| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() | | #41 | ![]() |
![]() Join Date: Mar 2011 Location: Shawnee, Ks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,101
Groans: 48
Groaned at 49 Times in 30 Posts
| Not Ranked : 0 score
__________________ AP, Corksport SRI/TIP, MD OCC, Autotech internals, CPE stage 2 RMM |
| The Following 3 Users Say Thank You to Stingray69 For This Useful Post: |
![]() | | #42 | ![]() |
![]() ![]() Join Date: Dec 2011 Location: San Marcos, TX
Rep Power: 692 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,138
Groans: 38
I'm kind of hard on my car most of the time so with rough driving and launches I would say it needs replacing every 25k miles i guess? I really loved this product though and would recomend it any day. If i could get another one I would right now, but just invested in a few other cp-e products so cant afford it :/ just have to go easy on my car till i can replace it
__________________ 06 MS6 & 06 MS6 [SIGPIC][/SIGPIC] The beauty is the beast Daily driven | |
![]() | | #43 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
If the bushing isn't messed up, I don't understand how it could be considered "about gone now"...
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
| The Following 3 Users Say Thank You to Nliiitend1 For This Useful Post: |
![]() | | #44 | ![]() |
Groans: 38
All I know is when I first got it, it was stiff as hell and I liked it, now it feels like how it did before replacing it(well, not THAT bad, but close). And even still after replacing the two side mounts. Once I get under there when installing the cpe dp though I will take a closer look at it and see if there are any cracks in the bushing that I couldn't see w/o the car jacked up. If its not cracked and its just worn out would that still be warranty-able?
![]() | | #45 | ![]() |
| Not Ranked : 0 score It's not like the EPDM turns to jelly as it "wears." ![]() If the rubber is in good shape, then I imagine so is the mount. If you're really having as big of an issue as you say, I can only assume the bushing has been compromised. A compromised bushing falls under the warranty,
![]() | | #46 | ![]() |
Groans: 38
| Not Ranked : 0 score Ah well I don't know that much about the materials and all that. Ill try and inspect it closer today or tomorrow then. Thanks for that info man.
![]() | | #47 | ![]() |
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
| Not Ranked : 0 score Is the actual engine moving? Try and grab a buddy and have him rev the engine to see if it rocks at all. It should be minimal movement. Although the best way to test is under load, do you happen to have a gopro and a small flashlight you can secure under the hood while doing a pull or 2?
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe |
| The Following User Says Thank You to www.cp-e.com For This Useful Post: | Nliiitend1 (03-01-2013) |
![]() | | #48 | ![]() |
![]() Join Date: Oct 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,795
Groans: 89
| Not Ranked : 0 score I have all 3 cp-e mounts. While not an effective measurement, when I try and move the engine with my hands, the entire car moves. Same can be said on start-up and revving. |
![]() | | #49 | ![]() |
![]() Join Date: Jan 2012 Location: Seattle, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 858
| Not Ranked : 0 score Kinda changing the subject back to OP's install, deal. Red loctite is the way to go, but with all this mm swapping you guys have done esp. passenger & driver, any problems getting bolts loose/heat required? I wouldn't risk putting blue on but red has pissed me off in the past trying to get heat in tight spots...
__________________ NATOR-WA 'GOVAN' '07 Sunlight Silver Mica MS3 GT JBR SRI + TIP + 88a RMM + SSP + SSB + Giant red knob + Reverse lock-out guide Michelin Pilot Sport A/S 3 215/45 R18 | Damond OCC | ebay Catless TP Defi Red Racer 52mm boost gauge | Torque Pro Android App Dash Install ebay All white LED bulbs + Custom LED strip hatch lights | 15% Tint + 5% Visor Pending installs: JBR EGR Delete + TB TIG | Stealthbox w/ Kicker & amp | Ford magical tranny jizz ~ [SIGPIC][/SIGPIC] |
![]() | | #50 | ![]() |
![]() Join Date: Nov 2010 Location: Bear, DE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score Great write-up and review, definitely on the top of the list when the money starts becoming available. |
![]() | | #51 | ![]() |
![]() Join Date: May 2011 Location: Cleveland, OH
| Not Ranked : 0 score I was going to start a new thread but I will just post here. I just installed the stage 2 after my stage 1 bushing separated after 60k miles of abuse. I also have the other two CP-e mounts. The car feels even better than when my stage 1 was good. Exactly as the OP stated in his review. Kudos to CP-e for doing such a great job.
