Like Tree5Likes
  • 1 Post By Menace1
  • 1 Post By jeopardy98
  • 1 Post By Moonshine Jack
  • 1 Post By BoominChu
 Old 02-18-2013, 11:36 AM   #1
Moonshine Jack's Avatar
Posts: 10   (View Stats)
Moonshine Jack is a name known to allMoonshine Jack is a name known to allMoonshine Jack is a name known to allMoonshine Jack is a name known to allMoonshine Jack is a name known to allMoonshine Jack is a name known to all
Default Help me decide between between stage 1 and stage 2 RMMs.
Hello all,
So, I've decided to upgrade my motor mounts, and based on everything I've read, I've decided to go with CP-E (full disclosure: partially because my CAI is CP-E as well, and my OCD impels me to have matching sets).
The decision I need help with is whether to use the stage 1 or stage 2 RMM.
The reason I'm torn is that, as much as I would like the performance gains of the stage 2, my car is also a daily driver in Las Vegas, which means a lot of stop-and-go driving and that the AC will be running full-time about 75% of the year. Additionally, I'm a family man, so I have to consider their comfort versus my desire for "More awesome!".
As such, if I go with the stage 1, it would be simply to use the 60 duro bushings for comfort's sake.
Based on Grumpyjap's review, however, the stage 2 is just awesome, AND it comes in a sweet, sweet anodized black. But the vibe increase IS a thing, even if not substantial, and I am a picky bastard. Some people seem to say it's negligible, others cite it as noticeable, but all agree it's there.
So, my question is this: Objectively, how substantial is the vibe increase for the stage 2 versus the stage 1 (60 duro)?
TL/DR: Being picky and OCD, will the vibrations from the stage 2 drive me insane? Is the 60 duro stage 1 going to be a significant enough reduction in vibes to warrant sacrificing what the stage 2 has to offer?
Moonshine Jack is offline   Reply With Quote
 Old 02-18-2013, 11:44 AM   #2
xI Leveler Ix's Avatar
Posts: 1,752   (View Stats)
Groans: 75
Buy Stage 2.
install it.
Make your decision.
if no likey, uninstall, Sell Stage2 buy Stage1.
if likey, Leave the RMM on and haz racecar.
STOCK AS OF 2015...
Old Stuff....
The Following 5 Users Say Thank You to xI Leveler Ix For This Useful Post:
DaDoctor (02-18-2013), Dmurray06 (02-18-2013), Dream20b (02-28-2013), El_Diablo (02-28-2013), www.cp-e.com (02-19-2013)
 Old 02-18-2013, 11:51 AM   #3
Menace1's Avatar
Posts: 946   (View Stats)
Menace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the world
Groaned at 40 Times in 21 Posts
go jbr 88 dur. there is very little I would buy from cpe. not saying its bad, because its not. might wanna get a better intake too. read that one doesn't flow very well, if that one has the silicone tip. its only slightly more flow then stock. there is way better flowing intakes. but yes the rmm is supposed to be very good.
2012 MS3 / Cobb AP/ JBR / STRATIFIED Stage 1 Tuned / Stock K04 / CPE HPFP / Maisonvi Heavy Shift Knob / JBR Powerpath Intake / JBR TIP / JBR BT / JBR BVH / JBR 88D RMM /
FOR NOW...
Menace1 is offline   Reply With Quote
 Old 02-18-2013, 12:31 PM   #4
sidekick's Avatar
Posts: 3,093   (View Stats)
If he is worried about vibes, I wouldn't suggest that. I have the 80A JBR and it has a pretty good amount of vibes at low RPM. It's not broken in yet, so I imagine it will get better with time, but 88A is probably not for him... 80A is the max I would go if you're worried about vibes.
What is the duro rating for the CP-E stage 2 mount?
Menace1 (02-18-2013)
 Old 02-18-2013, 12:47 PM   #5
Menace1's Avatar
I think its 70. read this. CP-E Stage 2 RMM Thrashed!
so if you are looking for a quiet mount. don't thrash yor car or this will happen sooner than later. I don't have any problems with cpe. I wanted racecar vibes and strength.
Hannibalspeed likes this.
FOR NOW...
 Old 02-18-2013, 02:14 PM   #6
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
I've been running my Stage 2 CPE RMM now for well over a year, with track time included, and have had zero issues (aside from the retaining screws backing out a bit a week after install due to a lack of threadlocker).
Just sayin...
