 Old 12-19-2012, 09:19 AM   #1
HammerChile11's Avatar
Posts: 45   (View Stats)
HammerChile11 has much to be proud ofHammerChile11 has much to be proud ofHammerChile11 has much to be proud ofHammerChile11 has much to be proud ofHammerChile11 has much to be proud ofHammerChile11 has much to be proud ofHammerChile11 has much to be proud ofHammerChile11 has much to be proud of
Groaned at 3 Times in 1 Post
Default New Installation of TMIC Gen 2
Dear CPE
Please take a look at the assembly of TMIC and shroud, that we spoke of yesterday. I have a 2011Gen 2 Mazdaspeed3. Something does not seem correct, as the top 1 inch of fins are covered by shroud. I see pictures with shroud farther down and not blocking any cooling fins, like the ETS version
Please advise if this is correct.
Thank You I attach 3 pictures.
Thank You,
Kevin Roberts
Forney, TX
Cobb AP, Cobb SRI, Cobb TIP, Autotech internals, CP-E TMIC,
CP-E Downpipe, Forge V2 BPV, NGK Colder Spark Plugs, Corksport Springs, JBR RSB, JBR RMM 80, Cobb Knob
Parts on the way: PermTune PCV double vent plate
Parts waiting to be installed: SSP Vented OCC
HammerChile11 is offline   Reply With Quote
 Old 12-19-2012, 09:30 AM   #2
Keko's Avatar
Posts: 1,455   (View Stats)
Groans: 107
Groaned at 9 Times in 9 Posts
Did a quick search seems they are all that way for genpu.
why didnt you search first?
2012 MS3
Stratified 91
MS3G35 (12-19-2012)
 Old 12-19-2012, 11:56 AM   #3
I did search, but not many are labeled as Gen 2 or Gen 1. Many also have custom shrouds, and there was a lot of problems with this early in 2011. So I really wanted CPE to answer me and explain why the shroud covers part of the fins...that doesn't make sense. Also I wanted to make sure that I received the correct shroud for my car and not the wrong one, as nothing is stamped. Also I reported to them that instructions were unclear and full of "typos" and unclear language. I tried to do this as PM , yesterday and they responded but I could not attach pics to PM for some reason.
Thanks for understanding and putting up with upside down pictures!
Kevin
 Old 12-19-2012, 11:58 AM   #4
deadlandxtreme's Avatar
Posts: 1,117   (View Stats)
Groans: 82
Mine fits that way.
 Old 12-19-2012, 12:03 PM   #5
Cpt_Rum-bo's Avatar
Posts: 897   (View Stats)
Cpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the worldCpt_Rum-bo is the leader of the world
Mine is that way also. You did it correctly!
Had: 2011 Black Speed3 - In speed heaven
Sold: 05 Miata MX-5 LS
Current: 2010 135i - bit of mods, tuned by me
Cpt_Rum-bo is offline   Reply With Quote
The Following User Says Thank You to Cpt_Rum-bo For This Useful Post:
HammerChile11 (12-19-2012)
 Old 12-19-2012, 12:05 PM   #6
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
Mine is also like that, however the instructions I received with my TMIC clearly implied that the shroud does not get installed on the Gen2.
The Following User Says Thank You to Mike@Stratified For This Useful Post:
 Old 12-19-2012, 12:20 PM   #7
Cpt_Rum-bo's Avatar
Damn, I just re-read the instructions and I thought it was the opposite, but you're right. Did you leave yours out?
 Old 12-19-2012, 12:26 PM   #8
Nope I installed mine as I think it makes the scoop more useful. Without it I don't think as much air would flow through it. I could be wrong...
 Old 12-19-2012, 12:32 PM   #9
That is what I thought too 1) Instructions clearly left out shroud for Gen 2
2) without shroud air is not funneled through fins
3) I may get the shroud cut so that all fins have air circulation.
Thanks guys for your quick answers....I'm glad I'm not the only one with doubts. There are many ways to turn the damn shroud around, but only way it lines up with the drilled holes...still doesn't make sense.
I'll have to "Nator It"...break out the duct tape!!
The Following User Says Thank You to HammerChile11 For This Useful Post:
Cpt_Rum-bo (12-19-2012)
 Old 12-19-2012, 01:05 PM   #10
warlord's Avatar
Posts: 756   (View Stats)
warlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the world
Groaned at 60 Times in 18 Posts
If you don't use the shroud you'll also melt the back edge of the rubber gasket on the underside of the hood scoop as it makes contact with the TMIC. Bitch gets hot, shroud insulates it a bit.
2018 Audi S6 Prestige. APR Tuned 575 AWHP (current)
2017 Audi A4 APR tuned 315 AWHP (sold)
2014 IS350 (sold)
2013 MS3 Stage2 E85 (sold)
2011 MS3 Stage2 (sold)
warlord is offline   Reply With Quote
The Following User Says Thank You to warlord For This Useful Post:
 Old 12-19-2012, 01:07 PM   #11
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
Groans: 266
Didn't they make a special shroud for the gen 2?
DONOTBUGME is offline   Reply With Quote
 Old 12-19-2012, 01:13 PM   #12
I thought there was one special for Gen 2, but I guess it is not that special. Maybe I'm wrong and somebody from CP-E will let us know. Thanks guys.
 Old 12-19-2012, 01:54 PM   #13
warlord's Avatar
Originally cp-e didn't make it with a shroud that's why the directions say no shroud needed. Then everyone bitched about the scoop gasket melting and air going around it and not through it so they started including a shroud. Meh, I tried mine with and without. Both heatsoak just as fast but with the shroud it cools down a little faster. IAT's are slightly lower without the shroud but I'd rather have the TMIC cool faster so I run mine with.
2014 IS350 (sold)
The Following 2 Users Say Thank You to warlord For This Useful Post:
Cpt_Rum-bo (12-19-2012), HammerChile11 (12-19-2012)
 Old 12-20-2012, 08:00 AM   #14
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Yes we're sorry about the old instructions that state not to use the shroud. We have to update them. There are specific gen1 and gen2 shrouds now as I had told you in a PM @HammerChile11.
@Warlord is correct. Originally we did not make the gen2 with a shroud, but we made one due to the demand for one.
Website: www.cp-e.com
 Old 12-20-2012, 10:59 AM   #15
Thank you CPE for chiming in! I do like the product, however I think that with all your stuff i'm going to have to change my tires faster...because race car!
www.cp-e.com (12-20-2012)
 Old 12-20-2012, 03:09 PM   #16
Glad you like it. Sorry about costing you extra money for tires, but at least you'll have fun doing it!
 Old 04-06-2013, 09:47 AM   #17
mspeed313's Avatar
Posts: 28   (View Stats)
mspeed313 is a jewel in the roughmspeed313 is a jewel in the roughmspeed313 is a jewel in the rough
Groaned at 6 Times in 3 Posts
Can you guys PM me the PDF version of the installation instructions?
mspeed313 is offline   Reply With Quote
TMIC > FMIC > back to TMIC - my journey dale_gribble Mazdaspeed3/6 General Discussion 95 12-14-2012 04:58 AM
Wot/Box Installation wake2011 2010 MS3 - ECU Computer Tuning 0 05-20-2012 12:43 PM
HP Gains- fully bolted w/stock TMIC vs. FMIC/bigger TMIC Chimmike MazdaSpeed 3/6 - Turbo Induction 6 07-04-2011 03:18 PM
Page generated in 0.35957 seconds with 29 queries
