Closed Thread
 Old 02-06-2009, 05:10 PM   #1
spnkr21's Avatar
Posts: 2,827   (View Stats)
Default help with the hks
So I installed the hks ssqv today with the cp-e flange and when I did a run after at wot my car jerks forword and loses all power. Then the power comes back for a sec the jerks forward again. This happened in third gear, it's around 25 deg out and I have the cp-e tbe and cai. Standback is on the way soon. Any help would be awesome. Thanks
spnkr21 is offline
 Old 02-06-2009, 05:41 PM   #2
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
cold weather fuel cut. welcome to the club
"08, I hate to break it to you, but if it gives kevin a boner, its porn"
NATOR PERFORMANCE
Nylon washer sponsered
mexicant is offline
 Old 02-06-2009, 05:47 PM   #3
spnkr21's Avatar
So will this go away when it gets warmer? Is there anything we can do to stop it?? By the way the hks is a bitch to put on
spnkr21 is offline
 Old 02-06-2009, 05:54 PM   #4
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
you recirc'd right?
skeeter149 is offline
 Old 02-06-2009, 05:57 PM   #5
lidokrantz's Avatar
Posts: 663   (View Stats)
lidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the worldlidokrantz is the leader of the world
the CP-E cold weather fuel cut flash. will solve your issue..... but i would check things out to make sure that going WOT in cold weather with the flash is safe, and if there is anything else you should be concerned with, i have also heard Cobb AP has a cold weather program as well.....i have the same valve, and indeed my bud MazdaJ had some playing around with the valve to get it on just right....not as easy as the Turbosmart was by a long shot, or the stocker for easy install...although being on the flange now, the HKS is easy to go on and off.
Current.. 2009 BMW 135i Twin Turbo, Sedonna Red Metallic, M Sport Pkg, Premium Pkg, Cold Weather Pkg with heated seats, Xenons,M Sport steering wheel, BMW Factory Sport Exhaust..300hp, 300 Tq.. in reality..320 hp 320 tq stock
SOON: BMS JB3....tune, ICarbon rear diffuser, ....all under warranty...
Past/Sold...2007 MazdaSpeed3,CP-E TBE, CAI, Advan Rs Gunmetal, TWM STS with bushings TWM Desert Eagle shift knob,, Defi Amber boost gauge, HKS BOV with CP-E flange..also tried CP-E Nano SRI (MazdaSpeed CAI, Rota TQ Hyperblack, are FOR SALE 4 months old)
lidokrantz is offline
 Old 02-06-2009, 06:00 PM   #6
spnkr21's Avatar
Yeah I am. It's kind of a crappy setup right now beacuse the hks isn't at the right angle so I gotta get some c ring pliers and fix it
spnkr21 is offline
 Old 02-06-2009, 06:04 PM   #7
spnkr21's Avatar
The stand back is on the way soon (backordered) so I'll look into the flash cuz it's never that warm in maine also why doesn't this happen with the stock bov???
spnkr21 is offline
 Old 02-06-2009, 06:31 PM   #8
ElBartoRex's Avatar
Posts: 1,186   (View Stats)
ElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the world
Are you sure the bpv is sealed on the flange and not leaking? I have the same bpv and don't experience these problems. I do get the cold weather cut, but I get that with the stock and the hks bpv.
ElBartoRex is offline
 Old 02-06-2009, 06:39 PM   #9
spnkr21's Avatar
I'm sure it's sealed at the flange. The only place it might not be is at the recirc fitting. I had a greedy type s on there before and same thing happened in the cold weather. It's really scary when it happens. I put the stocker back on and it doesn't happen. I think my stocker leaks though so may e that's why it doesn't happen. Another question I have is when the hks blows off do you hear like a sputtering sound? It almost sounds like comp surge but I think it's from the hks. Is that just how it sounds???
spnkr21 is offline
 Old 02-06-2009, 08:10 PM   #10
ElBartoRex's Avatar
if the car is sputtering with the HKS but runs fine with the stocker, its most likely the opposite-- it sounds like the HKS may be leaking.
The HKS valve definitely makes the car feel jerkier and less smooth between shifts, maybe this is what you are feeling? The HKS valve opens and closes about 100x faster than the stocker. The flutter sound is normal at low boost.
 Old 02-06-2009, 09:48 PM   #11
skeeter149's Avatar
Groans: 91
wow do you have a vac/boost gauge? is it holding boost and what is you vac looking like?
 Old 02-07-2009, 04:10 AM   #12
spnkr21's Avatar
No I don't have any guages but will be getting a dashhawk very soon
spnkr21 is offline
 Old 02-07-2009, 07:25 AM   #13
ElBartoRex's Avatar
yeah you really can't diagnose something like this when you are 'data logging' with your butt dyno. I say just leave the stocker on until you can figure it out.
Closed Thread
Page generated in 0.31236 seconds with 23 queries
