Closed Thread
 Old 11-17-2008, 10:34 AM   #41
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
yes, but you are also running a standback and have a way to tune for vta.
maybe i just bit off more than i could chew.
all i care about now, is power steering. please help me people.
ohhhh...i mis-read what you wrote..nvm
phillyb is offline
 Old 11-17-2008, 10:35 AM   #42
Renzokuken's Avatar
Posts: 900   (View Stats)
Renzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the world
Originally Posted by Laloosh View Post
Like i said, the coolant hose is there so you can fit a cpe cai with a cpe fmic. You got the hotpipe, the cold pipe and a 3 in intake going thorugh there. You dont like it, buy something else
The tow plate says to remove the bumper so you dont fuck your shit up. You can get a lot more tq on the bolt if the bumper is removed. Would you prefer instructions with short cuts that have the potential of fucking your oem equipment up?
I had never owned a CPE product till I bought the towplate. When I read the instructions, I was very surprised at how DETAILED they were. It was awesome! It really showed me how much dedication and thought they put into their product. I must say that CPE is a great company for this.
1990 Totoya Corrolla DX TRD limited edition w/ Back to the future Delorian body kit/ K&N snorkel inlet ram-air intake/ Mazdaspeed T3/T4 turbo-supercharged hybrid 5 PSI and many more mods. 11.92 @120 MPH
Renzokuken is offline
The Following User Says Thank You to Renzokuken For This Useful Post:
phailerider (11-17-2008)
 Old 11-17-2008, 10:37 AM   #43
timv's Avatar
Posts: 179   (View Stats)
timv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud oftimv has much to be proud of
haha. i was sober, and it all went well, just thought it was a bit much for an fmic. it could have been simpler.
i have no experience with power steering fluid. my hands had been dirty. and no one except kevin was talking shit until we all realized that this was a pain in the ass. (go figure )
well, i was 100% unbiased until i started disconnecting hoses. i understood that shit would run down and get me wet. that was not my problem, it's just too much for me. i'm not going to turn this thread into anything regarding cpe and cobb and i hope it stays that way. i don't give two shits about that. all i know is that i need help.
i need help with t3h power steering. please help me. i have no power steering right now. this might be as simple as adding more fluid, but i want to make sure i do it correctly.
the two lines coming off of the power steering cooler...does it matter which hose goes to which line?
i took the top one from the oem power steering thing and made that the top one on the cpe thing. then i did that on the bottom.
soooooo...when we tried filling the power steering fluid reservoir, the pump made horrible sounds...is that just air?
i tried turning it back and forth and back and forth to get rid of the air, but it seems like it was all for nought.
when i was turning the wheels (mind you, the car was still jacked), it felt really loose, leading me to believe power steering wasn't in fact hooked up correctly. should i switch the lines?
OR should i just try to fill the power steering reservoir and turn the wheels back and forth?
please please please help
You might want to try adding the fluid with the car off the jack stands. It might be putting some part of the system higher than the fluid reservoir and pump not allowing the fluid to be pumped through the system correctly, I'm not positive but it's worth a shot.
I know on my old VW vanagon, you had to raise the whole front of the car like a foot to bleed the coolant lines, crazy coolant system those had.
I'll be installing my CPE FMIC in a week or so and will give my install impressions after. I'll be doing it alone so will have to fight any problems by myself.
Good luck with your PS.....
timv is offline
The Following User Says Thank You to timv For This Useful Post:
phillyb (11-17-2008)
 Old 11-17-2008, 10:59 AM   #44
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
i run a standback with zero tuning for vta....imo needing to tune for vta is overrated
Laloosh is offline
 Old 11-17-2008, 11:05 AM   #45
phillyb's Avatar
Groans: 1,940
ahh
phillyb is offline
 Old 11-17-2008, 11:15 AM   #46
Lymerock's Avatar
Posts: 1,436   (View Stats)
Lymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the world
agreed, im vta with my cobb and with the exception of a blip during shifts, my afr's are straight
no need to specifically tune for vta imo
Lymerock is offline
 Old 11-17-2008, 12:57 PM   #47
phailerider's Avatar
Posts: 4,639   (View Stats)
fanboii to the rescue!!!!
