a little harder I get it. I think you're right with there being no bushing on the RMM. Makes sense now.
Would like to see some pics of this installed and hear some reviews.
Sent from my iPhone 4 using Tapatalk
2009 Mazdaspeed 3
 Old 11-11-2011, 12:01 AM   #14
08.5MS3's Avatar
Groans: 89
I saw this yesterday with only 2 pictures being visible. I believe, as seen in the pictures, that @bms3mtb is correct, in that the RMM is now solid and the rubber bushing has moved to the triangular piece that attaches to the transmission.
I also think cp-e needs to edit their description. They switched the terms horizontal and vertical...stating that their RMM has a horizontal bushing and the new piece has a vertical bushing. Now, I know I passed Geometry, so I hope someone else recognizes/ed this.
 Old 11-11-2011, 04:57 AM   #15
Groans: 819
I like it but as long as you dont have to have their standard rmm section. That design is still fail no matter how you slice it.
The long bolt on my cpe rmm bent and made the mount almost impossible to install. A trz delrin would kick ass with this mount.
 Old 11-11-2011, 07:22 AM   #16
Grumpyjap's Avatar
Posts: 1,839   (View Stats)
Think I get it.
You hit the nail on the head.
I will post pictures of the install and a review shortly
The Following User Says Thank You to Grumpyjap For This Useful Post:
2008speed3 (11-11-2011)
 Old 11-11-2011, 10:17 AM   #17
Jake_MS3's Avatar
I guess $198 really isn't a bad price for this setup. Definitely interested in seeing how this performs. Hopefully as well as it looks.
2009 Mazdaspeed 3
 Old 11-11-2011, 10:43 AM   #18
JohnMS3's Avatar
Posts: 754   (View Stats)
JohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the world
is there an improvement in moving the bushing vertically? with stock mount the engine movement is also vertical because of the cutout in the bushing.
-John
| Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns |
JohnMS3 is offline   Reply With Quote
 Old 11-11-2011, 10:54 AM   #19
eppopipe's Avatar
Posts: 601   (View Stats)
eppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the world
Maybe ill get one of these to replace my cpe60 rmm.
Shoot me a pm with your price JP. Thanks.
2010 Blue Mazdaspeed3
CP-E Nano Intake - JBR 88D Trilogy - Cobb AP - Sure Shortcut - 20% tint - Blox 490g shift knob - Big stereo system (WIP) - Singer 400AMP alternator - Turbosmart dual port - KDM V2 FP Internals - 10k DDM HID's (lows) - 12k HID's (fogs) - UR CBE (no mufflers) - Vibrant Ultra Quiet resonator - CP-E TMIC - UR Resonated Test Pipe - Dano Perm Tune - Blockhead Dual Gauge Vent Pod (painted) - Aeroforce Interceptor x2 - 19 inch RonJon Inspyres
eppopipe is offline   Reply With Quote
 Old 11-11-2011, 03:12 PM   #20
fishin53's Avatar
Posts: 1,721   (View Stats)
fishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the world
Groans: 44
looks like a good idea but have fun paying out the ass for that
2010 Black Mica Speed3 SOLD
2005 Jeep Wrangler X Impact OrangeSOLD
2015 Subaru XV Crosstrek Tangerine Orange Pearl
fishin53 is offline   Reply With Quote
 Old 02-02-2012, 09:14 AM   #21
blakkat's Avatar
Posts: 572   (View Stats)
blakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the world
Has anyone tried this yet?
2011 black mica ms3.
Mods:
mounts- jbr 80duro rmm, jbr 80duro trans mount
engine- sure aeros,cs tip, forge v1 bpv, autotec internals,cnt catless dp, dizzy tuned
shift- sure shortcut, countershift, anchors
looks- ddm 6000k lows, 3000k fogs, rally armour mud flaps, cs led kit
blakkat is offline   Reply With Quote
 Old 02-04-2012, 12:10 PM   #22
ak_spray's Avatar
Posts: 552   (View Stats)
ak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the world
Here you go searched it for you,
http://www.mazdaspeedforum.org/forum/foru...r-mount-98167/
07 MS3 Sport
CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP
SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon)
JBR: RSB
Cobb: Accessport
Corksport: TMIC
CNT: Catted Downpipe
ak_spray is offline   Reply With Quote
The Following User Says Thank You to ak_spray For This Useful Post:
Nliiitend1 (02-04-2012)
Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's Dre 2010 MS3 - Engine, Transmission & Driveline 23 05-21-2016 08:47 AM
What motor mount should I get? Nataphen 2010 MS3 - Engine, Transmission & Driveline 56 06-10-2010 02:17 PM
is transmission mount the same as motor mount? spoonher MazdaSpeed 3 - Engine, Transmission & Driveline 10 08-26-2009 02:21 PM
weakest motor mount..? what mount takes a dump first? Lvis MazdaSpeed 3 - Engine, Transmission & Driveline 29 03-02-2009 11:39 PM
Page generated in 0.42657 seconds with 32 queries
