Closed Thread
 Old 05-01-2009, 03:09 PM   #81
Boost Whore
Unoriginalusername's Avatar
Posts: 1,757   (View Stats)
Unoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the world
Groans: 223
Originally Posted by Scatt Nasty View Post
i can haz 400whp on stock internals ?
for a few weeks maybe yes
"God created turbo lag to give v8's a chance"
Unoriginalusername is offline
 Old 05-01-2009, 03:12 PM   #82
medieval's Avatar
Posts: 213   (View Stats)
medieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the world
Thank you CPE.
One of the problems the Mazdaspeed has is reversion. Many are going down the route of running a larger compressor side turbo (ATP turbos) while still using the stock turbine configuration. To make it simple, the stock turbine A/R in relation to the compressor is causing some issues that many are not looking at. In layman's terms, you can only flow as much as the turbine will allow regardless of how big you get on the compressor. Since our motor is a 4 stroke, valve overlap is present. With that being said, so will reversion. This is why many are falling below the 400whp mark.
Manifold design:
A turbo uses the energy present in the exhaust pulse to produce boost, so the faster and more efficiently the manifold can deliver exhaust pulses from each cylinder to the turbo, the quicker the turbo will spool up and produce boost.
The idea behind keeping each exhaust pulse separate to the collector is to maximize efficiency to control and minimize the turbulence created when the exhaust pulses merge.
Uncontrolled turbulence equals lost energy. Lost energy is when the exhaust gas pulses lose their direction and cannot deliver full and controlled punch to the turbine.
A turbo manifold design that creates turbulence inside the manifold causes reversion, energy loss and increased exhaust gas temperatures. (The added heat will burn exhaust valves)
Reversion is a normal condition in a 4 stroke engine. It is most predominant in higher horsepower engines. When the piston reaches top dead center (TDC) on the exhaust stoke, there is valve overlap.
The exhaust valve remains open for a short period of time as the piston is going down on what is called the intake stroke. This causes a negative pressure pulse (vacuum) in the turbo manifold that is drawn back into the combustion cylinder (reversion).
The effects of reversion:
The engine becomes prone to detonation.
The engine power decreases due to charge contamination.
Charge contamination occurs when hot, thin exhaust is pumped back into the combustion chamber when the manifold cannot exhaust it efficiently. -properly.
Testing shows a log style manifold has roughly a 3-1 pressure ratio (3 psi of exhaust pressure Vs 1 psi of boost pressure)
Simply put, your exhaust pressure is much greater than your charge pressure (boost). During the overlap period, exhaust is forced back into the combustion chamber.
A 4-1 pyramid collector manifold is superior to a log manifold style, non-collector style, and cast manifolds for the simple fact that turbulence is limited to one point instead of two, maximizing the energy potential. This can result in faster turbo spool up, and potentially more energy to create boost.
Besides minimizing the lost energy, reducing turbulence also has another desirable effect: the creation of a freer flowing exhaust path for the engine.
We all know the freer the flow the more HP you will make. A properly designed collector style manifold will help evacuation of exhaust gasses from the combustion chamber and minimizing energy loss that is normally lost in this process.
This also means more of the exhaust gas is expelled on each exhaust stroke of the crankshaft, which is known as cylinder scavenging.
You must maintain exhaust pulse velocity from the cylinder head to the collector in a manifold. This is done by designing a properly sized collector in relation to the primary runner diameter.
The design of the collector itself can dictate what happens to the exhaust pulses after they reach the collector. The shape and length of a collector, in relation to the secondary runner, can promote a venturi effect, which positively affects the velocity of the exhaust pulses heading towards it in the primary runners.
Individual exhaust pulses reach the collector at different times due to the way that a four-stroke engine works. For one rotation of the crankshaft, while one pulse is entering the collector, other ones are at different points along the primary runner lengths of a manifold. When a pulse enters the collector, it expands due to the greater volume found there in the collector (now a low pressure).
The localized expansion of this exhaust pulse creates a suction effect on the other primary runners that converge at the collector, thus further helping the exhaust pulses in those runners to maintain as much velocity as possible.
