 Old 02-01-2013, 09:01 AM   #1
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Default Ms6 front diff mount
How comes you guys make the rear but not the front one?
The Following User Says Thank You to Dizzy Turbo For This Useful Post:
Jh8909 (02-01-2013)
 Old 02-01-2013, 09:19 AM   #2
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
coming from the person who owns the records for quickest/fastest/lowest 60' on an MS6 (and MS3 for that matter), i dont have one and i feel it isent needed.
you DO however need the top diff mount and you would be an idiot not to go with CPE. ive had my mount since it came out 4 years ago and its been awesome. SURE's mount has fitment problems with an aftermarket sway bar and their bushings are known to fail after 10k miles.......
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
The Following 4 Users Say Thank You to superskaterxes For This Useful Post:
Dizzy Turbo (02-01-2013), doubleflusher (02-01-2013), Jh8909 (02-01-2013), LaraS (02-01-2013)
 Old 02-01-2013, 09:31 AM   #3
Already got their rear, wanted them to complete the set for me. But I did NOT know you stuck with the stock one, if you haven't broke it I never will get even close hah
The Following 2 Users Say Thank You to Dizzy Turbo For This Useful Post:
Jh8909 (02-01-2013), superskaterxes (02-01-2013)
 Old 02-01-2013, 05:11 PM   #4
theschrum's Avatar
Posts: 1,031   (View Stats)
Back in the day several people sheared front diff bolts and that is the main reason why Turbine Tech designed one with more mounting points. I am assuming that the rear diff mount solved that problem as well, so just the rear mount will suffice.
08 Speed 3|SOLD
The Following User Says Thank You to theschrum For This Useful Post:
rear diff "stiff diff" brace vs. rear diff front mount giordanos4 MazdaSpeed 6 - Engine, Transmission & Driveline 18 03-03-2011 08:38 AM
Page generated in 0.24904 seconds with 22 queries
