Closed Thread
 Old 01-19-2009, 08:04 AM   #1
spnkr21's Avatar
Posts: 2,827   (View Stats)
Default Help With removing CPE DP
So I'm trying to remove the CPE downpipe from my car so it can get a new cat put on it. The trouble I'm having is what i thought would be the easiest part. I can't get the DP to disconnect from the catback. everything is apart except i cant seperate the two. I tried to take the cat back off too but where it connects to the rear piece behind the muffler is stuck on too. Any tricks or ideas to getting these two pieces seperated?? THanks.
spnkr21 is offline
 Old 01-19-2009, 08:08 AM   #2
A nice size rubber mallet is your friend. The stainless steel shrinks and makes a tight seal on the pipes. So, basically, beat the shit out of it at the connections and it will break loose for you.
Haltech is offline
killa cam (01-19-2009)
 Old 01-19-2009, 08:53 AM   #3
spnkr21's Avatar
Alright well I guess I'll go buy a rubber mallet then. I tried as hard as I could to pull the two apart but couldn't get it. Thanks for the help.
spnkr21 is offline
 Old 01-19-2009, 02:08 PM   #4
spnkr21's Avatar
thanks for the help haltech it just needed a good pounding
spnkr21 is offline
 Old 01-19-2009, 02:33 PM   #5
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
Propane the outter tube side then water down the inner tube side then commence to pounding lol.
bioevolve is offline
 Old 01-19-2009, 04:03 PM   #6
killa cam's Avatar
Posts: 450   (View Stats)
killa cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the world
yup, beating the shit out of them always works. I have had this issue before, and a couple hits radially works to loosen it up, and then a couple hits axially will separate the two.
killa cam is offline
 Old 01-19-2009, 04:17 PM   #7
booya620's Avatar
Posts: 697   (View Stats)
booya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the world
sounds like a bitchy girl
booya620 is offline
 Old 01-20-2009, 06:58 PM   #8
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
if you don't happen to have a rubber mallet, a piece of wood works just about as well...
Sacrilicious is offline
Closed Thread
Removing driverside dash NJSPEED3 MazdaSpeed 3 - How-To's 11 01-20-2009 10:00 AM
How To Repair Car Rust, Removing Flywheel on GMC Jimmy, Transmission Problem on Dodge Grand Caravan, Idle Air Sensor on Haltech Automotive News 0 12-18-2008 01:10 PM
Removing COBB FSB... need help MS3 Ventura MazdaSpeed 3/6 - Suspension & Brakes 5 11-27-2008 05:46 PM
removing belts StewRat Drag Racing 5 09-03-2008 09:28 AM
Removing LP fuel lines?? Ghetto Mods MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 2 05-02-2008 06:40 PM
Page generated in 0.27670 seconds with 25 queries