However, just like how the exhaust pulses under pressure in the primaries seek out the relatively low-pressure collector, the pulse that is expanding in the collector will try to enter the other primary runners at the collector.
As the expanding gas from the primary enters the collector the other primary exiting would then present a restriction to the pulses moving down the primaries, instead of helping them. (Reversion)
Thus, a necessary component in the collector is an anti reversion wall (4-1 Pyramid).This is the wall (the pyramid) present in the collector design that presents a barrier to the expanding gas in the collector, discouraging it from entering the other primaries.
Keeping the expansion in the collector and not in the other primaries that are trying to deliver their exhaust pulses helps low back pressure and restrictions. Thus, a collector must be much more than just a meeting place of the individual exhaust pulses. Without a 4-1-pyramid collector or equal to, the collector can actually slow down the exhaust pulses in the primaries. Slow it down and you make it hard for the engine to breath freely.
If we keep it basic and look at just restriction ideas you will see why a tubular manifold with a 4-1 pyramid collector will create less resistance and make more power day in and day out (if designed right). Less restriction means more power.
medieval is offline
The Following 10 Users Say Thank You to medieval For This Useful Post:
94jedi (05-13-2009), badams118 (05-05-2009), Crossbow (05-02-2009), darkstarmotorsports (05-03-2009), Kennosuke (05-03-2009), lidokrantz (05-01-2009), MarkyMark (05-01-2009), psychophyr (05-01-2009), TruboPower (05-19-2009), xcoldricex (05-18-2009)
 Old 05-01-2009, 03:23 PM   #83
MarkyMark's Avatar
Posts: 1,624   (View Stats)
Groans: 62
Yup.
MarkyMark is offline
The Following User Says Thank You to MarkyMark For This Useful Post:
Smoker6 (05-01-2009)
 Old 05-01-2009, 04:23 PM   #84
killa cam's Avatar
Posts: 450   (View Stats)
killa cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the world
↑↑ to your avatar
killa cam is offline
The Following User Says Thank You to killa cam For This Useful Post:
mdogg (05-01-2009)
 Old 05-01-2009, 04:31 PM   #85
Smoker6's Avatar
Posts: 984   (View Stats)
Smoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the world
That avatar is hot.
'06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s |
CPE CAI, SU MM, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3 (not installed), GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler, DMH 3" exhaust cutout.
Smoker6 is offline
 Old 05-01-2009, 06:01 PM   #86
smakdown61's Avatar
Posts: 1,069   (View Stats)
smakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the world
Groaned at 37 Times in 23 Posts
I was about to read that, then i saw mark's avatar, then i had to run to the bathroom....
smakdown61 is offline
 Old 05-01-2009, 06:28 PM   #87
crazyitalian041's Avatar
Posts: 611   (View Stats)
fapfap.
Fully Built short and long block biatches
Sponsored by Cp-e and built by P3.
"giddy-up"
crazyitalian041 is offline
 Old 05-01-2009, 07:49 PM   #88
phailerider's Avatar
Posts: 4,639   (View Stats)
fapfap.
why the hell arent you at the track? i thought you guys were going to MIR tonight?
phailerider is offline
 Old 05-01-2009, 07:51 PM   #89
Deadman's Avatar
Posts: 868   (View Stats)
please say you went...
Deadman is offline
 Old 05-01-2009, 07:54 PM   #90
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
they couldn't cause they got swine flu
bova is offline
The Following 2 Users Say Thank You to bova For This Useful Post:
boosted3 (05-01-2009), MarkyMark (05-01-2009)
 Old 05-01-2009, 08:08 PM   #91
I couldnt go, work unfortunately has me bound, tomorrow im going, tonight is just a test night.
"giddy-up"
 Old 05-01-2009, 11:01 PM   #92
howd the test go? its 1am are they still testing? with charles driving they were bound to bust out a 120mph run!! somebody cough it up!!
 Old 05-02-2009, 08:08 AM   #93
so no times... were they just screwing around and today is the day?
 Old 05-02-2009, 07:46 PM   #94
Boost Whore
Groans: 223
time slip or ban lol
 Old 05-03-2009, 09:24 PM   #95
Kennosuke's Avatar
Posts: 55   (View Stats)
Kennosuke will become famous soon enough
I can't wait for a full CP-E kit to come out derived from Robbie's setup. (|:
~ "I simply do what I can, when I can, with what I've got."
