Closed Thread
 Old 11-05-2008, 05:40 PM   #1
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
Default First CP-E Nano installed! w/pics
Well here it is. Pics are below. It's as good as i thought it would be. I like the design and it looks great also. Few tips for anyone installing one, the CNC bracket can be maneuvered to fit where it needs to be without to much of an issue. The small plastic tab has to be bent up slightly but once it is in it doesn't touch it at all. Also ensure the filter isn't pushed on too much. It only has to go on enough for you to tighten u the clamp. Anyways here is what you guys want to see...
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline
The Following 9 Users Say Thank You to SgtP For This Useful Post:
Crossbow (11-12-2008), eliminator (07-31-2010), gsrtype1 (11-06-2008), HiggyMS3 (11-09-2008), labikesrcool (11-05-2008), nighthawk358 (11-05-2008), phailerider (11-05-2008), superskaterxes (11-06-2008), SyntaxEscobar (11-14-2008)
 Old 11-05-2008, 08:09 PM   #2
MStempted's Avatar
Posts: 199   (View Stats)
MStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the world
sweet pictures, what camera did u use?
|| CP-E CAI || CP-E Inlet || CP-E FMIC || CP-E Catback || SU TurboSmart BOV || PG Turbo Manifold || CDI/PG Fuel Pump internals+spring || Denso 1step colder plugs || ATP DP || ATP FCD || ATP CEL trick || TWM stage2 SS+bushings || AWR Engine mount || SU rear diff mount || TT rear diff Rear mount || Whiteline anti-sway bar || AWR Endlinks || BC racing CO's || matt black OZ Ultraleggeras + Kumho ASX || Cobb AP || VEI boost || VEI oil Pressure/Water Temp. || AEM wideband || ApexI Turbo Timer || N2MB WOTbox || SM catchcan || BS delete+baffle kit || Spin on Oil filter conversion + Prosport sandwich ||
Other: Other mods are BS!
Sponsored by: STREETUNIT.COM check them out :thumbsup:
MStempted is offline
 Old 11-05-2008, 09:11 PM   #3
Strytnyne's Avatar
Posts: 214   (View Stats)
Strytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud ofStrytnyne has much to be proud of
looks like d40
Strytnyne is offline
 Old 11-06-2008, 12:43 AM   #4
sweetpickles's Avatar
Posts: 375   (View Stats)
sweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the world
Canon Rebel XTi w/a 18-55mm lense (per exif).
sweetpickles is offline
 Old 11-06-2008, 01:04 AM   #5
bombdotcom's Avatar
Posts: 816   (View Stats)
bombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the world
Groaned at 40 Times in 20 Posts
hows performance?
(RIP) 08' MS3---MODS:COBB AP- COBB SRI AND TIP- COBB RSB- COBB KNOB- CP-E TMIC- LIMITED EDITION HKS BOV- CORKSPORT DP AND TP- TRZ REARMOUNT- MD OCC- PTP IM COOLER KIT- COSWORTH BSD- EIBACH PROKIT- TWM SHIFTER BUSHINGS- JBR SHORT SHIFT KIT-
13' CWP MS3
bombdotcom is offline
 Old 11-06-2008, 04:07 AM   #6
SgtP's Avatar
Groans: 106
correct
Originally Posted by bombdotcom View Post
hows performance?
i haven't driven it yet. as soon as i installed the nano the ETS came off to ship out. today i put the stock ic on so i can drive to a shop to put the FMIC and tow plate on.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 11-06-2008, 07:21 AM   #7
desperado callado's Avatar
Posts: 170   (View Stats)
desperado callado is a splendid one to beholddesperado callado is a splendid one to beholddesperado callado is a splendid one to beholddesperado callado is a splendid one to beholddesperado callado is a splendid one to beholddesperado callado is a splendid one to behold
Artsy pix! Surprised you try to get reflected image within an image within an image within an image . . . .
Thanks for posting, looks great.
The mass of men lead lives of quiet desperation. What is called resignation is actually a lack of boost.
Mods: Defi Blue Racer Boost Gauge, 2nd Fiamm Horn (Low Tone) SU Mid-Pipe. Cobb Adjustable Shifter (now "functioning as intended" with 20mm allen bolts and locking nuts), CP-e Nano SRI. Sometime in the not-too-distant future: Airbox (?) and SU/ETS 3.25 TMIC
desperado callado is offline
 Old 11-06-2008, 08:05 AM   #8
zer0's Avatar
Posts: 50   (View Stats)
zer0 is a jewel in the roughzer0 is a jewel in the roughzer0 is a jewel in the rough
just ordered one from SU yesterday. hope i get it someday. LOL i need to go pray to the car gods.
zer0 is offline
 Old 11-06-2008, 08:48 AM   #9
SgtP's Avatar
Groans: 106
i think CPE shipped them to SU on wednesday so you should have it soon.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 11-06-2008, 08:48 AM   #10
I'm a caveman
gtlaw's Avatar
Posts: 758   (View Stats)
gtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the world
Groans: 68
Groaned at 22 Times in 16 Posts
is that a dry flow or oiled filter?
