Closed Thread
 Old 05-26-2009, 02:58 PM   #1
Speedie6's Avatar
Posts: 1,838   (View Stats)
Default CPE catted DP question
I have a CPE catted DP on my MS6. I have a couple of simple questions, hope someone can answer.
First, my installer claims the "cat" is a dummy, it isn't actually a cat. I'm pretty sure he's wrong on this. But, I thought I'd bring it up. He says he dropped a socket in one end of the DP by accident, and, it just fell out the other end. That tells him it is just a straight pipe and the hump that is supposed to be the cat is a dummy. I never had any CEL with it, so, I'm sure he's wrong. But, I thought I'd ask for comments.
Second question, I got the ProSport widband A/F gauge. The instructions say that if you have a turbo or high EGTs, then you should mount the sensor 36" from the engine exhaust. On the other hand, it also says it should be mounted before your cat. Well, the cat isn't 36" away. My shop, since they concluded the cat was a dummy, welded the bung at the end of the DP, past the flex section. So, I'm wondering about that as well.
Thanks.
Speedie6 is offline
 Old 05-26-2009, 03:11 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
The CP-E DP does have a real cat in it.
The wideband O2 should have been mounted right before the cat in the DP, if it overheats you'll need to make or buy a heatshield/spacer for it..(Innovate Motor Sports On-Line Store)
Your wideband will read leaner than the actual AFR because it is now mounted behind the cat...
SSinstaller is offline
 Old 05-26-2009, 03:17 PM   #3
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groans: 31
Groaned at 86 Times in 65 Posts
I have heard a few things you've said that your shop has "said". You sure you trust them man? It doesnt sound like they have the most performance oriented education or skills.
-JEWBERT
jhershorin is offline
 Old 05-26-2009, 04:20 PM   #4
Speedie6's Avatar
I was pretty sure of that. But, at least regular cats you can't usually drop a bolt through them. Obviously I know that performance cats are designed for less backpressure, but, I didn't think it would be so open to let a bolt fall through.
Thanks!
Speedie6 is offline
 Old 05-26-2009, 04:24 PM   #5
Speedie6's Avatar
Well, they were right about the hole sizes in the spacer. They haven't been right about everything, but, overall, I've been happy with their work. Though, the shop went out of business. The landowner wanted to sell the land it was on. The main people of the shop are thinking about opening their own new shop. The shop manager and lead tech are both RX-7 fans and both have modded RX-7's.
Speedie6 is offline
 Old 05-26-2009, 04:43 PM   #6
phailerider's Avatar
Posts: 4,639   (View Stats)
who did you buy this "catted" dp from?
phailerider is offline
 Old 05-26-2009, 04:50 PM   #7
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
the cp-e downpipe is definately not straight through at the cat...when i got mine you can somewhat look through the mouth of the downpipe and tell that it isn't straight thru so i think your shop is blowing smoke up your ass, especially with some of the other stuff you had posted they said.
bova is offline
The Following User Says Thank You to bova For This Useful Post:
Fobio (05-26-2009)
 Old 05-26-2009, 05:21 PM   #8
Speedie6's Avatar
I got it from SU. It came with all the CPE papers and logo on the pipe. So, I'm pretty sure it is legit. So, I guess I must conclude that my shop gave me bad info on this. Thanks for the responses.
Speedie6 is offline
 Old 05-28-2009, 08:16 PM   #9
steven88's Avatar
Posts: 773   (View Stats)
steven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the world
Groaned at 9 Times in 5 Posts
i have a cp-e catted for my ms3
i am sure my cat is legit....i can small my exhaust and it does NOT smell like a catless setup
steven88 is offline
 Old 05-31-2009, 10:43 AM   #10
Speedn3's Avatar
Posts: 642   (View Stats)
Speedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond repute
Maybe it is catless with just the flexpipe. A bolt could fall straight through the catless set-up.
Can you verify from the outside it has both the flex joint and a small hf cat?
http://www.cp-e.com/imgs/SP3OffRoad1_Big.jpg
Speedn3 is offline
 Old 05-31-2009, 02:37 PM   #11
slo4now's Avatar
Posts: 382   (View Stats)
slo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond repute
Groaned at 24 Times in 6 Posts
That is exactly what i was thinking.
slo4now is offline
 Old 05-31-2009, 07:20 PM   #12
Speedie6's Avatar
My pipe has both the flex and a CAT. I am not pretty certain that my installer was mistaken or whatever. I don't know. But, I now feel confident I have a CAT. Thanks for responding everybody.
Speedie6 is offline
Closed Thread
catted DP or cattless DP? black-speed3-gt Miata - Engine, Transmission, Driveline 1 04-12-2009 11:22 PM
catless or catted cpe dp? asiandude74 MazdaSpeed 3/6 - Turbo Induction 16 01-02-2009 11:58 AM
cp-e catted downpipe bova MazdaSpeed 6 - Engine, Transmission & Driveline 10 12-01-2008 11:16 PM
Page generated in 0.31794 seconds with 27 queries