Kennosuke is offline
 Old 05-03-2009, 09:29 PM   #96
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Great post, thanks for sharing.
Design is offline
 Old 05-12-2009, 09:32 PM   #97
SPD6Tuner's Avatar
Posts: 391   (View Stats)
SPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant futureSPD6Tuner has a brilliant future
Ill be making 400whp one day When my head is built.
SPD6Tuner is offline
 Old 05-21-2009, 08:37 AM   #98
hey jordan... can we get an update on the car. whats in progress on this sucker!!
 Old 05-21-2009, 09:46 AM   #99
Fa5t's Avatar
Posts: 224   (View Stats)
Fa5t is the leader of the worldFa5t is the leader of the worldFa5t is the leader of the worldFa5t is the leader of the worldFa5t is the leader of the worldFa5t is the leader of the worldFa5t is the leader of the worldFa5t is the leader of the worldFa5t is the leader of the worldFa5t is the leader of the worldFa5t is the leader of the world
I hope they got a chance to run it. Seems like things really died down.
Originally Posted by whoosh View Post
You dipped your peepee in fail sauce.
Fa5t is offline
 Old 05-21-2009, 10:01 AM   #100
Deadman's Avatar
hellllo?
Deadman is offline
 Old 05-21-2009, 10:29 AM   #101
shadesofgray19's Avatar
Posts: 794   (View Stats)
Must have gotten tied up with other things, but for how stoked they were, you would think they would have reported back with some additional information by now. Usually no news is good news, unless your boasting maximum power numbers. One has to wonder, are they really busy with other things, disappointed with the numbers on their dyno and working on doing better before reporting, or something else.
shadesofgray19 is offline
 Old 05-21-2009, 10:29 AM   #102
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
We've been using the car for engine mount development while we were diagnosing an electrical issue that has since been addressed. Jason performed a pressure test on the intake tract today to check for leaks and we found that the BOV gasket blew out, so we're trying to source some new ones.
We also need to spend some more time on the boost control before we can go for big power numbers because it's still a little unstable in the top-end. So we'll probably need a few days of work on boost control before we can start putting out more exciting dynos.
www.cp-e.com is offline
The Following 3 Users Say Thank You to www.cp-e.com For This Useful Post:
phailerider (05-21-2009), SharkDiver (05-21-2009), xcoldricex (05-21-2009)
 Old 05-21-2009, 11:27 AM   #103
thanks jordan!!
 Old 05-21-2009, 01:30 PM   #104
94jedi's Avatar
Posts: 2,200   (View Stats)
94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world
Groaned at 7 Times in 5 Posts
damn...any timeslips yet?
BONE STOCK.
94jedi is offline
 Old 05-21-2009, 01:57 PM   #105
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
need those mounts now!
xcoldricex is offline
 Old 05-24-2009, 11:20 AM   #106
all4bspinnin's Avatar
Posts: 188   (View Stats)
all4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant futureall4bspinnin has a brilliant future
so what was the final verdict on the turbo setup?
all4bspinnin is offline
 Old 07-06-2009, 06:36 AM   #107
Flightmedic's Avatar
Posts: 105   (View Stats)
Flightmedic is a splendid one to beholdFlightmedic is a splendid one to beholdFlightmedic is a splendid one to beholdFlightmedic is a splendid one to beholdFlightmedic is a splendid one to beholdFlightmedic is a splendid one to beholdFlightmedic is a splendid one to beholdFlightmedic is a splendid one to behold
What turbo did they go with? The post says they found the perfect one but doesnt say which one it was...
Flightmedic is offline
 Old 07-06-2009, 08:11 AM   #108
Deadman's Avatar
update on this?
Deadman is offline
 Old 07-13-2009, 11:11 PM   #109
morgan2112's Avatar
Posts: 29   (View Stats)
morgan2112 is on a distinguished road
Groaned at 7 Times in 4 Posts
Originally Posted by Deadman View Post
update on this?