__________________ Hypertech Max Energy Tuner / ETS 3.25 TMIC PC'd Black / SpeedDaddy 3" Catless Downpipe / Cobb Catback Exhaust / Turbosmart BPV / CP-e Nano SRI w/ Pre-filter / CP-e TIP / CP-e Stg 2 Rear Mount / CP-e 65 Duro Passenger Mount / CP-e 65 Duro Transmission Mount / PTP HPFP Fuel Pump Internals / Toyo Injector Seals/ TWM Short Shifter / TWM Shifter Bushings / JBR Heavy Shift Knob / JBR Adjustable Short Shift Plate / JBR Intake Mani Insulating Gasket / JBR EGR Delete / NGK One Step Colder Plugs |
![]() | | #52 | ![]() |
![]() Join Date: Apr 2012 Location: Schwenksville, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 22
__________________ CWP 2012 MS3 JBR SRI/TIP // Cobb AP // Autotech internals // CP-E Stage 2 RMM // CS racepipe (still in box) | |
![]() | | #53 | ![]() |
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
LOL!! my girl knows not to complain... but we're not married... I'll have to make sure she knows that not complaining about my car is a term for getting married lol
Question though, I'm looking to hear what CPE has to say about the issue Nliiitend1 mentioned above - about the bushing retaining bolts working loose... Am I going to need to crawl under the car again and take the mount out to loktite it? ALSO - Your instructions need fixing... Page 2 ends at "start engine" and then goes right into the install on page 3. Big issue though, is what @nusihb encountered - no instruction on whether the larger size "bushing" goes down or up - you need to identify which way the horizontal mount goes. Also, various spelling issues...
__________________ ![]() [SIGPIC][/SIGPIC] Last edited by hnda etr; 04-15-2013 at 01:56 AM. | |||
![]() | | #54 | ![]() |
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe | |
![]() | | #55 | ![]() |
Groans: 90
Sent from my giant i317 Pocket Monster
__________________ ![]() [SIGPIC][/SIGPIC] | |
![]() | | #56 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score Red locktite & done.... hell, my front tow plate is red locktited on, haha.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
| The Following User Says Thank You to El_Diablo For This Useful Post: | CWP_MS3 (04-16-2013) |
![]() | | #57 | ![]() |
| Not Ranked : 0 score Will red give you any issues if you need to remove the mount? The package stated you need to heat the red to 500 degrees to break the bond
![]() | | #58 | ![]() |
![]() Join Date: Mar 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35
Groaned at 44 Times in 13 Posts
![]() | | #59 | ![]() |
Groans: 769
| Not Ranked : 0 score Red is recommended that you heat to remove for larger bolts but not entirely necessary. Personally, I’ve never had an issue removing anything with hand tools with red loctite but it holds great.
![]() | | #60 | ![]() |
Sent from my big-ass phone.
__________________ NATOR-WA 'GOVAN' '07 Sunlight Silver Mica MS3 GT JBR SRI + TIP + 88a RMM + SSP + SSB + Giant red knob + Reverse lock-out guide Michelin Pilot Sport A/S 3 215/45 R18 | Damond OCC | ebay Catless TP Defi Red Racer 52mm boost gauge | Torque Pro Android App Dash Install ebay All white LED bulbs + Custom LED strip hatch lights | 15% Tint + 5% Visor Pending installs: JBR EGR Delete + TB TIG | Stealthbox w/ Kicker & amp | Ford magical tranny jizz ~ [SIGPIC][/SIGPIC] | |
![]() | | #61 | ![]() |
![]() Join Date: Aug 2012 Location: Bellevue, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
| Not Ranked : 0 score I used blue and torqued down.... so far so good!
__________________ 2011 Black Mica MazdaSPEED3 // CS SRI // CS TIP // HKS SSQV-IV VTA w/ CP-E flange // CP-E FMIC // CP-E Triton CBE // CP-E Catted DP // CP-E HPFP // CP-E Stage 2 RMM // COBB AP With Lex Tunes // JBR SSP // JBR 88DM TMM //JBR 80DM PMM // JBR custom cylindrical shift knob // JBR SSB's // Rally Armor Mudflaps // ISC Coilovers and front end links // Denso ITV-22's // SPC Camber Arms // Michelin Pilot SuperSports // STRATIFIED LEX TUNED FTMFW Mustang Dyno Results: 301WHP 334WTQ on 35% E85 282WHP 325WTQ on 92oct |
![]() | | #62 | ![]() |
Groans: 90
| Not Ranked : 0 score Curious as to why no response from cpe about this issue... Sent from my giant i317 Pocket Monster
![]() | | #63 | ![]() |
| hidin in yo bushes ![]() Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6574 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
No they will not. Red is what is put on the bolts from the factory, and you will see it in the threads when you pull the bolts out to replace your RMM. Use red, but don't go cray with it. A little goes a long way.
