 Old 08-10-2017, 11:02 AM   #1
Say Chi Sin Lo's Avatar
Posts: 872   (View Stats)
Had a 2x4 lodged near the side jack point of the car, need CP-E complaint line, and ask for a reimbursement in the form of their Stage 2 RMM.
Thanks!
2009 Mazdaspeed 3 GT
CWP
Mazdaspeed Coilovers // BMW E46 M3 Front Endlinks (works perfectly) // SPC Rear Camber Arms // Mazdaspeed CAI // CP-E Turbo Inlet // TurboXS BPV // CP-E 60 Duro RMM // Damond PMM // TWM Short Shifter // JBR Shifter Bushings // JBR Heavy Shift Knob
I have an Autotech HPFP laying around, just too lazy to install it.
The Following User Says Thank You to Say Chi Sin Lo For This Useful Post:
dagrimey1 (11-03-2017)
 Old 08-11-2017, 08:35 AM   #2
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Groaned at 18 Times in 8 Posts
Thanks!
10/10 would compensate you with the stage 2 rmm and pmm/tmm
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
How optimizing aerodynamics significantly increases EV range Haltech Automotive News 0 02-20-2017 12:10 PM
Leaking something out of the transmission/transfer case I think. scnewt MazdaSpeed 6 - Engine, Transmission & Driveline 25 03-19-2013 06:46 AM
Transmission, Transfer Case, Rear Diff Oil arnobg MazdaSpeed 3 - Engine, Transmission & Driveline 1 08-30-2012 10:10 AM
Page generated in 0.23217 seconds with 23 queries