OP:
I can say without a doubt that for what you're looking for, the Stage 2 CPE mount is the ticket.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 4 Users Say Thank You to Nliiitend1 For This Useful Post:
breakfstincluded (02-18-2013), El_Diablo (02-28-2013), Menace1 (02-18-2013), Moonshine Jack (02-18-2013)
 Old 02-18-2013, 04:12 PM   #7
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
I believe CP-E told me it was 65 duro, however, when I got my bushing replaced, this is what I found. I'm due soon for an oil change, I'll check out the bushing to see how it's holding up.
The Following 2 Users Say Thank You to 08.5MS3 For This Useful Post:
Menace1 (02-18-2013), Nliiitend1 (02-18-2013)
 Old 02-18-2013, 12:49 PM   #8
Keko's Avatar
Posts: 1,455   (View Stats)
Groans: 107
Groaned at 9 Times in 9 Posts
Normally I would recommend the JBR 88d dogbone, but in this case since you don't like vibes AND will be using A/C a lot I would go woth the CP-e Stage 2.
I tried to find the durometer of the CP-e stage 2 but I can't find it. I assume it's less than 88a so it shouldn't be that bad with vibes after it breaks in. After the JBR 88a RMM died down the vibes were not bad at all.
2012 MS3
Stratified 91
 Old 02-18-2013, 01:55 PM   #9
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
If you get the stage 2 I would gladly give you mine and some cash for it should you not like it.
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline   Reply With Quote
 Old 02-18-2013, 02:01 PM   #10
Thanks for the replies, all.
Based on what everyone's saying, I think I might end up just going with the stage 2. I did e-mail CP-E to see if they could actually give me a number on the durometer of the bushings, but who knows if they'll actually answer.
Worst case scenario, I end up taking thatsmrgimp2u up on his offer.
Thanks again!
 Old 02-19-2013, 01:45 PM   #11
KILLER_VIZ's Avatar
Posts: 451   (View Stats)
KILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the worldKILLER_VIZ is the leader of the world
Groaned at 28 Times in 14 Posts
Thanks again!
I run all three CP-e mounts and love them.(stage2 rmm, 75d sides) I just installed the side mounts over the weekend and I could tell the difference in my car right away. They are well worth the money. If you want your power to be transferred to where you want and not wasted you need to consider the three. Don't be cheap when it comes to your ride bro!
KILLER_VIZ is offline   Reply With Quote
The Following 2 Users Say Thank You to KILLER_VIZ For This Useful Post:
DaDoctor (02-19-2013), El_Diablo (02-28-2013)
 Old 02-18-2013, 02:04 PM   #12
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Stage 2... Shit is the bees knees.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 2 Users Say Thank You to CWP_MS3 For This Useful Post:
KILLER_VIZ (02-19-2013), Nliiitend1 (02-18-2013)
 Old 02-18-2013, 08:49 PM   #13
DaDoctor's Avatar
Posts: 276   (View Stats)
DaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the world
Only have experience with the Stage1 and Stage2 rmm from cp-e.
BUY STAGE2, worth every penny. Vibes were never an issue with this mount and I'm a hypochondriac.
If ur that worried about vibes, stay stock mounts
Sent from my HTC_Amaze_4G using Tapatalk 2
2011 Mazdaspeed 3 - Black Mica
NJSPEED3 PNP Manifold/Cp-e HPFP/Cp-e Catted DP/Cp-e FMIC/Cp-e Stage2 RMM 75a PMM and TMM/Cp-e Triton/CS Exhaust hangers/JBR SSP V1/3 Bar Map Sensor/Matt Jackson Harness/JBR Tigs
Suspension: KW V1 Coils/CS FSB & RSB/CS Front and Rear Endlinks/CS Aluminum Skidplate/CS Mid-Chassis Brace
Appearance:Lamin-X Smoke - Headlights, Taillights and reflectors/Corksport Antenna/TagArmur CF License Plate/Optima Yellowtop Battery/CS Interior Lighting Kit/DDM 3k/Block8head Defrost guage/ defi red boost guage
DaDoctor is offline   Reply With Quote
The Following 3 Users Say Thank You to DaDoctor For This Useful Post:
El_Diablo (02-28-2013), Moonshine Jack (02-18-2013), Nliiitend1 (02-18-2013)
 Old 02-18-2013, 09:00 PM   #14
jeopardy98's Avatar
Posts: 1,920   (View Stats)
jeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the world
Hey why don't you cough up $25 for VIP access on here while you are spending money on your car. That will 100x more valuable in the long run than your RMM. Oh and I suggest JBR 88 duro.
DaDoctor likes this.
Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed.
jeopardy98 is offline   Reply With Quote
The Following 2 Users Say Thank You to jeopardy98 For This Useful Post:
DaDoctor (02-18-2013), xI Leveler Ix (02-18-2013)
 Old 02-18-2013, 09:06 PM   #15
Ireland's Avatar
Posts: 1,419   (View Stats)
Ireland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the worldIreland is the leader of the world
Groaned at 119 Times in 22 Posts
Yep JBR dog bone for the win
sent while spool'n
2013 Tech Package // NVS tuned // 35% e85
DYNOCOM eddy current chassis dyno @ 332hp 400lbft
Ireland is offline   Reply With Quote
 Old 02-19-2013, 01:36 AM   #16
dhsieh911018's Avatar
Posts: 530   (View Stats)
dhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the world
Groaned at 55 Times in 35 Posts
jbr 88.
2011 VRM w/ tech pkg
SURE SRI+TIP
NGK LTR7IX-11
CPE TMIC
JBR rmm 88
Cobb AP
ATP dp
UR test pipe
Autotech FP internal
Moddiction Anvil shift knob
JBR solid shifter bushing
SURE ShortCut+CounterShift
Corksport LED light kit
Corksport lug nut set
Enkei Raijin
Corksport LED fog light kit
H&R Springs
UR axleback
Shell Rotella T6
Motorcraft XT-M5-QS
dhsieh911018 is offline   Reply With Quote
 Old 02-19-2013, 09:02 AM   #17
DaDoctor's Avatar
Did anyone actually read the novel in the OP? He doesn't want vibes, lol. Wouldn't jbr 88dur substantially increase vibes...especially with the AC running all the time?
The Following 2 Users Say Thank You to DaDoctor For This Useful Post:
Moonshine Jack (02-19-2013), Nliiitend1 (02-19-2013)
 Old 02-19-2013, 09:22 AM   #18
jeopardy98's Avatar
Yea I read it. NCE. Didn't donate. Doesn't want racecar. NCE. JBR 88
The Following User Says Thank You to jeopardy98 For This Useful Post:
 Old 02-19-2013, 10:52 AM   #19
So, CP-E was cool enough to respond to my questions about the duro used with the Stage 2:
"The Stage 2 mount has a 70 durometer bushing however the placement of the bushing is what makes the difference. The Stage 2 mount is actually smoother than the stage 1 70 duro."
So, that answers that. Despite the (numerous) recommendations to go with the JBR 88, I'm going to give the Stage 2 a try.
Thanks for all the replies.
The Following 6 Users Say Thank You to Moonshine Jack For This Useful Post:
DaDoctor (02-19-2013), El_Diablo (02-28-2013), KILLER_VIZ (02-19-2013), Menace1 (02-19-2013), Nliiitend1 (02-19-2013), www.cp-e.com (02-19-2013)
 Old 02-19-2013, 11:22 AM   #20
Nliiitend1's Avatar
I think you'll be happy with your decision.
2008 MS3 GT
2016 MX-5 Club
DaDoctor (02-19-2013), Moonshine Jack (02-19-2013)
 Old 02-19-2013, 12:47 PM   #21
DaDoctor's Avatar
I'm not sure if cp-e puts red loctite on their small hex bolts that hold the bushing in place or not. I def recommend taking the extra two minutes to do it yourself
The Following User Says Thank You to DaDoctor For This Useful Post:
 Old 02-19-2013, 12:51 PM   #22
BoominChu's Avatar
Posts: 188   (View Stats)
BoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Please let me correct you in saying when these mounts were first released cp-e™ did not use the loctite, HOWEVER now they do. Please do not take the screws out of the bushing surrounding plate. They are ready to rock right out of the box. Again DO NOT take them apart if you have any problems with them cp-e™ will warranty them.
BoominChu is offline   Reply With Quote
The Following 7 Users Say Thank You to BoominChu For This Useful Post:
CWP_MS3 (02-19-2013), DaDoctor (02-19-2013), El_Diablo (02-28-2013), Menace1 (02-19-2013), Moonshine Jack (02-19-2013), Raider (02-19-2013), sidekick (02-19-2013)
 Old 02-19-2013, 01:04 PM   #23
DaDoctor: Thanks for lookin out
BoominChu: Thanks for the clarification.
 Old 02-19-2013, 01:11 PM   #24
BoominChu's Avatar
no problem if you can't tell I work at cp-e™ and I usually do not post in our threads under my personal account but i figured you guys should know that we took care of that problem a while ago. Thank you.
