Closed Thread
 Old 02-20-2010, 04:43 AM   #1
erod550's Avatar
Posts: 467   (View Stats)
erod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the world
Default HPFP Question
Sorry if this is a dumb question, but is the CP-E HPFP the same for both the MS6 and MS3? I don't see part numbers on the website to verify it's the same pump. I'm trying to buy a used one and I want to verify if one off an MS6 will fit my MS3.
Sorry for the noob question.
2011 Mustang GT Premium 5.0
2009 True Red Mazdaspeed3 - Sold
Cobb SRI | Cobb TIP | Cobb AP | CP-E DP | SU TMIC | Denso ITV22 | PTP HPFP | Synapse Synchronic BPV | Saikou Michi OCC | SU 90A RMM | SU Side Mounts | TWM Stage 2 STS w/Bushings | Dashhawk
erod550 is offline
 Old 02-20-2010, 05:50 AM   #2
nutsac76's Avatar
Posts: 694   (View Stats)
nutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the worldnutsac76 is the leader of the world
Groans: 100
Groaned at 39 Times in 26 Posts
unfortunately you have the same motor so yes same hpfp.
Whats wrong with a cloned turbo?
nutsac76 is offline
Closed Thread
HPFP problems..... 9900rpm 2010 MS3 - Troubleshoot/Diagnostics 39 01-25-2010 08:29 AM
CPe HPFP installed vbt101 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 12 11-07-2009 05:40 PM
Randy HPFP QUESTION! Deadman MazdaSpeed 6 - Engine, Transmission & Driveline 2 12-30-2008 11:12 PM
CP-E HPFP Question... Deadman MazdaSpeed 6 - Engine, Transmission & Driveline 6 12-18-2008 04:19 AM
So if HPFP ticks, then what? MS3 Ventura MazdaSpeed 3 - Engine, Transmission & Driveline 14 12-05-2008 11:35 PM
Page generated in 0.24568 seconds with 21 queries