philly b bought a product that happens to be made by CPE,if he would have gotten the same deal by purchasing a different brand he would have done that as well. We were all there to see its glory.....it was like an 80 year old womans fart actually. You got a vested interest in CPE s success so you are about as objective as me in a buffet. You don't like that deal with it. We all use products that get reviewed and feedback is given to either promote the product or vent one's frustrations over the problems encountered. If you really believe that a single company is incapable of making a product here and there that doesn't meet the expectations of the customer that bought it, then sadly you've been sniffing cpe's packing tape too long. This was such a case and it happened to be witnessed by at least 8 other ms3-ms6 owners. World is full of dissapointments...sad to say.
newsflash....
these intercoolers have been out for over 6 months with hundreds of installs and user impressions. you guys just had the worst one ive read and you posted it in my section....wtf?!?!? and lenny...you specifically have an axe to grind so you need to personally man up.
as for me...of course im a fanboi for defending it. and i think you need to all take kevins dick with the cobb tattoo out of your mouth, in order to have an objective opinion. philly brought the truth out when he said that kevin "was the first to bring it up"... yeah surprise there. kevin bitching about cpes design = real shocker.
phailerider is offline
 Old 11-17-2008, 01:10 PM   #48
Their design is stupid and ive made no secret about it from day one, geee... surprise..
Everyone makes good and bad parts, who gives a fuck? He got it cheap and he wanted a FMIC. I was just surprised at all the shit he had to relocate, just to off center the damn thing to save 2, worthless, plastic tabs.
Haltech is offline
 Old 11-17-2008, 01:18 PM   #49
phillyb's Avatar
Groans: 1,940
can we make one thing clear. i have NO dick in my mouth. and if i did, it sure as hell wouldn't say cobb.
i'm not 100% loyal to a manufacturer. and like i said, i was, as were most people, really really impressed with the downpipe. that's a quality fucking piece.
i also stated that i remained unbiased even though others were not.
these thoughts are my opinions spoken through experience, not a bot regurgitating crap from fanbois.
phillyb is offline
 Old 11-17-2008, 01:18 PM   #50
well come in here and grind your axe big boy... ive got one in both hands myself.
its just perspective kevin... ive installed 4 of them and when im doing it.... the customers are usually tickled with the extra higher quality heat exchangers, easy and near perfect fitment, incredibly detailed instructions, upgraded ps lines, and beauty of the kit in general. and installed like i said... in a busy 2 hours.
search all three forums and link a thread where a customer posted negative impression AFTER they purchased the kit.
if you hadnt been so busy bitching about it, you might have been able to lead your little army there to get the job done in less than all day affair.
 Old 11-17-2008, 01:22 PM   #51
Please demonstrate to me, how a Cpe FMIC is higher quality, than that of a Cobb? I really have to hear this one.
Haltech is offline
 Old 11-17-2008, 01:23 PM   #52
just remember... if id helped with the install it would have taken 2 hours and it would have been spent highlighting the positives....
which there are many.
to describe it as OVERengineered, is quite an arbitrary opinion im afraid..
 Old 11-17-2008, 01:26 PM   #53
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
Kevin was sober so he notices things. As for I , specifically told everyone no dropping fluids in my driveway..... had I known the cp-e fmic required not one..but TWO fluids to be drained the install wouldn't have happened. Thats my ignorance for assuming the only element involved in an FMIC change would be AIR. And I'm sure putting some fins on a shorter tube that carries powersteering fluid really drops the temps on that pump!?!? I'm just surprised they dont claim the rubber they use for the radiator hose has magic rubber that has additional cooling properties. All is well....the downpipe looked ok at least...compared to exhaust depot's.
rodrigo is offline
 Old 11-17-2008, 01:27 PM   #54
Laloosh's Avatar
why is cobb brought in this? Seriously
Laloosh is offline
 Old 11-17-2008, 01:29 PM   #55
im not the one saying one is better than the other.
