| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() Join Date: Sep 2008 Location: Soledad, CA
Rep Power: 446 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 393
Groaned at 5 Times in 2 Posts
(Thread Starter) | Not Ranked : 0 score I just wanted to take a moment and share some details of how my E-Tune is going with CP-E (Jake). As I am from the West Coast, California, and CP-E is almost 2000 miles away I cannot get a custom dyno tune from them. I have a built block, gt3076r, CP-E XcelXL Big Maf Intake, all CP-E flashes and looking forward to 400whp!! Running the car untuned felt somewhat weak and sluggish. Once Jake started making adjustments to my tune the car started to feel better and carried the power to redline. At the first couple adjustments, Jake had the car at 12psi and to be honest I felt the car more powerful than before having my car fully-bolted at 20psi with the stock k04 turbo! After several adjustments and now at around 17.5 psi at 3500rps going WOT in 3rd gear I get alot of torque steer! Everyone running the Standback should consider getting an E-Tune or even getting dyno tuned at CP-E, Jake has been great to work with and I appreciate all the time he has put in my tuning. Thanks CP-E!! |
| The Following 5 Users Say Thank You to 11cruzito11 For This Useful Post: | bioevolve (02-24-2010), gsrtype1 (02-28-2010), madvillain (02-27-2010), MPSdriver (05-06-2010), tozfeekum (02-23-2010) |
![]() Join Date: Dec 2009 Location: Fontucky, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 1,364
| Not Ranked : 0 score dyno dyno dyno it. |
| The Following User Says Thank You to felt For This Useful Post: | SpeedNess (02-23-2010) |
| The Following 2 Users Say NO Thank You to felt For This Un-useful Post: |
![]() Join Date: Dec 2008 Location: Flint, MI
Rep Power: 206 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 955
| Not Ranked : 0 score ^+1, i want to start seeing more 400whp ms3 and 6's, hopefully 2010 will be the Speed's YEAR!!!! |
| The Following 2 Users Say Thank You to 11cruzito11 For This Useful Post: | 802MS3 (02-24-2010), xcoldricex (05-05-2010) |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
| Not Ranked : 0 score What turbine housing do you have? Other mods? Good luck with your tuning and is it absolutely awesome to drive? |
| Not Ranked : 0 score 22psi? r u kidding? how bout 26? you have a built block what r u afraid of!!!
| The Following 3 Users Say Thank You to superskaterxes For This Useful Post: |
| Not Ranked : 0 score Post some pics and vids. We need media
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score what tires are you rocking and what size?
__________________ '08 CWP MS3 w/ T3 3071r |
| Miembro ![]() Join Date: Jun 2008 Location: Puerto Rico
Rep Power: 420 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,095
Groans: 27
| Not Ranked : 0 score if your using the ATP stock housing turbo you cant boost more than 21psi??
__________________ 2008.5 MS3 Metro Gray...slow |
![]() Join Date: Jul 2008 Location: Forest Hills, NY
Rep Power: 352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 104
| Not Ranked : 0 score 22lbs dry 24lbs meth
__________________ ![]() 2003 E39 ///M5 |
![]() Join Date: Aug 2008 Location: jersey
Rep Power: 609 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
Groaned at 42 Times in 35 Posts
| Not Ranked : 0 score 1. Get some videos and dynos. 2. dont be afraid run at least 24psi 3. Race some people on video
__________________ |
Rep Power: 1790 ![]() Thanks: 2,239
Groans: 62
| Not Ranked : 0 score Yea carlos, i was going 30 psi and 110 octane after 2000 miles. and that was without the new power flash. dont be skurred. |
| The Following 2 Users Say Thank You to MarkyMark For This Useful Post: | djuosnteisn (02-28-2010), NJSPEED3 (03-30-2010) |
Groans: 78
| Not Ranked : 0 score I can't wait to see what you can come up with on this car man.
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
Groaned at 24 Times in 6 Posts
| Not Ranked : 0 score Do yourself a favor and dont go to the track on stock tires, get yourself some drag radials. cant wait to see some #'s. |
![]() | | #19 | ![]() |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| Not Ranked : 0 score Badass!!! cant wait to see dyno! ))
![]() | | #20 | ![]() |
![]() Join Date: Nov 2009 Location: Lacey, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,314
Groans: 48
Groaned at 16 Times in 14 Posts
| Not Ranked : 0 score updates???
__________________ "Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is." -TTT |
![]() | | #21 | ![]() |
![]() Join Date: Sep 2009 Location: South Korea
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score Carlos - glad to see the Standback tune is going well. 400 hp is in your future. Making me want to take the next step and go big turbo. Looks like i'm going to just end up e-tuning with cobb and maybe pick up a PTP SST though, the wife is cool with all the car stuff and I promised her I wouldn't take it too far with this car. Now every time I try to schedule some time for a dynotune up in Plano I end up having work related travel get in the way. Again, thanks for the great deal on your AP and meth kit!
__________________ New Car: Evo X/MR, COBB AP Stg-II, COBB TBE, HKS PF, COBB Springs Old Car: '06 MS6, AP, GT3076R, CS FMIC, CP-E CDFP, Etc.... |
![]() | | #22 | ![]() |
![]() Join Date: Jan 2009 Location: DC
Rep Power: 228 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 408
| Not Ranked : 0 score im so wet. |
| The Following User Says Thank You to vbt101 For This Useful Post: | phillyb (05-05-2010) |
![]() | | #23 | ![]() |
![]() Join Date: Aug 2009 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 739
![]() | | #24 | ![]() |
| The Following User Says Thank You to 11cruzito11 For This Useful Post: | MPSdriver (05-06-2010) |
| Anyone fine tune there shifter and tune out a second gear grind? | stevessvt | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 10-21-2009 12:06 AM |
| MS3 tune | Asse | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 05-04-2009 08:45 AM |
| Tune for 91 or 93? | GongShow | MazdaSpeed 3/6 - ECU Computer Tuning | 2 | 02-12-2009 09:22 AM |
| help me tune please | etant333 | MazdaSpeed 3/6 - ECU Computer Tuning | 7 | 01-05-2009 05:12 PM |
