| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() | | #41 | ![]() |
![]() Join Date: Nov 2011 Location: Corona, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 220
| Not Ranked : 0 score
__________________ 2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. . |
![]() | | #42 | ![]() |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score lololoz |
![]() | | #43 | ![]() |
![]() Join Date: Jan 2012
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Yeah good shout buddy. I thought of somehow modifying my original tow hook. At least i know it will be the rite thread |
![]() | | #44 | ![]() |
![]() Join Date: Apr 2010 Location: Miami FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,836
Groans: 263
| Not Ranked : 0 score a whole bunch of art master pieces here
__________________ 2010 Black Mica 2004 EVO 8 Green Monster The "7up" |
| The Following User Says Thank You to rghispanic88 For This Useful Post: | Vader (01-12-2012) |
![]() | | #45 | ![]() |
![]() Join Date: Aug 2008 Location: Orange County NY
Rep Power: 2267 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,484
| Not Ranked : 0 score Just saw this now. If you work in a garage just make a space that fits between the shaft and the plate. That bolt should be long enough.
__________________ cp-e-FMIC/cp-e-HPFP/cp-e-Xcel Nano Intake/cp-e-Nviscid TIP/cp-e-BOV Kit/cp-e-Stage2 RMM/cp-e-xFlex Passanger & Driver Motor Mounts/cp-e-catted DP/cp-e-Nexus cat-back exhaust/cp-e-tow plate/cp-e-Tripple Gauge Pod/Rally Armor-Mud Flaps/TWM-Base Bushings/TWM-Shift Weight/Street Unit-Washer Fluid Cap/Street Unit-Oil Cap/Konig-Milligram/Corksport-Rear Sway Bar/Corksport-Aluminum Skidplate/StopTech-Sport Brake Kit/GTSpec-rear v-brace/GTSpec-link reinforecement panel/GTSpec-rear lower tie bar/GTSpec-4 points ladder brace/Lamin-x-Headlight film/Lamin-x-Taillight film/TWM-Full replacement shifter/TWM-Big Type R knob & Hybrid Knob/TWM-Shift boot/3M-1080 Matte Dark Grey Wrap/3M-1080 Brushed Steel Wrap/Tial-BPV/DG Motorsports-CF front lip/DG Motorsports-CF Rear wing extention/Sonic Tuning-Coilovers/COBB Tuning-AccessPort/ |
![]() | | #46 | ![]() |
![]() Join Date: Nov 2010 Location: Annapolis, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,335
Groans: 45
And people wonder why all the shitting on these guys. Almost a week to get back to you, basically telling you to fuck off, and fix it yourself. @Grumpyjap What if he had no access to parts? What then? He's SOL and has to keep it, or get ass raped to return it. Maybe you should tell your boys to stock a few of the CORRECT part, for international buyers. | |
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score Exactly ^^^^ the wrong parts and when i asked what they will do about it i get no reply and still havnt. Customer service! I do work in a garage but that bolt is not long enough. So i will need to find a longer bolt that fits the rite thread and must fit inbetween the hole in the plate!! NITEMARE!! Your exactly rite in what your sayin they took a week to get back to me and are pretty much not bothered there arse! |
| The Following User Says Thank You to mikie For This Useful Post: | Vader (01-12-2012) |
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score And yes i would get RAPED to return it to usa from uk. For wat? Because they made a cunt of it? Great! |
![]() | | #49 | ![]() |
| Not Ranked : 0 score Moved the thread to the CPE section in case they feel the need to see it and respond. I will reopen if it gets closed, tho. |
| The Following User Says Thank You to Raider For This Useful Post: | Vader (01-12-2012) |
![]() | | #50 | ![]() |
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score you might be able to get someone in a job shop to weld an extension in?
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah thats wat am thinkin bout doin |
![]() | | #52 | ![]() |
Groans: 890
| Not Ranked : 0 score yeah man, screw sending it back to the US. That's why I don't deal w/ CP-e.
