| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
![]() Join Date: Mar 2008 Location: abc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,081
Groans: 147
Groaned at 34 Times in 29 Posts
| Not Ranked : 0 score cold weather fuel cut. welcome to the club
__________________ "08, I hate to break it to you, but if it gives kevin a boner, its porn" ![]() NATOR PERFORMANCE Nylon washer sponsered |
(Thread Starter) | Not Ranked : 0 score So will this go away when it gets warmer? Is there anything we can do to stop it?? By the way the hks is a bitch to put on |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,297
Groans: 91
| Not Ranked : 0 score you recirc'd right?
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" |
![]() Join Date: Apr 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 247
| Not Ranked : 0 score the CP-E cold weather fuel cut flash. will solve your issue..... but i would check things out to make sure that going WOT in cold weather with the flash is safe, and if there is anything else you should be concerned with, i have also heard Cobb AP has a cold weather program as well.....i have the same valve, and indeed my bud MazdaJ had some playing around with the valve to get it on just right....not as easy as the Turbosmart was by a long shot, or the stocker for easy install...although being on the flange now, the HKS is easy to go on and off.
__________________ Current.. 2009 BMW 135i Twin Turbo, Sedonna Red Metallic, M Sport Pkg, Premium Pkg, Cold Weather Pkg with heated seats, Xenons,M Sport steering wheel, BMW Factory Sport Exhaust..300hp, 300 Tq.. in reality..320 hp 320 tq stock SOON: BMS JB3....tune, ICarbon rear diffuser, ....all under warranty... . Past/Sold...2007 MazdaSpeed3,CP-E TBE, CAI, Advan Rs Gunmetal, TWM STS with bushings TWM Desert Eagle shift knob,, Defi Amber boost gauge, HKS BOV with CP-E flange..also tried CP-E Nano SRI (MazdaSpeed CAI, Rota TQ Hyperblack, are FOR SALE 4 months old) |
(Thread Starter) | Not Ranked : 0 score Yeah I am. It's kind of a crappy setup right now beacuse the hks isn't at the right angle so I gotta get some c ring pliers and fix it |
(Thread Starter) | Not Ranked : 0 score The stand back is on the way soon (backordered) so I'll look into the flash cuz it's never that warm in maine also why doesn't this happen with the stock bov??? |
![]() Join Date: May 2008 Location: West Chester, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score Are you sure the bpv is sealed on the flange and not leaking? I have the same bpv and don't experience these problems. I do get the cold weather cut, but I get that with the stock and the hks bpv. |
(Thread Starter) | Not Ranked : 0 score I'm sure it's sealed at the flange. The only place it might not be is at the recirc fitting. I had a greedy type s on there before and same thing happened in the cold weather. It's really scary when it happens. I put the stocker back on and it doesn't happen. I think my stocker leaks though so may e that's why it doesn't happen. Another question I have is when the hks blows off do you hear like a sputtering sound? It almost sounds like comp surge but I think it's from the hks. Is that just how it sounds??? |
| Not Ranked : 0 score if the car is sputtering with the HKS but runs fine with the stocker, its most likely the opposite-- it sounds like the HKS may be leaking. The HKS valve definitely makes the car feel jerkier and less smooth between shifts, maybe this is what you are feeling? The HKS valve opens and closes about 100x faster than the stocker. The flutter sound is normal at low boost. |
Groans: 91
| Not Ranked : 0 score wow do you have a vac/boost gauge? is it holding boost and what is you vac looking like?
(Thread Starter) | Not Ranked : 0 score No I don't have any guages but will be getting a dashhawk very soon |
| Not Ranked : 0 score yeah you really can't diagnose something like this when you are 'data logging' with your butt dyno. I say just leave the stocker on until you can figure it out. |
