 Old 06-03-2013, 02:41 PM   #1
rnbMS3's Avatar
Posts: 25   (View Stats)
rnbMS3 has much to be proud ofrnbMS3 has much to be proud ofrnbMS3 has much to be proud ofrnbMS3 has much to be proud ofrnbMS3 has much to be proud ofrnbMS3 has much to be proud ofrnbMS3 has much to be proud ofrnbMS3 has much to be proud ofrnbMS3 has much to be proud of
Default CP-E TMIC just installed, couple suggestions
I don't normally post anything on these forums, because search, but I figured I should for this instance. I just installed your TMIC and it fits great, looks great, and woke the car up a bit and is there in preparation for some toonage. I'm not asking a question. There were two things, though, that I noticed and wanted to forward on to you guys.
(By the way, this is for a genpu, so imagine the appropriate shroud for the first item.)
1. Your emblem location. I'm not sure if this applies to you Juan guys, but this could be moved for the Pu's so we can see it. It's not a big deal, just figured if we are spending 400 quid on a piece, it's not bad to show the name (and the emblem is pretty nice looking, not a crap sticker). With the shroud mounted, you can not see the emblem. Just moving it up a couple inches would remedy this. Or anywhere else along the uppermost part of the front end tank. Maybe it's the point to be hidden, some people like that, but I wouldn't mind seeing it. (marked with pretty colors to portray what I'm thinking)
2. Angled bracket to weld clearance. There is one angled bracket on the front end tank that I had some issues with. A corner of the bracket overlapped the weld beads and would not sit flat on the tank. I could not find that other people were having this problem so I wonder if this is isolated, but probably not since I'd assume they are all the same ICs. Maybe others didn't notice or just did not care. I wanted the thing sitting flush, so I hacked the corner off (about 1/4 - 3/8) at an angle. This is even after the bracket was moved all the way to one side of the slotted holes. In no way do I see this deteriorating structural integrity of this bracket or the IC. If you guys never knew about this and wanted to alter the design, I'd gladly throw a new bracket on to test. Otherwise, I don't really care and it will never be seen or hurt anything as it sits currently. (sorry for the pic quality, my cell camera is on its way out)
Again, none of this bothers me as is. Just wanted to forward some thought that may help somebody down the line. If both issues are already known, then don't mind me, just throw me into the pot of reported misc.
2010 PU Currently being FREEKED by Finkle <> Autotech HPFP <> Cobb AP <> Cobb SRI <> James Barone Racing TIP & BPH <> Custom Performance Engineering TMIC <> NGK Iridium Step Colder <> GoFastBits Respons BO/BPV <> Matt Damond OCC, check valve - VTA <> James Barone Racing RSB <> James Barone Racing 88a RMM <> Koni Yellows <> Swift Sport Spec-R Springs <> Ultimate Racing CBE <> eBay super duper performance ultimate definitely American made TP <> Ford Unicorn Juice <> Shell Rotella T6 <> Motegi MR117's <> Continental Extreme Contact DW <> Flying Spaghetti Monster Mod
rnbMS3 is offline   Reply With Quote
 Old 06-04-2013, 07:16 AM   #2
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Thanks for the suggestions. Let us know how you like it when you get some miles on it
Website: www.cp-e.com
ETS TMIC Installed crbalch MazdaSpeed 6 - Engine, Transmission & Driveline 28 08-10-2011 02:53 PM
Bilsteins and H&Rs installed...A couple questions whitespeed MazdaSpeed 3/6 - Suspension & Brakes 6 03-26-2011 02:17 AM
Suggestions for replacement TMIC? ihadacivicsi MazdaSpeed 3/6 - Turbo Induction 83 01-16-2010 12:14 PM
TMIC suggestions speedms6 MazdaSpeed 3/6 - Turbo Induction 25 11-28-2009 12:01 PM
A couple questions about the stock TMIC and its cover Smokehouse Mazdaspeed3/6 General Discussion 10 02-05-2009 04:16 PM
Page generated in 0.23513 seconds with 21 queries