Any new NEWS????
morgan2112 is offline
 Old 07-14-2009, 05:27 AM   #110
I believe P3 and Robbie just scrapped practically the whole setup. Here's the new parts list.
Creative Custom Tubular Exhaust Manifold
Creative FMIC piping (2.5 inches)
Creative 3.5 Inch Downpipe
Precision FMIC Core
Precision SC61-62 T3/T4 Turbo
Tial Alpha-Q 50mm Bov
Tial 38mm EWG (routed back into the DP)
This was posted on M3F and was linked in the P3 "Robbie Update" thread. Also, they now plan to hit 600 hp with that setup. This will never happen without at least a performance IM and larger TB if this is even possible on the stock fuel injecters and cams.
 Old 07-14-2009, 08:57 AM   #111
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
fail thread
'08 CWP MS3 w/ T3 3071r
802MS3 is offline
bioevolve (07-14-2009)
 Old 07-14-2009, 10:09 AM   #112
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
Originally Posted by opt_ms3 View Post
fail thread
+1
bioevolve is offline
 Old 07-14-2009, 11:12 AM   #113
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
The stock head cant flow that much air lol, I have had it flow tested. Even with the massive port work and big valves that I put in it *might* flow 600hp but it isnt too likely.
You need .500" lift cams to even have a chance at flowing that much air.
I know the stock TB is flow limited to 420hp, and I imagine that the IM is about the same.
2006 Mazdaspeed 6
06Speed6 is offline
802MS3 (07-14-2009)
 Old 07-14-2009, 03:06 PM   #114
SPD6Tuner's Avatar
Somebodys gotta start working on some new parts for this car. If 400hp is gonna be the limit than that sucks.
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f330/official-release-400hp-beyond-26671/
Day of 7/14/2009: Top 50 of 304 Referring Pages This thread Refback 07-15-2009 08:04 AM
Day of 7/11/2009: Top 50 of 196 Referring Pages This thread Refback 07-13-2009 07:59 AM
Day of 7/6/2009: Top 50 of 258 Referring Pages This thread Refback 07-07-2009 07:58 AM
New to Mazdas - Page 2 - MN Mazda Forums This thread Refback 06-08-2009 10:14 PM
Day of 5/18/2009: Top 50 of 194 Referring Pages This thread Refback 05-19-2009 08:13 AM
Day of 5/13/2009: Top 50 of 221 Referring Pages This thread Refback 05-14-2009 08:43 AM
Day of 5/7/2009: Top 50 of 207 Referring Pages This thread Refback 05-08-2009 08:32 AM
Day of 5/6/2009: Top 50 of 204 Referring Pages This thread Refback 05-07-2009 08:19 AM
Day of 5/5/2009: Top 50 of 222 Referring Pages This thread Refback 05-06-2009 07:58 AM
Day of 5/2/2009: Top 50 of 151 Referring Pages This thread Refback 05-04-2009 08:20 AM
Day of 5/1/2009: Top 50 of 201 Referring Pages This thread Refback 05-02-2009 06:54 PM
Day of 4/30/2009: Top 50 of 232 Referring Pages This thread Refback 05-01-2009 08:45 AM
Day of 4/29/2009: Top 50 of 209 Referring Pages This thread Refback 04-30-2009 08:32 AM
MS3 over 400HP on Dyno - Carolina Mazdas This thread Refback 04-29-2009 10:57 AM
Day of 4/28/2009: Top 50 of 242 Referring Pages This thread Refback 04-29-2009 07:42 AM
2010 Impreza News, Rumours and Requests - Page 13 - NASIOC This thread Refback 04-29-2009 01:36 AM
Scion prices tC Release Series 5.0 Haltech Automotive News 0 02-09-2009 03:00 PM
1.03 release date? Death-From-A-Mile
Cobb Access Port/Maps
62 11-23-2008 08:10 AM
Mazdaspeed 6 Wotbox official release! jay@n2mb Mazdaspeed3/6 General Discussion 70 10-30-2008 07:00 PM
hood release broke bova MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 04-26-2008 01:14 PM
Wii Fit Priced at $89.99 for May 19 U.S. Release Haltech Computers & Technology News 0 04-16-2008 07:10 AM
Page generated in 0.50821 seconds with 43 queries
