Closed Thread
 Old 11-05-2008, 05:37 PM   #1
copperkid's Avatar
Posts: 22   (View Stats)
copperkid is just really nicecopperkid is just really nicecopperkid is just really nicecopperkid is just really nicecopperkid is just really nice
Default Cp-e Xcel Nano install and review w/ pics n vids
I picked up an Xcel Nano today from Cp-e. As always the Cp-e staff was great and I was in and out with the new intake.
What’s in the box:
Initial impressions 10/10
The quality is top notch. The MAF housing was nicely machined and constructed. I believe the aFe wet filter is the same one found on Cp-e's CAI. All the hardware and filter were well packaged and organized. The Nano includes fully illustrated step by step color instructions.
Installation 8/10
Installation was straight forward and relatively easy with the provided instructions.
The filters frame support/mount is better designed than Cobb's. It's not hard to install the small machined piece over the battery tray studs. The thick rubber mount looks like it will allow the intake to freely move with the engine and not put pressure on the battery bracket.
The trickiest part was adjusting and installing the vacuum hose to the MAF housing. The fittings on the vacuum hose do rotate, but since the hose doesn’t bend much it puts some minimal pressure on the whole intake. It did take some adjusting of the silicon elbow and MAF hosing to get everything tight and straight.
The final step involves installing the air filter.
Performance 10/10
The car definately feels faster! The engine revs up much faster. I have a friend with a Cobb SRI and I would say the performance is comparable. You can definitely hear the turbo spool up and the BOV with this intake. I would say the intake noise is mild to moderately loud.
Things I would improve:
The machined MAF housing or the filter need to have a built in stop. It’s too easy to slide the filter over the MAF housing too far. This would affect the performance of the filters molded velocity stack.
I would slightly adjust the position of the vacuum attachment point that extends from the MAF housing to reduce the pressure the vacuum hose puts on the whole filter.
Overall Rating 9/10
I would highly recommend this kit to anyone looking for an SRI for their MS3.
Coming soon, full review on the Racing Beat CBE for the Mazdaspeed3!
2008 Mazdaspeed3 Sunlight Silver
TWM short shifter & bushings - HKS SSQV - CorkSport MMI - Dashhawk - Racing Beat CBE
copperkid is offline
The Following 8 Users Say Thank You to copperkid For This Useful Post:
Cool Whip (11-06-2008), Dash08 (11-05-2008), labikesrcool (11-05-2008), Lex (11-05-2008), PaPaSpeed (11-05-2008), phailerider (11-07-2008), skeeter149 (11-05-2008), speedster3_08.5 (11-10-2008)
 Old 11-05-2008, 05:46 PM   #2
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
I just adjusted the PCV piping a little so it reduced the stress on the intake. its stiff but not impossible to adjust.
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline
 Old 11-05-2008, 05:49 PM   #3
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Looks awesome!!
I should be getting mine soon!
this forum serves 2 purposes
Dash08 is offline
 Old 11-05-2008, 05:53 PM   #4
Eazy's Avatar
Posts: 1,539   (View Stats)
Eazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the world
Groaned at 32 Times in 14 Posts
So am I seeing this right?.... CPE used the bracket that keeps breaking with the Cobb SRIs? WTF?!
Eazy is offline
 Old 11-05-2008, 05:53 PM   #5
SgtP's Avatar
Groans: 106
just realized you beat me posting by three minutes lol. i should have installed it yesterday... lol
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 11-05-2008, 06:30 PM   #6
jlocurto's Avatar
Posts: 388   (View Stats)
jlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the world
does that mean that they are offering it in different colors? or just a possibility in the future?
08.5 BM MS3 GT; CPE Nano; Forge BPV; CPE Catless TBE; CPE 60 RMM: ITV22; Cobb AP Stage 2 +SF 93; PTP HPFP; CPE Front Mount Intercooler
jlocurto is offline
 Old 11-07-2008, 11:40 AM   #7
speedster3_08.5's Avatar
Posts: 11   (View Stats)
speedster3_08.5 is an unknown quantity at this point
+1, anyone know about this?
speedster3_08.5 is offline
 Old 11-07-2008, 11:52 AM   #8
desperado callado's Avatar
Posts: 170   (View Stats)
desperado callado is a splendid one to beholddesperado callado is a splendid one to beholddesperado callado is a splendid one to beholddesperado callado is a splendid one to beholddesperado callado is a splendid one to beholddesperado callado is a splendid one to behold
Only option is polished for now. After awhile SU started offering the CAI in different colors, so maybe they'll do that for the Nano also.
The mass of men lead lives of quiet desperation. What is called resignation is actually a lack of boost.
