Closed Thread
 Old 02-12-2011, 09:14 AM   #1
Zbrit00x's Avatar
Posts: 541   (View Stats)
Zbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the worldZbrit00x is the leader of the world
Default Cpe tmic and the 2nd gen ms3..
Pretty much if you have a gen 2 and were thinking of purchasing.. Think again. Way intercooler is designed is that rubber shroud under hood scoop sits on intercoolet CORE. found this the hard way last week as the rubber melted on core..
Look back at this thread for pics/ info
cp-e TMIC pics
Zbrit00x is offline
 Old 02-12-2011, 07:22 PM   #2
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
If you would address this by calling us we would be happy to make an amendment to the design to satisfy your problem. There's not much of an option with this though, as this intercooler is almost twice as thick as the stock unit. It is nearly impossible to almost double the flow of the stock intercooler (which we've done with our TMIC) with out making the core significantly thicker. This extra core volume will lead to contact with the rubber seal of the hood which is designed for a 1.5-1.75 inch thick core.
We are more than happy to implement changes in our design to keep our customers happy, however, calling our shop is a better way to implement these changes as opposed to starting a thread on MSF.
In the end, we are here to make sure you are happy with your product.
Thanks,
-Sander
Website: www.cp-e.com
www.cp-e.com is offline
The Following 3 Users Say Thank You to www.cp-e.com For This Useful Post:
dagrimey1 (05-09-2019), Mikedubs (02-12-2011), skeeter149 (02-12-2011)
Closed Thread
Page generated in 0.22536 seconds with 21 queries