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score Wel that was my first experience with them as iv only had my car about 6 months and will definatly not go back. Still had no response from cpe. I even asked if they would start to make the adapter to fit the uk spec or even make me 1 and i would pay for it but still heard nothing |
![]() | | #54 | ![]() |
| Not Ranked : 0 score Keep your pants on @Vader I'm trying to resolve the issue.....always so quick to jump on the bashing.
| The Following 2 Users Say Thank You to Grumpyjap For This Useful Post: | Easter Bunny (01-30-2012), Vader (01-12-2012) |
![]() | | #55 | ![]() |
![]() Join Date: Nov 2010 Location: Phoenix, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,658
| Not Ranked : 0 score Because they're across an ocean from you?
__________________ 2010 MS3 - Restockified (The former STX Battle Wagon) Progress RSB - Koni Sport - EBC Yellow - MD OCC - CS MonoCBE - Cobb SRI 2004 MSM TiGrey AEM SRI - Turbosmart MBC - FM TBI - eBay DP - Turbosmart BPV - Mishimoto FMIC - Denso 305cc Koni Sport - GC Coilover - Racing Beat 1.25" Front Sway Bar - SS Lines - 15x8 Flatout - 225/45 RS3 |
![]() | | #56 | ![]() |
Groans: 45
But can you honestly tell me why they can't handle things better? Really, 5 min of their time, on more than one occasion, would have gone a long way to quell the fires. | |
![]() | | #57 | ![]() |
__________________ cp-e-FMIC/cp-e-HPFP/cp-e-Xcel Nano Intake/cp-e-Nviscid TIP/cp-e-BOV Kit/cp-e-Stage2 RMM/cp-e-xFlex Passanger & Driver Motor Mounts/cp-e-catted DP/cp-e-Nexus cat-back exhaust/cp-e-tow plate/cp-e-Tripple Gauge Pod/Rally Armor-Mud Flaps/TWM-Base Bushings/TWM-Shift Weight/Street Unit-Washer Fluid Cap/Street Unit-Oil Cap/Konig-Milligram/Corksport-Rear Sway Bar/Corksport-Aluminum Skidplate/StopTech-Sport Brake Kit/GTSpec-rear v-brace/GTSpec-link reinforecement panel/GTSpec-rear lower tie bar/GTSpec-4 points ladder brace/Lamin-x-Headlight film/Lamin-x-Taillight film/TWM-Full replacement shifter/TWM-Big Type R knob & Hybrid Knob/TWM-Shift boot/3M-1080 Matte Dark Grey Wrap/3M-1080 Brushed Steel Wrap/Tial-BPV/DG Motorsports-CF front lip/DG Motorsports-CF Rear wing extention/Sonic Tuning-Coilovers/COBB Tuning-AccessPort/ | |
| The Following User Says Thank You to Grumpyjap For This Useful Post: | Vader (01-12-2012) |
![]() | | #58 | ![]() |
Groans: 890
| Not Ranked : 0 score I like the customer service of the companies I work with (Cobb/Corksport/JBR), plus my wallet HATES being raped anally. Too many CP-e issues and too much $$$($) lol
![]() | | #59 | ![]() |
![]() | | #60 | ![]() |
| Not Ranked : 0 score So here's what's happening. So it appears that this is the first issue that has come up with the tow plate over seas. They haven't had enough demand for this product so they offered the OP a refund. This option was given when he first contacted them so at this point it's up to him what he does.
| The Following User Says Thank You to Grumpyjap For This Useful Post: | Nliiitend1 (01-12-2012) |
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score This ^^^ is bullshit! I was offered a refund yesterday! I can copy and paste the email if needed. 11-01-12 at 5.25pm. |
![]() | | #62 | ![]() |
| Not Ranked : 0 score My bad, I thought today was the 11th. Sorry about that
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score Also they have never come across this problem from a uk buyer before so my 3 mps must be different from every other in the uk that has purchased the cpe towplate! Mmmm SURE!! |
![]() | | #64 | ![]() |
Groans: 890
| Not Ranked : 0 score And I'm sure you eat the shipping.