2015 MUSTANG GTPP
gtlaw is offline
 Old 11-06-2008, 08:49 AM   #11
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
Nice!
gsrtype1 is offline
 Old 11-06-2008, 08:56 AM   #12
SgtP's Avatar
Groans: 106
its oiled. ill take a pic of the paperwork that came with the filter when i get home.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 11-06-2008, 10:17 AM   #13
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
so ummm can i get some MS6 love?
jordan,
what would be needed to get this to work for me aside from the bracket?
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
superskaterxes is offline
 Old 11-06-2008, 10:21 AM   #14
SgtP's Avatar
Groans: 106
i wish there was a ms6 near me so i could see if it fit or what would be needed to make it fit.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 11-06-2008, 10:23 AM   #15
Must Have Teh 10's!
hello? P3!?!?!
 Old 11-06-2008, 10:48 AM   #16
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
jordan,
The bracket should be the only thing that'd be different right? I've already got one preordered from SU and just plan on fabbing up a bracket of my own.
2007 MS6 - broked & gone
2006 MS6 - less broked
RhoadBlock is offline
 Old 11-06-2008, 10:55 AM   #17
SgtP's Avatar
Groans: 106
it shouldnt be that hard. the rubber vib stop allows for enough adjustment. you should be able to make one with a piece of scrap metal.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 11-06-2008, 12:48 PM   #18
DeadWayt's Avatar
Posts: 186   (View Stats)
DeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the world
And honestly (and this is completely unofficial and not recommended by CP-E or any of their shops/installers *end disclaimer*) I bet you could safely drive this indefinitely without a proper mounting bracket. The Nano is very light and it really doesn't have anywhere to run to. Just make sure your clamps are tight.
Again, my words, not CP-E's.
'08.5 MS3 GT -- Metropolitan Grey
www.speedsportlife.com
DeadWayt is offline
 Old 11-07-2008, 11:41 AM   #19
SgtP's Avatar
Groans: 106
agreed
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 11-07-2008, 02:56 PM   #20
Must Have Teh 10's!
yah i know if i got this i would have no prob machining a bracket but its just nice to know were not forgotten.
would it really have been that hard for CPE to make a MS6 kit with just a tiny little bracket difference? i mean c'mon
 Old 11-07-2008, 11:30 PM   #21
skubidoobie's Avatar
Posts: 206   (View Stats)
skubidoobie has much to be proud ofskubidoobie has much to be proud ofskubidoobie has much to be proud ofskubidoobie has much to be proud ofskubidoobie has much to be proud ofskubidoobie has much to be proud ofskubidoobie has much to be proud ofskubidoobie has much to be proud ofskubidoobie has much to be proud ofskubidoobie has much to be proud of
So when will the color options be available? I'd like really like red for my MS3.
skubidoobie is offline
 Old 11-08-2008, 09:47 AM   #22
peruspeed3's Avatar
Posts: 326   (View Stats)
peruspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud ofperuspeed3 has much to be proud of
i have a injen cai. do u think it would be worth to get cpe sri? whats the difference?
peruspeed3 is offline
 Old 11-08-2008, 10:44 AM   #23
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
in so. CA, no....
2008 STi
Intake
Turboback
AP
danesti is offline
 Old 11-12-2008, 09:59 AM   #24
y2kc0wb0y's Avatar
Posts: 808   (View Stats)
y2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the world
hello? P3!?!?!
I can take a look tonight to see IF it will fit the MS6.
y2kc0wb0y is offline
 Old 11-12-2008, 10:54 AM   #25
priceprince's Avatar
Posts: 18   (View Stats)
priceprince has a spectacular aura aboutpriceprince has a spectacular aura about
Good work cowboy, I know a lot of us MS6ers will be eagerly awaiting your results...
priceprince is offline
 Old 11-12-2008, 12:09 PM   #26
DeadWayt's Avatar
They just needed a car to fit it on, that's all. CP-E has an in-house Speed3 for test fitting, but they don't have a Speed6.
Hopefylly y2k will get it all fixed up for you guys.