Mods: Defi Blue Racer Boost Gauge, 2nd Fiamm Horn (Low Tone) SU Mid-Pipe. Cobb Adjustable Shifter (now "functioning as intended" with 20mm allen bolts and locking nuts), CP-e Nano SRI. Sometime in the not-too-distant future: Airbox (?) and SU/ETS 3.25 TMIC
desperado callado is offline
 Old 11-07-2008, 01:53 PM   #9
chowhoundb's Avatar
Posts: 15   (View Stats)
chowhoundb is an unknown quantity at this point
Sweet, just got word from SU, my nano has been shipped.
chowhoundb is offline
 Old 11-07-2008, 02:53 PM   #10
DeadWayt's Avatar
Posts: 186   (View Stats)
DeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the world
And I would assume it would be the same three powdercoat finishes they offer for the CAI if they decide to go that route.
'08.5 MS3 GT -- Metropolitan Grey
www.speedsportlife.com
DeadWayt is offline
 Old 11-05-2008, 09:35 PM   #11
Team Überfrazn
labikesrcool's Avatar
Posts: 782   (View Stats)
labikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the world
Which would you say is louder? Your friend's Cobb or your CP-E? Or perhaps there isn't a difference.
"My car won't start!"
"Well, maybe there's a killer after you."-Mitch Hedberg
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming.
- Mitch Hedberg
labikesrcool is offline
 Old 11-05-2008, 09:49 PM   #12
Besides actually being able to buy this and not being on back order, is there any advantage to the CPE vs the Cobb SRI? I know the CPE has a dry flow filter, but anything different between the two besides that?
Thanks
 Old 11-05-2008, 10:03 PM   #13
copperkid's Avatar
If you purchase the filter from an online vendor you'll receive a wet filter. You can choose wet or dry if you order direct from Cp-e.
The Nano incorporates a rubber grommet that will allow the filter to move with the engine and not put stress on the battery bracket. This bracket has been breaking with some Cobb Sri's.
 Old 11-05-2008, 11:21 PM   #14
Silver Ecstasy's Avatar
Posts: 2,450   (View Stats)
Silver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the world
Groaned at 81 Times in 33 Posts
So I haven't taken my stock air box off before, and I don't recall seeing all that extra piping. What's that piping for between the recirc line (i'm assuming that's what it is), and the maf housing? The one with the two cylinders in the piping?
Mike
2008.5 CWP Mazda CX-7 Sport FWD - hers
2008.5 CWP Mazdaspeed 3 GT - traded
2011 LSM Mazdaspeed 3 Sport w/tech pkg - sold
Silver Ecstasy is offline
 Old 11-06-2008, 07:58 AM   #15
copperkid's Avatar
The one bellow the recirc tube is a radiator hose. I'm not sure about the one with the two cylinders.
You have nothing to worry about.
 Old 11-06-2008, 08:55 AM   #16
I'm a caveman
gtlaw's Avatar
Posts: 758   (View Stats)
gtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the world
Groans: 68
Groaned at 22 Times in 16 Posts
how does this sound on decelleration any drone? BTW sounds great in the video
2015 MUSTANG GTPP
gtlaw is offline
 Old 11-06-2008, 10:51 AM   #17
chowhoundb's Avatar
GT,
If by some stroke of luck mine arrives before sunday, we can take it for a spin and you can check it out first hand.
 Old 11-06-2008, 11:41 AM   #18
I'm a caveman
gtlaw's Avatar
Groans: 68
Originally Posted by chowhoundb View Post
GT,
that would rule
2015 MUSTANG GTPP
gtlaw is offline
 Old 11-07-2008, 06:05 AM   #19
MS6_Auburn_Fan's Avatar
Posts: 481   (View Stats)
How does the sound compare to a CAI? A lot louder, some what louder, a little louder?
MS6_Auburn_Fan is offline
 Old 11-07-2008, 06:07 AM   #20
SgtP's Avatar
Groans: 106
its louder than my wifes CAI on the cx7.
13.2@111
Sponsored By: CP-E
SgtP is offline
Closed Thread
How to MS3 Catch Can Install with tons of pics. JimmyMac MazdaSpeed 3 - How-To's 131 01-29-2018 03:53 AM
CP-E Xcel Cold Air Intakes For MS3 In stock! kevin@gripgarage.com Mazdaspeed3/6 General Discussion 7 01-08-2009 05:57 PM
twm sts review with pics dread MazdaSpeed 3 - Engine, Transmission & Driveline 16 08-30-2008 01:46 AM
Page generated in 0.43657 seconds with 32 queries