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() | |
| The Following 4 Users Say Thank You to CWP_MS3 For This Useful Post: |
![]() | | #64 | ![]() |
You shouldn't have to remove the cover for the bushing. cp-e will only remove the cover if the bushing needs to be replaced.
| The Following 3 Users Say Thank You to www.cp-e.com For This Useful Post: |
![]() | | #65 | ![]() |
![]() Join Date: Nov 2011 Location: San Diego, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score I just received and mounted my CP-e Stage 2 RMM last night! I got the anodized black version, so I thought I'd post up some pics since OP posted pics of the silver colored one. When I first took it out of the box, I was (pleasantly) surprised at how meat-y and solid it was. Great craftsmanship, CP-e! There is a bluish-purple tint to it if you take a closer look. And here it is installed. I used red loctite on all 5 bolts, and torqued to 85 ft/lbs as stated on the mount itself. I had a little trouble bolting it on, but I had a friend hold the motor in place while I wedged the bolts back in place. The flash made the tint look really purple. Either way, looks nice! Initial vibes were pretty strong, but like others have said is only noticeable in first and reverse in the 1k - 1.5k rpm range. I tried a hard launch just to test it out, no wheel hop! Car feels firmer to the ground, and I feel like more power is connecting to the wheels. All in all, very satisfied so far, and I'm excited to break it in!
__________________ 2012 Pearl White Mazdaspeed 3 Current Mods: Cobb SRI | Cobb TIP | CP-e Catted DP | Cobb AP | RichTuned | CP-e Stage 2 RMM | Autotech HPFP Internals | Denso ITV22 Future Mods: MD OCC | CP-e CBE | JBR RSB | Cobb XLE BPV | CP-e TMIC 2004 Yamaha Blue YZF-R6 |
| The Following 7 Users Say Thank You to HKchucksta For This Useful Post: | 08.5MS3 (04-16-2013), 3starmagnum (04-17-2013), chaser27 (08-07-2013), CWP_MS3 (04-18-2013), El_Diablo (04-17-2013), Nliiitend1 (04-16-2013), www.cp-e.com (04-16-2013) |
![]() | | #66 | ![]() |
Crappatalking on my big-ass phone.
| The Following User Says Thank You to SeeMeGovan For This Useful Post: | HKchucksta (04-17-2013) |
![]() | | #67 | ![]() |
Groans: 89
| Not Ranked : 0 score You fuckers need to drive in the snow; with salt, brine, and all kinds of other shit on the roads. Your shit it too clean. |
| The Following 2 Users Say Thank You to 08.5MS3 For This Useful Post: | El_Diablo (04-17-2013), SeeMeGovan (04-16-2013) |
![]() | | #68 | ![]() |
![]() Join Date: Apr 2013 Location: Springville, UT
Rep Power: 0 ![]() Thanks: 0
![]() | | #69 | ![]() |
Groans: 90
__________________ ![]() [SIGPIC][/SIGPIC] Last edited by hnda etr; 04-16-2013 at 06:10 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to hnda etr For This Useful Post: | himurax13 (07-08-2013) |
![]() | | #70 | ![]() |
| Not Ranked : 0 score @Grumpyjap I've felt the 88duro dogbone - it's too harsh for me - but I also plan on stopping at ~300hp/340tq. At what point during your build would you say you outgrew the inserts? Thanks!
![]() | | #71 | ![]() |
| Not Ranked : 0 score I'm sitting at around 295/320 and have stage 2 rear and 65 duro sides. I could never go back. Do yourself a favor and get all three.
![]() | | #72 | ![]() |
![]() Join Date: Dec 2012 Location: Stockton, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score I just installed Corksports Passenger Side Motor Mount and their Transmission Mount Insert. AMAZING!! No engine movement at all. The NVH is barely noticeable, it's not any louder than than a turbo back exhaust system. The benefits of these products from CS way out way any NVH!! Two must have products!!! I will post the before and after video on my page if I can figure out how hahaha |
| The Following User Says Thank You to KRASHFOX For This Useful Post: | JgamB (04-17-2013) |
![]() | | #73 | ![]() |
Groans: 89
| The Following 5 Users Say Thank You to 08.5MS3 For This Useful Post: | chaser27 (08-07-2013), CWP_MS3 (04-18-2013), El_Diablo (04-17-2013), Nliiitend1 (04-17-2013), SeeMeGovan (04-17-2013) |
![]() | | #74 | ![]() |
![]() Join Date: Aug 2008 Location: Orange County NY
Rep Power: 2267 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,484
The cp-e mounts reduce the vibrations and at the same time do not sacrifice the performance of having an upgraded mount. People that have sat in my car, which has all 3 mounts, barely notice the vibrations even with the a/c on. You do have to break them in though, as with all mounts.
