  • 1 Post By chaser27
 Old 03-16-2014, 12:11 PM   #1
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
Default Extended bung on DP
So I ordered a 3" catless DP, installed using the extended bung with the medium defouler tip and drove around for a while, love it, thought the defouler was working perfect, etc.
I ended up getting a CEL about 300 miles after the install, go online to check which ones I was supposed to uncheck in my tune and found out that the Gen 2's aren't supposed to use a defouler or extended bung for the secondary o2. My question for @www.cp-e.com; is, Why did my DP only come with an extended bung? Can I get a normal one to screw into the DP without having to go to shop and having them weld one on?
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
 Old 03-17-2014, 08:56 AM   #2
lobitoPU's Avatar
Posts: 3,205   (View Stats)
Groans: 42
Its 20 bucks to add an extra bung at any muffler shop.
You dont even have to remove the dp.
Fuck mazdaspeeds
Fuck shayne
The Following User Says Thank You to lobitoPU For This Useful Post:
chaser27 (03-17-2014)
 Old 03-17-2014, 08:58 AM   #3
chaser27's Avatar
Groans: 42
Sounds easy enough
Sent from my XT1080 using Tapatalk
ECU: self-tuned
 Old 03-17-2014, 09:07 AM   #4
kornybun's Avatar
Posts: 119   (View Stats)
kornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the worldkornybun is the leader of the world
Grind down the bung. No need for welding or defouler. Has worked fine on mine for twenty thousand miles.
-kornybun
kornybun is offline   Reply With Quote
The Following User Says Thank You to kornybun For This Useful Post:
JgamB (03-17-2014)
 Old 03-17-2014, 12:01 PM   #5
Grumpyjap's Avatar
Posts: 1,839   (View Stats)
You don't have to use the defouler, they include it with all of their cattless DP just in case you do. Take the defouler out, your O2 sesor will screw into where the defouler screwed into no problem.
The Following 2 Users Say Thank You to Grumpyjap For This Useful Post:
Agent_Orange (03-17-2014), mxlplx71 (03-17-2014)
 Old 03-17-2014, 12:03 PM   #6
chaser27's Avatar
Groans: 42
The threads are different for the extended bung vs the o2 sensor
ECU: self-tuned
 Old 03-17-2014, 12:05 PM   #7
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
He's correct. The threads are the same for the defouler and the O2 sensor
Website: www.cp-e.com
 Old 03-17-2014, 12:06 PM   #8
chaser27's Avatar
Groans: 42
I could be an idiot. I'll look again this afternoon assuming my garage isn't flooded again
ECU: self-tuned
 Old 03-17-2014, 12:14 PM   #9
The threads may have gotten gunked up, but if the defouler threaded in fine you should be good. We recommend using some copper anti-seize on there before you install.
 Old 03-17-2014, 12:21 PM   #10
chaser27's Avatar
Groans: 42
I used some anti size when I screwed it onto the defouler. I'm going to have to put my foot in my mouth if this works flawlessly haha
ECU: self-tuned
 Old 03-17-2014, 01:03 PM   #11
We're are hoping that it will work out flawlessly, not because we want to see your foot in your mouth, but just for your sanity so you can get back on the road quicker.
Although I think if it does work out you should post a pic of you with your foot actually in your mouth lol
 Old 03-17-2014, 05:14 PM   #12
chaser27's Avatar
Groans: 42
Of course it worked perfectly... I'm an idiot uploadfromtaptalk1395098021584.jpg
www.cp-e.com likes this.
ECU: self-tuned
The Following User Says Thank You to chaser27 For This Useful Post:
www.cp-e.com (03-21-2014)
UR Downpipe...which 02 bung do I use? pwned 2010 MS3 - Engine, Transmission & Driveline 0 07-14-2012 09:24 PM
Weld in O2 bung YokiMazoku 2010 MS3 - Engine, Transmission & Driveline 12 07-05-2010 05:31 PM
O2 sensor bung, is AEM = innovate for bung size? marcusdigi MazdaSpeed 3/6 - Turbo Induction 5 07-19-2009 08:16 PM
WI bung, done the correct way! ptperformance Mazdaspeed3/6 General Discussion 51 05-14-2009 10:29 AM
Second bung on CP-e downpipe Erich Custom Performance Engineering (cp-e.com) 14 08-09-2008 03:54 PM
Page generated in 0.33503 seconds with 25 queries
