Like Tree5Likes
  • 1 Post By Celestspeed3
  • 2 Post By Celestspeed3
  • 1 Post By DONOTBUGME
 Old 05-04-2013, 06:22 PM   #1
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
Default Gen2 Gauge Pod
Is there any chance there can be a production run of gauge pod for the Gen2 that's similar to the Evo X gauge pod you produce.
I'm looking to mount about 5 gauges in the car and visibly is greatly reduced with more than 2 gauges on the pillar.
The Following 3 Users Say Thank You to Celestspeed3 For This Useful Post:
bertrand_CX_7 (05-08-2013), rfinkle2 (05-09-2013), Sum1UDidntC (05-04-2013)
 Old 05-04-2013, 08:12 PM   #2
Sum1UDidntC's Avatar
Posts: 157   (View Stats)
Sum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond reputeSum1UDidntC has a reputation beyond repute
Put it above the gauge cluster and it'll still cause issues. Perhaps something like the gen 1 triple gauge pod but that wont block the nav./info screen.
2011 Black Mica MazdaSPEED3 // CS SRI // CS TIP // HKS SSQV-IV VTA w/ CP-E flange // CP-E FMIC // CP-E Triton CBE // CP-E Catted DP // CP-E HPFP // CP-E Stage 2 RMM // COBB AP With Lex Tunes // JBR SSP // JBR 88DM TMM //JBR 80DM PMM // JBR custom cylindrical shift knob // JBR SSB's // Rally Armor Mudflaps // ISC Coilovers and front end links // Denso ITV-22's // SPC Camber Arms // Michelin Pilot SuperSports // STRATIFIED LEX TUNED FTMFW
Mustang Dyno Results:
301WHP 334WTQ on 35% E85
282WHP 325WTQ on 92oct
Sum1UDidntC is offline   Reply With Quote
 Old 05-08-2013, 10:55 AM   #3
triphop631's Avatar
Posts: 1,191   (View Stats)
triphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the world
Groans: 30
From my understanding there is something in the works regarding this.
I haz Partz!!!!!!!!!!
triphop631 is offline   Reply With Quote
The Following 2 Users Say Thank You to triphop631 For This Useful Post:
Celestspeed3 (05-09-2013), rfinkle2 (05-09-2013)
 Old 05-08-2013, 11:10 AM   #4
manila's Avatar
Posts: 1,767   (View Stats)
Jealous that the gen1 and 6 guys have this
'12 MS3 Black Mica w/ Tech
 Old 05-09-2013, 08:39 AM   #5
Well I pulled the whole cluster apart this past weekend. There is enough room for me to month standard gauges cup to the top of the cluster. If something like this doesn't come out soon I'll just be doing that.
 Old 05-09-2013, 08:44 AM   #6
Andjo's Avatar
Posts: 937   (View Stats)
Andjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the world
I haz glow shift a-piller gauge thing and its not that bad for blocking visibility
GT3076 and supporting mods with Kozmic Motorsports Built motor and tune
FUTURE MODS: 6266 with V-Band everything
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
2013 TROLL CHAMPION "DYLANFYHN"
Andjo is offline   Reply With Quote
The Following User Says Thank You to Andjo For This Useful Post:
 Old 05-09-2013, 10:51 AM   #7
I need to mount 7 gauges. I have a pillar pod with 3 gauges already I didn't like the gauge placement.
rfinkle2 and Sum1UDidntC like this.
 Old 05-09-2013, 10:58 AM   #8
Yes please.
Celestspeed3 (05-09-2013), triphop631 (05-09-2013)
 Old 05-09-2013, 12:18 PM   #9
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
Groans: 266
Lol, they said they were working on this in 2010. Corksport said they would look into it too. One of the two sent me digital renditions. But nothing in over 3years. If you need one or two guages buy the ones from blockhead. There is no good place to put them due to the stupid placement on the navigate screen and that other worthless screen. @rfinkle2; @Celestspeed3; @triphop631;
Celestspeed3 likes this.
DONOTBUGME is offline   Reply With Quote
The Following 2 Users Say Thank You to DONOTBUGME For This Useful Post:
Celestspeed3 (05-10-2013), triphop631 (05-09-2013)
 Old 05-09-2013, 02:44 PM   #10
SparkySparks's Avatar
Posts: 1,314   (View Stats)
I've been thinking of making my own 3 gauge pod for the over the center vents but they would have to be small gauges to not block the screens in the dash or you could modify the vents them self to be a bit smaller and then you could fit a bigger pod but I like my AC.
On Order:
Coming Soon:
DIY Projects:
 Old 05-09-2013, 07:20 PM   #11
I would personally love something that I can just two way tape over the the screens right to the dash. I'll figure out where the wires go at that point. Nothing some nicely placed split loom can't fix.
 Old 05-10-2013, 12:14 AM   #12
Because racecar?
The Following User Says Thank You to Sum1UDidntC For This Useful Post:
 Old 05-10-2013, 02:28 PM   #13
Originally Posted by Sum1UDidntC View Post
Because racecar?
yes,
oil pressure
oil temp
water temp
trans temp
RPM shift light
EGT
Boost
I may add a fuel pressure gauge for port injection as well.
rfinkle2 (05-18-2013)
poss gen2 gauge pod solution austin102085 Mazdaspeed3/6 General Discussion 5 02-11-2011 02:07 PM
What kind of Belt Gauge, Tire Gauge or Scan Tool Should I Buy? Haltech Automotive News 0 04-08-2010 02:40 PM
Page generated in 0.32909 seconds with 27 queries