![]() | | #65 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yup probably. Iv asked if they would make 1 adapter for me so i can use the product and even offered to pay for it. Ill see wat happens |
![]() | | #66 | ![]() |
| Not Ranked : 0 score Why pay them to make one special adapter? You have the actual part, you know how much longer it needs to be. Take it to a machinist and he can make that for you easily, either to extend the CPE part, or a new single piece.
![]() | | #67 | ![]() |
(Thread Starter) | Not Ranked : 0 score Point is i shouldnt need to. There sorting out a longer bolt and possibly a spacer so i can use it |
![]() | | #68 | ![]() |
(Thread Starter) | Not Ranked : 0 score Big thanks to grumpyjap. Hes help get this shit sorted |
![]() | | #69 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
![]() If so, do you know for a fact that they notified cp-e of the issue?
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
![]() | | #70 | ![]() |
(Thread Starter) | Not Ranked : 0 score Cpe confirmed there has been uk customers that purchased this product and this is the first time they have come across this problem |
![]() | | #71 | ![]() |
| Not Ranked : 0 score ...and you're speaking specifically of the Gen2-specific product as well?
![]() | | #72 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes |
![]() | | #73 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thought id update this. So iv been told by grumpyjap i am getting a longer bolt and spacer sent to me. This was almost 2 weeks ago. In the last week iv sent him 2 messages and emailed cpe and being ignored by both. I dont see how a company that manufactures there own products can take 2 weeks to source a small bolt! |
![]() | | #74 | ![]() |
| Not Ranked : 0 score Go to a machine shop.
![]() | | #75 | ![]() |
| Not Ranked : 0 score "2 weeks" is CPE's way of saying 2 months. Very common. I would hit up your local fastener shop, fix it on your own, and chalk it up as a leaking lesson. |
![]() | | #76 | ![]() |
Groans: 45
![]() | | #77 | ![]() |
Groans: 890
Sent from my Evo 3D
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER | |
![]() | | #78 | ![]() |
| The Following 4 Users Say Thank You to Grumpyjap For This Useful Post: |
![]() | | #79 | ![]() |
| Not Ranked : 0 score UPDATE: Bolt and spacer have been on order since last tuesday. Its a special order so it's taking a bit longer to get.
| The Following 3 Users Say Thank You to Grumpyjap For This Useful Post: |
![]() | | #80 | ![]() |
| Not Ranked : 0 score Unfortunately, grumpy, since you are the face of cpe, handle their shit customer service, and have a couple pics of your car on their site, you tend to be tied to cpe. To be fair, an mail to him from cpe with details would have resolved the matter for at least 2 weeks. In my experiences with 4 other vendors here in recent months, I get pm's replied to within 1 business day, email status updates, and more. Hell, @jbarone called me 20 minutes after a panic pm yesterday when had issues with the ssp. Problem solved. Edgeautosport sent my mt90 out the door 1 hour after $ was sent. @MATT DAMOND helped me with my cx7 after. Fucked the pcv valve. It's sad to see cpe dropping a presence here. It's not helping sales to see every thread you help resolve their issues. When Jordan and even Jake were there, any of this stuff was resolved. Actually, I take it back. There were no problems when Jordan was there, but Jake resolved a lot. It's sad they cannot see the need to have someone here to promote their products in a tight market, flooded with lower cost, high quality alternatives. I'm afraid to see in time, when sales for their stuff dry up, they seem the market dead, kill of the Mazdaspeed line to focus on Gencoupe and other lines \rant |
| The Following 3 Users Say Thank You to Raider For This Useful Post: |
| CP-e TowPlate | Haltech | Review Discussion | 46 | 04-15-2009 04:12 AM |
| GM adds 12-month/12,000-mile bumper-to-bumper warranty on certified used vehicles | Haltech | Automotive News | 0 | 08-19-2008 05:50 PM |