DeadWayt is offline
 Old 11-17-2008, 09:59 AM   #27
MSF Punished Member
FWD=WWD's Avatar
Posts: 200   (View Stats)
FWD=WWD is a name known to allFWD=WWD is a name known to allFWD=WWD is a name known to allFWD=WWD is a name known to allFWD=WWD is a name known to allFWD=WWD is a name known to all
update?... very interested for MS6... may just order one, and have a buddy machine a bunch of brackets for me...
lenient metal shop bosses FTMFW (especially 3-axis lathe, cnc water jetting, polishing and bead/sandblastic availability)
FWD=WWD is offline
 Old 11-23-2008, 10:55 AM   #28
lidokrantz's Avatar
Posts: 663   (View Stats)
lidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the world
Default Gomers Pyles
having run the CP-E CAI for 18 months and with the stock air box on the car now for a month, i finally have the CP-E Nano SRI on now. My impressions.
1) SRI is smoother down low, with the CAI feeling a little better up top in the rpms.
2) SRI is better looking, very nice looking piece, as you can appreciate the intake, with the CAI all you see is the tube when you open the hood.
3) SRI is quite a bit quieter than the CAI. You do not hear all that sucking/flushing sounds like you do from the CAI...I REALLY APPRECIATE THIS, AS THE CAI WAS A TAD ANNOYING AT TIMES.
4)SRI has no potential hydo lock issues... I never worried about this with the CAI, but it was in my thoughts when we get downpours.
5) IMO..the SRI will run better on my car in the winter and colder weather because on the warm air in the engine bay, and may have the adverse effect in the summer. We all no the Speed3 does not like the cold weather and i do think the SRI in the winter will run better than the CAI especially like to today at 20 degrees.
overall, if i had to do it again, i would buy the Nano...i just like looking at the intake, even if its just an intake and the benefits of it being quieter without all the sucking noises that i had with the CAI feels better to me, as well as being smoother down low. I do not mind giving up a couple of hp up top for the benefits of having this SRI.....a HIGH QUALITY PIECE for CP-E and as usual.....and not to knock Cobb, but the air staightner in this thing blows Cobbs away in quality. CP-E FTW!!!!!!!!!!!!!!!!!!!
Current.. 2009 BMW 135i Twin Turbo, Sedonna Red Metallic, M Sport Pkg, Premium Pkg, Cold Weather Pkg with heated seats, Xenons,M Sport steering wheel, BMW Factory Sport Exhaust..300hp, 300 Tq.. in reality..320 hp 320 tq stock
SOON: BMS JB3....tune, ICarbon rear diffuser, ....all under warranty...
Past/Sold...2007 MazdaSpeed3,CP-E TBE, CAI, Advan Rs Gunmetal, TWM STS with bushings TWM Desert Eagle shift knob,, Defi Amber boost gauge, HKS BOV with CP-E flange..also tried CP-E Nano SRI (MazdaSpeed CAI, Rota TQ Hyperblack, are FOR SALE 4 months old)
lidokrantz is offline
 Old 11-23-2008, 11:56 AM   #29
SgtP's Avatar
Groans: 106
good points.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 01-02-2009, 06:15 PM   #30
2008speed3's Avatar
Posts: 421   (View Stats)
2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world2008speed3 is the leader of the world
Groans: 707
Groaned at 127 Times in 108 Posts
What are the pros and cons of the pre-filter oiled filter and the pre-filter dry flow filter?
2008speed3 is offline
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f330/first-cp-e-nano-installed-w-pics-14689/
???? Mazda6.ru: ??? ? Mazda6 (?????6) - ????? AEM This thread Refback 02-01-2009 09:34 AM
M3club > Èíòåðêóëåð This thread Refback 01-23-2009 08:05 AM
???? Mazda6.ru: ??? ? Mazda6 (?????6) - ???????? ???????? ? ??????, ?????????? ?????? This thread Refback 01-22-2009 02:18 AM
Èíòåðêóëåð - M3club This thread Refback 01-22-2009 01:40 AM
Day of 1/3/2009: Top 50 of 203 Referring Pages This thread Refback 01-05-2009 02:54 PM
PG mani w/Tail EWG installed *pics inside whoosh@Realtune MazdaSpeed 3/6 - Turbo Induction 26 07-11-2015 10:49 AM
AWR transmission / passenger side / rear engine mounts (installed pics) whoosh@Realtune MazdaSpeed 6 - Engine, Transmission & Driveline 13 11-27-2008 10:47 AM
Cp-e Xcel Nano install and review w/ pics n vids copperkid Custom Performance Engineering (cp-e.com) 19 11-07-2008 02:53 PM
Pics of AEM CAI installed? Vinnie R 4 MazdaSpeed 3 - Engine, Transmission & Driveline 15 10-31-2008 10:40 PM
Thought I'd post some pics of the liquid/air ic installed... ATE BALLER MazdaSpeed 3/6 - Turbo Induction 18 09-23-2008 11:04 AM
Page generated in 0.47282 seconds with 39 queries
