Closed Thread
 Old 02-11-2009, 09:34 PM   #1
Ftaz1's Avatar
Posts: 111   (View Stats)
Ftaz1 is a splendid one to beholdFtaz1 is a splendid one to beholdFtaz1 is a splendid one to beholdFtaz1 is a splendid one to beholdFtaz1 is a splendid one to beholdFtaz1 is a splendid one to beholdFtaz1 is a splendid one to behold
Default CPE Catted downpipe SPL
I am about to install the CPE catted DP
I have the MSCAI and HKS-BOV already installed.
Without catback exhaust....how different will the car sound after the install of the DP?
Ftaz1 is offline
 Old 02-12-2009, 07:33 AM   #2
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
Not very different. It is slightly louder and angrier sounding but outside the car most people will not notice a difference.
The best advice I can give you is... install it and find out! Its a good upgrade dude, I promise.
2006 Lotus Elise: Toy car
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
subparpunk03 is offline
 Old 02-12-2009, 07:39 AM   #3
Ftaz1's Avatar
Thanks dude...but there is no question that I am installing the DP. Just that there are some fussy old neighbours around my house, so I wanted to know from now if I had to start getting on their good sides...maybe start bringing them muffins or something from now.
But the DP has been paid for and is in flight somewhere, should be installed my Monday!
Ftaz1 is offline
 Old 02-12-2009, 07:41 AM   #4
Ftaz1's Avatar
So I have heard conflicting opinions on this topic, maybe I will ask it again here and see:
Seems that the sound is the major advantage of a catback, are there any major HP increases that would justify getting a catback with the Catted DP?
Ftaz1 is offline
 Old 02-12-2009, 08:14 AM   #5
phailerider's Avatar
Posts: 4,639   (View Stats)
no. not for what you intend with the car.
phailerider is offline
 Old 02-12-2009, 08:21 AM   #6
Ftaz1's Avatar
So Randy.... what's your take on difference in sound after the DP install??
( I know I can wait a couple days to find out.... But I wanna know now!)
Ftaz1 is offline
 Old 02-12-2009, 09:13 AM   #7
how the fuck am i supposed to know...lol. my car is the loudest ms3 in north america I sell this shit all over the country but none of the local guys have that setup.
id say it wont be a hell of alot louder unless its wide open throttle. Then it will be. But still not bad. the catback is where the sound characteristics usually come from.
Ive got a vibrant ultra quiet resonator i'll probably throw on there eventually.
 Old 02-12-2009, 01:24 PM   #8
timv's Avatar
Posts: 179   (View Stats)
timv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud of
I have just installed the cpe catted downpipe with my stock cat back about 2 weeks ago now, thanks Randy!!!!
It is a bit louder and deeper, meaner sounding I would say. I like the sound. At certain RPM's I feel a bit more vibration in the car so definately deeper and louder.
I'm not sure if it is loud enough to upset neighbors but I do try and keep it quiet when I get home from work at 11:30pm because it seems like it could.
The cp-e down pipe moves the stock exhaust forward about an inch so make sure and check your heat shields towards the back of the car for rubbing. I had to bend the shields out of the way which only took about a minute.
timv is offline
 Old 02-12-2009, 01:30 PM   #9
Ftaz1's Avatar
Thanks Timz.
What other mods do you have?
Besides the sound... What difference does the DP make?
Ftaz1 is offline
 Old 02-13-2009, 07:23 PM   #10
timv's Avatar
Thanks Timz.
I'm mostly fully bolted now:
CP-E CAI black, CP-E FMIC black, HKS SSQV CP-E black version, PG CDFP internals, CP-E Catted Down pipe, HKS step colder plugs, Street Unit rear MM and shifter bushings, CP-E Stand Back Ver 2 with PNP, rignt now a RPMC turbo inlet but waiting for the CP-E one to replace it with, I just got a set of Eibach springs to install monday......
I guess you could say I like the CP-E stuff. I started with a few Cobb items but decided to try a few other things and was more impressed by the quality and support I received for the CP-E items then the Cobb.... Just my personal experience and opinion.
I am going to dyno with the Arizona Mazda Club on the 28th so i'll have some #'s then. My tune is @ 18psi right now and i've noticed that the down pipe makes my boost spike a bit higher probably because it spools a bit quicker.
The downpipe definately gave more power, quicker build, I also get some pop, gurgle and small amount of backfire but my car feels good right now......
timv is offline
 Old 02-12-2009, 10:44 PM   #11
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
Groans: 38
I just put on a cattless cpe DP and it's amazing. I have a stock cbe. at idle it is slightly deeper but not enough to really notice. At wot it is a totally different car it sounds mean as hell. pops,gurgles, and even backfires on occassion. Car pulls much harder up top and comes into boost much faster. I have been holding steady 17psi dropping to 15ish since I put it on.
bykeryder4life is offline
 Old 02-12-2009, 10:45 PM   #12
Groans: 38
I need a fuel pump though soon.....putting a cpe fmic on in the morning so I will most likely be cutting bad.
 Old 02-14-2009, 12:41 AM   #13
steven88's Avatar
Posts: 773   (View Stats)
steven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the world
Groaned at 9 Times in 5 Posts
i have a cp-e catted with the stock cbe....it's definitely an increase in noise....but it will tone down after awhile and it won't be bad...its not a HUGE increase in noise that is for certain.....it is definitely daily-able with stock cbe
if you absolutely do not want a noise increase, you will have to look else where...a downpipe opens up the restriction big time
steven88 is offline
 Old 02-14-2009, 09:04 AM   #14
Ftaz1's Avatar
I am not worried too much about the noise increase...I just wanted to know what I was in for.
Ftaz1 is offline
 Old 02-14-2009, 12:18 PM   #15
steven88's Avatar
it's not bad at all...at first it might take you off guard...but after driving it around and letting it break in, it will be fine
it took me about 2 weeks to fully break in and get use to the sound
steven88 is offline
 Old 02-02-2010, 08:50 AM   #16
snowms3's Avatar
Posts: 287   (View Stats)
snowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond reputesnowms3 has a reputation beyond repute
cant wait to install mine. Shitty part is i have to wait til i get home from the desert. oh well it will be waiting on me when i get there
snowms3 is offline
 Old 02-02-2010, 08:55 AM   #17
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
i give u the "numbskull who bumped a year old thread " award!!!!!
collect your prize over there ------------------------------------------------------------>
rodrigo is offline
 Old 02-04-2010, 08:17 AM   #18
snowms3's Avatar
haha i noticed that man but just lookin around at shit, its still worth talkin about. Seein as i just purchased one, would love to have insight on the shit ya know. If you have some, then shoot, even if it is some shit talkin lol
snowms3 is offline
Closed Thread
catted downpipe? tbone Mazdaspeed3/6 General Discussion 3 02-03-2009 04:00 PM
cp-e catted downpipe bova MazdaSpeed 6 - Engine, Transmission & Driveline 10 12-01-2008 11:16 PM
Page generated in 0.36858 seconds with 28 queries