The Following 3 Users Say Thank You to BoominChu For This Useful Post:
DaDoctor (02-19-2013), El_Diablo (02-28-2013), Nliiitend1 (02-19-2013)
 Old 02-19-2013, 08:11 PM   #25
DaDoctor's Avatar
I've been running the stage2 rmm and 70dur rmm and tmm for over a year now. Not once since owning them have I regretted it
 Old 02-28-2013, 12:49 PM   #26
Redlinez's Avatar
Posts: 117   (View Stats)
Redlinez is a splendid one to beholdRedlinez is a splendid one to beholdRedlinez is a splendid one to beholdRedlinez is a splendid one to beholdRedlinez is a splendid one to beholdRedlinez is a splendid one to beholdRedlinez is a splendid one to behold
I asked about this mount and was told I was wasting the extra $80. I guess you gotta weigh who's opinion is worth listening to. I probably should have bought it, but I guess I'll ride on my electric Ford Focus mount for now.....
13 Ford F150 Ecoboost......
Redlinez is offline   Reply With Quote
 Old 02-28-2013, 12:52 PM   #27
Nliiitend1's Avatar
Whomever told you it would have been a waste has never driven a car with the Stage 2 mount.
I guarantee it.
2008 MS3 GT
2016 MX-5 Club
 Old 02-28-2013, 02:51 PM   #28
Redlinez's Avatar
I will have to end up with one. I liked the design and idea of two isolation points.
 Old 02-28-2013, 03:07 PM   #29
Nliiitend1's Avatar
It still really only has one "isolation point."
The Stage 2 mount uses a rearward piece (the piece that is just like all the other mounts out there) that has no bushing at all. It's simply a solid piece of aluminum. The forward piece (that replaces the transaxle-mounted OEM bracket) holds the only bushing in the mount.
Regardless, the design is far superior to the one piece options out there, IMO.
2008 MS3 GT
2016 MX-5 Club
DaDoctor (02-28-2013), El_Diablo (02-28-2013)
 Old 02-28-2013, 06:45 PM   #30
iammike's Avatar
Posts: 1,415   (View Stats)
Had the stock mount with Corksport inserts.
Had the JBR dogbone.
Now have the CP-E Stage 2.
If you don't want a lot of vibes, go for Stage 2.
While the JBR did it's job very very well, the fact remains it is one of the most extreme of the mounts and as a result, will transfer a lot of vibes into the car. Only reason I sold my JBR is because it was too many vibes for me considering 90% of the time, I'm driving my car like a normal person...not Because Race Car.
The Corksport inserts did make a noticeable improvement over an untouched stocker and I never once heard the engine slap the firewall which I've heard complaints about on the stocker...but it was still pretty bouncy in there. Vibes were basically non-existant.
Just installed the Stage 2 today and I'm already in love. You will have some vibes...but they are more "smooth" than the vibes I had from the JBR dogbone and for a shorter period of time on normal launches. On the flip though, the engine doesn't feel like it's bouncing in my engine bay. I'd consider it a very very nice mount for your average daily driver. It hits a good middle ground.
That's just my 2 cents.
Mike
The Following 2 Users Say Thank You to iammike For This Useful Post:
Nliiitend1 (02-28-2013), TheRealDefman (02-28-2013)
 Old 02-28-2013, 09:44 PM   #31
TheRealDefman's Avatar
Posts: 532   (View Stats)
TheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the world
Ditto... almost word for word. I had inserts, then JBR, then cp-e stage 1, and now cp-e stage 2.
One of the best purchases I have ever made!! Like you, vibes are a no-go for me which is why the JBR lasted about a week before it was replaced. Had TRZ's in my Gen1, it was pretty unpleasant too.. If you end up TMM shopping, look very hard at the cp-e... another fine piece of gear!
2012 Black Mica with Tech package.
Chock full of goodies and Dizzy tuned
TheRealDefman is offline   Reply With Quote
The Following 2 Users Say Thank You to TheRealDefman For This Useful Post:
El_Diablo (03-01-2013), Nliiitend1 (03-01-2013)
 Old 02-28-2013, 07:41 PM   #32
Redlinez's Avatar
I thought I saw this mount with two EPDM bushings, I see now that I saw it wrong. Thought it had a bushing in both ends.
 Old 02-28-2013, 08:16 PM   #33
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
The stage 2 is the only mount that uses the bushing in the correct orientation for best performance and longevity.
I love my stage 2, no real vibes unless lugging around. Great mount and beautifully engineered. I believe they also use this mount on their race car.
Last edited by El_Diablo; 03-01-2013 at 05:10 AM. Reason: late night spelling error
The Following 2 Users Say Thank You to El_Diablo For This Useful Post:
Virtual Dyno - stage 1 soon to be stage 2 h0ckeyman 2010 MS3 - Dyno Sheets/Discussions 14 08-31-2012 05:31 PM
Cobb ATR Support
4 05-24-2009 07:52 PM
Page generated in 0.54990 seconds with 39 queries