Im the one in my own cpe section, defending an intercooler i use and sell, thats had marvelous customer reviews from top to bottom....from being mocked and trashed by the lapdogs of the forum owner who is a known cobb fanboy.
are we clear here?
And i dont mind defending it either... it allows me to highlight all the upgrades the thing has over the competition.
The Following User Says Thank You to phailerider For This Useful Post:
FreeFlyFreak (11-18-2008)
 Old 11-17-2008, 01:33 PM   #56
phillyb's Avatar
Groans: 1,940
i wish you were here to help
i'm actually annoyed by this as well. with permission randy, i'd like to prune the shit out of this thread. hhahaha
phillyb is offline
 Old 11-17-2008, 01:35 PM   #57
geez louise...
your a hypocrite considering how badly you attack laloosh al the time for addressing real isues with your manufacturer of choice. Quit comparing issues like loss of power, broken components, plastic tinker quality, springs that drop the car up, out of stocks like crazy..... to cpe. Your fear of a little fluid on your driveway compared to all that is a fucking joke.
 Old 11-17-2008, 01:37 PM   #58
Ive built over 15 cars/trucks in 20+ yrs of working on hot rods, do you really think, us 12 people, dont know how to install parts?
Haltech is offline
 Old 11-17-2008, 01:40 PM   #59
phillyb's Avatar
Groans: 1,940
well, it is phillyb
phillyb is offline
 Old 11-17-2008, 01:40 PM   #60
The point im making is, you are telling me how much superior, CPe's core is.. HOW? How is it superior? This is what im asking you...
Haltech is offline
 Old 11-17-2008, 01:41 PM   #61
Laloosh's Avatar
lol yes? The more poeple, the more drinking the shittier shit goes.
Laloosh is offline
 Old 11-17-2008, 01:42 PM   #62
Laloosh's Avatar
as far as the cpe core...the end tank design is better then what i see from every1 besides atp.
Laloosh is offline
 Old 11-17-2008, 01:46 PM   #63
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
geez louise...
if u really think that installing a FMIC and bolting shit to a car is knowledge of shit u must think im in my teens or early 20's. I attack la-douche cuz he is always chiming in on shit that has nothing to do with him. This thread i believe was about phillyb's experience with his cpe installs...since the shit was at my house and I have enough experience working on plenty of hot rods that I have built myself from the ground up using only community college as my "driveway" (yeah, including buillding and machining my own motors.0 I believe I am certified enough to judge how lame a "bolt on " part is. Reality is a difficult thing sir.... that why I dont like looking at pics of myself...cuz I'm fat as can be.....but it doesn't change the fact that I am nonetheless. get over it homes, cant all be kiss pale's ass reviews of CPE shit.
rodrigo is offline
 Old 11-17-2008, 01:59 PM   #64
Laloosh's Avatar
hey faggot, i can chime in whever i want. Esp in the cpe section. Id love to see u sqeeze underneat a car with all that experience of yours
Laloosh is offline
The Following 2 Users Say NO Thank You to Laloosh For This Un-useful Post:
 Old 11-17-2008, 02:06 PM   #65
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
never said u couldnt son. free world...even idiots get to vote in this country.
rodrigo is offline
 Old 11-17-2008, 02:08 PM   #66
Laloosh's Avatar
yes they can...its a good thing there no to many of them or else mcain would of won, but u can start another thread on that.
Laloosh is offline
 Old 11-17-2008, 02:21 PM   #67
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
haha....we agree on that.
by the way, I can get underneath my car just fine (provided the jackstands can clear my gut) and if i dont have a circus monkey like phillyb to do my dirty work. the fanbois may be impressed with someone swapping turbos and thinking its an accomplishment. I'm not......I was engine building before u stopped jerking off to MTV videos. what u do is repectable (taking your car to a higher level) but dont think its fucken black magic bro. go OBAMA!!!!!!!!!
rodrigo is offline
 Old 11-17-2008, 02:40 PM   #68
all right. thats enough. youve made youre point and people are gonna judge your comments based on probably what seems obvious about all this or what they already believe. but your posts are going to hell. so thats enough. ok?