__________________ cp-e-FMIC/cp-e-HPFP/cp-e-Xcel Nano Intake/cp-e-Nviscid TIP/cp-e-BOV Kit/cp-e-Stage2 RMM/cp-e-xFlex Passanger & Driver Motor Mounts/cp-e-catted DP/cp-e-Nexus cat-back exhaust/cp-e-tow plate/cp-e-Tripple Gauge Pod/Rally Armor-Mud Flaps/TWM-Base Bushings/TWM-Shift Weight/Street Unit-Washer Fluid Cap/Street Unit-Oil Cap/Konig-Milligram/Corksport-Rear Sway Bar/Corksport-Aluminum Skidplate/StopTech-Sport Brake Kit/GTSpec-rear v-brace/GTSpec-link reinforecement panel/GTSpec-rear lower tie bar/GTSpec-4 points ladder brace/Lamin-x-Headlight film/Lamin-x-Taillight film/TWM-Full replacement shifter/TWM-Big Type R knob & Hybrid Knob/TWM-Shift boot/3M-1080 Matte Dark Grey Wrap/3M-1080 Brushed Steel Wrap/Tial-BPV/DG Motorsports-CF front lip/DG Motorsports-CF Rear wing extention/Sonic Tuning-Coilovers/COBB Tuning-AccessPort/ | |
| The Following User Says Thank You to Grumpyjap For This Useful Post: | JgamB (04-17-2013) |
![]() | | #75 | ![]() |
Groans: 122
![]() | | #76 | ![]() |
Groans: 769
| Not Ranked : 0 score After around 8-9k miles & about 5-6 months on the mount the vibes are pretty much gone unless you lug the engine down. Awesome mount and well worth the money.
| The Following 4 Users Say Thank You to El_Diablo For This Useful Post: |
![]() | | #77 | ![]() |
| Not Ranked : 0 score So I finally got around to installing my CP-E stage two mount and I gotta say, I'm pretty pissed off.... Why might you ask? Because the car should have come from the factory this way!!! After installing it I drove around a bit with my dad in the car and even he, as a passenger, could tell how much more solid the shifts were. CP-E, this is one hell of a mount. So far it is the best mod I've done!!!
| The Following 4 Users Say Thank You to tc0308 For This Useful Post: |
![]() | | #78 | ![]() |
| Not Ranked : 0 score Can the stage 2 mount can cause additional "tranny" whine? This morning while driving to work, and also on the way home, I noticed a whine between 2500 RPM down to 2000 RPM. It seems to be most apparent in 3rd gear and a little in 2nd. The sound isn't overly obnoxious, but just something I noticed. I've been driving w/ no radio just to listen to the engine and that is when I can hear it. IF it is tranny whine I am not worried; I just want to know what it is before I start blasting the radio again .
![]() | | #79 | ![]() |
| Not Ranked : 0 score We have not heard anyone with this issue. It wasn;t apparent on our test vehicles either. Do you have any of the other motor mounts installed?
![]() | | #80 | ![]() |
Groans: 90
| Not Ranked : 0 score The mounts don't "cause" more whine, but stiffer mounts can transmit more existing noise into the cabin... I have this Mount and both Street unit side mounts, in addition to the PTP kicker Mount, lightened Flywheel and balance Shaft deleted... My car sounds like a diesel truck inside the cabin.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f330/cp-e-stage-2-rmm-review-walkthrough-107792/ | ||||
| cp-e stage 2 RMM Review/walkthrough - Mazdaspeed Forums | This thread | Refback | 03-23-2015 12:58 PM | |
| cp-e stage 2 RMM Review/walkthrough - Mazdaspeed Forums | This thread | Refback | 03-23-2015 10:57 AM | |
| "Suspension help." discussion on Evo Community | This thread | Refback | 05-01-2012 07:59 AM | |
| EM Stage III+ Clutch Review | Tomas | MazdaSpeed 3 - Engine, Transmission & Driveline | 44 | 09-16-2012 03:39 PM |
| Jbarone SSP Stage 2 Plus Knob install and review | asall667 | MazdaSpeed 3 - Engine, Transmission & Driveline | 11 | 01-25-2011 09:50 AM |
| VIDEO: Walkthrough of 2011 Chevy Volt interior | Haltech | Automotive News | 0 | 09-16-2008 12:30 PM |
