Closed Thread
 Old 06-01-2009, 12:43 PM   #1
badams118's Avatar
Posts: 821   (View Stats)
badams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the world
Groaned at 126 Times in 71 Posts
Default Fuel Pump Whistle
I've noticed my fuel pump making a whistle or ringing sound when I let off the gas lately. It's as though it is releasing the pressure built up when I give it throttle. I can make it do this by revving it a bit at idle or while driving.
I also notice that my AFR gauge sweeps rich when I do this, which would be consistent with it releasing built up fuel pressure. I will try to get a data log & maybe a video of I can pick it up that way.
2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI
Whiteline F/R Sways | SPT SSK | TWM M1 Abrams
badams118 is offline
 Old 06-01-2009, 01:34 PM   #2
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Let me see if I understand...
When you let off the gas you hear a hissing sound coming from the fuel pump area under the hood, and your AFR gauge goes rich? That's definitely strange! Please do grab a log of the event if you can and we'll see if we can't figure out what's up.
www.cp-e.com is offline
 Old 06-01-2009, 02:09 PM   #3
badams118's Avatar
Thanks, I'll post something as soon as I have the chance. The sound is kind of like tapping a pipe with a wrench.
 Old 06-03-2009, 05:13 PM   #4
badams118's Avatar
Fuel pressure looks good. I am seeing 420psi at idle & 1600+ at WOT.
I'll try to get a video of the sound later.
Closed Thread
Am I already in need of a fuel pump? GongShow
Cobb Access Port/Maps
4 08-12-2009 01:34 AM
bad fuel pump? ebranch MazdaSpeed 6 - Engine, Transmission & Driveline 9 03-10-2009 10:49 AM
Fuel pressure dip: Do I need a new pump? Ferdball MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 37 12-27-2008 09:08 PM
Do I need a fuel pump. dread
13 12-14-2008 08:06 AM
which fuel pump to get? Buildabong MazdaSpeed 3/6 - Turbo Induction 20 10-15-2008 11:43 AM
Page generated in 0.23925 seconds with 22 queries