?????? dude chill out. theres more to the kit. some would say thats a good thing... some would say its overengineered. no question there is more published r/d on the cpe core. cobb hardly released anything.
i dont want to argue this. cobbs kit is a nice one too it seems. this really just isnt the big deal you guys are trying to make out.
 Old 11-17-2008, 02:45 PM   #69
booya620's Avatar
Posts: 697   (View Stats)
booya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the world
wow the minute cp-e or cobb is mentioned a pissing match ensues. Philly just wanted to comment of what he thought of the install, and to ask a few questions about fixing his power steering issue. it's nice to know that the install was more complex than other kits, some may like the ps cooler, others may not. Some people looking for a faster install and removal time may decide to look somewhere else. I do like the fact that cp-e did add these additions to the kit it makes it look like they actually did some r&d and thought that there is an added benefit. Maybe a basic kit sans ps cooler would be a nice option for those looking for a quicker install time.
philly unless i'm mistaken it shouldn't matter which \ hose goes into an out of the cooler, unless there some crazy 1 way baffle system in it. Just add more fluid and keep turning the wheel, while on the ground.
booya620 is offline
The Following User Says Thank You to booya620 For This Useful Post:
 Old 11-17-2008, 02:47 PM   #70
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
fair enough. (to pales last post)
rodrigo is offline
 Old 11-17-2008, 02:51 PM   #71
all the more questionable that you had such a big issue when a rookie like me, knocked it out in 2 hours the second time i saw the damn thing.
Between 2-3 hours.... me and semperboost pulled his turboxs ic OFF, put the cpe ic on, pulled his fujita intake off and fitted a cpe cai to the atp inlet and gt3071 which was the bulk of the pia in the install. we didnt have the correct length coupler and had to run around the shop for the last 1/2 hour tracking some stuff down.
he showed up at 9 and was gone by noon.
How in the hell 12 guys with all your experience bungled this job can probably be summed up in just a few words.....
10 cobb fanboys
beer
carne asada
a driveway that better not get dirty....and
class clown philly bought a used cpe ic
 Old 11-17-2008, 02:57 PM   #72
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i thought we were stopping????lol and my driveway did get dirty btw......fuck!!! if u think we were working 75% of the time u r wrong, I was going to do an oil change inside the garage on my car, but I started drinking vodka and squirt at 9am.....the rest is a haze.
phillyb would have gotten done sooner but Kev and I were chucking rocks at him from lawnchairs.
rodrigo is offline
 Old 11-17-2008, 03:05 PM   #73
phillyb's Avatar
Groans: 1,940
so long as i'm not one of the 10 cobb gobblers, that list looks fine to me. BUT, dane was there, and he has a standback...soooooooooooooooooooooooooooooooooooom aybe 9 cobb gobblers
phillyb is offline
danesti (11-17-2008)
 Old 11-17-2008, 04:19 PM   #74
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
hahah for sure philly...
and ya.. i have a few cpe parts with my FMIC and CAI from them getting here sometime this week (right randy?)
i am by no means a car expert, and wont claim to be... but yesterday there were plenty of people that knew there shit.
we did everything from front mounts, sways, downpipes, ect. and had a great time talkin shit and talkin cars
i helped philly out a little bit (not much) with his FMIC and i agree the things required for install seemed a little extensive, and i just hope its not that involved for when mine gets here and i eagerly throw it on.
Kevin- i have alot of respect for you, but i dont think the Cpe FMIC is horrible. (la-douche where the fuck did you tap for meth?)
not saying its any better/worse than the cobb.
randy- thanks for all the constant price checks and helping me ordering and such..
but dont take this the wrong way, alot of people dont like the way you argue/present yourself on the boards.. and representing a company, i think you should take a more technical approach to arguing.. when you avoid answering questions it leads me to believe you dont have a good answer.
please try to understand...
not hating.. im just a reader in these things most of the time..
i was just offended that you thought all the people at the bbq were incompetent installers.
im not ASE certified or anything, but some people there were quite knowledgeable so please show some respect in that regard.
2008 STi
Intake
Turboback
AP
danesti is offline
The Following User Says Thank You to danesti For This Useful Post:
 Old 11-17-2008, 05:10 PM   #75
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
"offended" ..i like that.....
rodrigo is offline
 Old 11-17-2008, 05:19 PM   #76
danesti's Avatar
Groans: 137
lenny... after meeting me in person.. you should have expected that. haha
2008 STi
Intake
Turboback
AP
danesti is offline
 Old 11-17-2008, 05:49 PM   #77
dane..
first and foremost... i represent myself. i hardly believe that my opinions hurt cpe sales. thats a joke. and i'll let my sales figures dictate, and my sponsors decide... if i need to tone it down. i hardly think i do. give me an example of where ive angered anybody but all the cobb guys running around with their tinker toy tuning devices concerned more about ltfts, and KR... than actual power. When Kevin gets done with 8 months of revisions for MSF version 1.03.45fsr and actually posts a goddam dyno... than i might take the whole thing seriously.
and as far as knocking all the car experts there. i am. point blank. if this fucking intercooler pissed them all off than i wouldnt trust them to install a bag of groceries in my trunk. its just not that hard. my neighbor, derek and i installed it the first time in my driveway in about 4 hours interupted by a rainstorm where we had to pack up everything and move itside.... there was no complaints by any of us. hell the damn undertray...is and remains the worst part of the job.
the second time i did one we knocked it out in a couple of hours... the 3rd and 4th time i could have done it in my sleep. there were never any complaints from the others invovled.
this was a cobb sausage fest gone bad. a bunch of guys got buzzed, started making fun of philly with his used cpe shit and when the thing didnt snap together like the glovebox...all hell broke loose. i can imagine EXACTLY what went on there, and if guys are gonna talk shit about how "tough" it was... or how"overengineered" it all is... then im gonna call them out for being biased.... either that, or they have no business lifting wrench. There simply just isnt much to this install.
and the fact that you guys are making such a goddam big deal about it has already affected perception... i gaurantee it. the one guy above concluded that it might take a little too much time, or be a little over his head. thats fucking bullshit and im gonna say so. its a great kit and ive never heard more bitterness about the thing than in this one thread.
100's of satisfied customers > a bunch of bitter buzzed cobb fanboys at a socal barbecue
as i said before... if i was doing the install this thread never would have gone this way. its that simple. and im not exactly an experienced grease monkey either...lol
 Old 11-17-2008, 05:51 PM   #78
Lymerock's Avatar
after reading all this, i completely forgot what this thread was about
Lymerock is offline
 Old 11-17-2008, 06:00 PM   #79
its been awhile since weve had a good barnburner. this one was ineveitable. all the ingredients collided on that driveway yesterday.
Kevin + socal cobb crew + philly b + cpe ic install = a pissing match the next day.
 Old 11-17-2008, 06:02 PM   #80
Pissing match? lol.. if you were there, you couldn't be more wrong. I just think its fuckin stupid to relocate all of that shit, just to have an off centered core, where as a person could cut 2 simple plastic tabs off if need be and be done with the damn thing, centered.
Haltech is offline
Closed Thread
Cobb FMIC vs Exhaust Depot FMIC mrjoshyman MazdaSpeed 3/6 - Turbo Induction 44 04-20-2009 10:30 AM
DIY FMIC babcockxmx MazdaSpeed 3/6 - Turbo Induction 0 09-06-2008 01:03 PM
Cobb Ap FMIC map with Cobb FMIC not driveable Unoriginalusername MazdaSpeed 3/6 - ECU Computer Tuning 119 07-20-2008 08:40 AM
Page generated in 0.57818 seconds with 29 queries
