| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() | | #41 | ![]() |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
| Not Ranked : 0 score
Yeah, brake cleaner will work great if they are all gunked up. Wire brush should work fine but be gentle. Also while you have the plugs out double check the gap. If they're anymore than like 0.032" that may have contributed to the misfire as well. I'll be curious to know what you find. And dude, I didn't read your post closely enough last time. Have you not tightened that sensor down with ah wrench yet? I know it's tough to get at but you really really need to get that taken care of asap. What is the issue exactly? Can you not even get an open ended wrench on there? | |
![]() | | #42 | ![]() |
![]() Join Date: Nov 2010 Location: Stormville, NY
Rep Power: 1415 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,027
Groans: 155
(Thread Starter) | Not Ranked : 0 score Alright, so I finally got the sensor tightened up on it Saturday. About 130 miles driven on it since. The codes I cleared last week and no CEL since but should I rest the ECU again or just ride it out as is? I did not have time to pull the plugs but I gave it a few WOT runs after it was tightened down so hopefully that cleans up the plugs enough but I will check them before the week is out. |
![]() | | #43 | ![]() |
![]() | | #44 | ![]() |
Groans: 155
(Thread Starter) | Not Ranked : 0 score Ok, so I', l;ate with the update. I got it tightened down a couple fo weeks ago and all was fine until last night when I got anohter CEL. I had it checked and it is now the P0421 - Warm up Catalyst Below Threshold Bank. I clear it out but the CEL came back on tonight. WTF? |
![]() | | #45 | ![]() |
![]() | | #46 | ![]() |
![]() Join Date: Dec 2009 Location: Cincinnati, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,608
Groans: 215
| Not Ranked : 0 score that says your cat isnt working. Its CPE's problem now, you need to tell them that. I have the same code with their catless pipe.
__________________ 2011 DGM STI Sedan - Fully Bolted FP Green Setup 368WHP / 335WTQ SOLD: Black Mica 2010 MS3 - Tech Package -CPE Catless DP - CS CBE - SURE Aeros - SURE Sidewinder - TS BPV - CPE HPFP - JBarone Shifter Bushings - TRZ RMM - MD OCC - Progress RSB - DashDAQ - 18x8.5 +45 Rays Gram Light 57F - 235/40 Potenza RE760 |
![]() | | #47 | ![]() |
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
| Not Ranked : 0 score Unfortunately, it should be noted that catalysts are fragile pieces. If you were running around excessively rich for an extended period of time (due to your original problem, and loose secondary oxygen sensor), you may have damaged the catalyst, causing the in-efficiency fault. If you would like to email me on the issue, I will see what we can do. smarques@cp-e.com -Sander
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe |
![]() | | #48 | ![]() |
| Not Ranked : 0 score If you have a P0420 with a cat-less down pipe, this is to be expected, as there is no cat to measure the efficiency of.
![]() | | #49 | ![]() |
Groans: 215
| Not Ranked : 0 score Im aware
![]() | | #50 | ![]() |
Groans: 155
![]() | | #51 | ![]() |
![]() Join Date: Dec 2008 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 541
| Not Ranked : 0 score I just started throwing a P0421 code with my CP-E catted downpipe. I have had the DP for 30,000 miles ish I would say. I have cleared the code a couple times and it comes back after a day. Any ideas?
__________________ GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP Bitwise Motorsports http://www.bitwise-motorsports.com - Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!) |
![]() | | #52 | ![]() |
Groans: 155
(Thread Starter) | Not Ranked : 0 score I'm gonna seafoam it in a couple of weeks when I change the oil since the can mentions cleaning the cat. |
![]() | | #53 | ![]() |
| Not Ranked : 0 score If you guys have made sure that the o2 sensors are tight, and that the exhaust system is free of leaks, we will take the catted DP's back with a copy of the original purchase receipt and either repair or replace the cats under warranty. Any questions on this please email me at smarques@cp-e.com -Sander
| The Following 4 Users Say Thank You to www.cp-e.com For This Useful Post: |
![]() | | #54 | ![]() |
Groans: 215
| Not Ranked : 0 score At least some vendors here stand by their work
| The Following 3 Users Say Thank You to smitty5788 For This Useful Post: |
![]() | | #55 | ![]() |
| Not Ranked : 0 score Thanks Sander. I am sure mine is good as its been installed for over a year. I will let you know what I decide to do. For now I am going to see how it goes as its not affecting driving. Will replace it probably when I replace the turbo. Only want to do the install once. I really do love CP-E's customer service.
| The Following User Says Thank You to MattJackson86 For This Useful Post: | www.cp-e.com (01-04-2011) |
![]() | | #56 | ![]() |
Groans: 155
(Thread Starter) | Not Ranked : 0 score Thanks Sander. I'll still try to Seafoam it and see what happens. I don't have another car so I can't just take it off and wait for it to come back but if you are having another dyno day in the near future, I could come down there a day or two beforehand to get it done. I was planning on this anyway since I wanted to get tuned also. |
![]() | | #57 | ![]() |
Groans: 155
(Thread Starter) | Not Ranked : 0 score Ok, for Sander and anyone else that may be concerned. This weekend, I cleared the P0421 code out again and once again saw that I had the misfire code as well. So, with codes cleared, I seafoamed after getting it good and hot, cleared it out with a few strong highway pulls in 4th and then cleaned and regapped all 4 plugs. Two of the plugs were pretty blackened. I cleaned out the MAF sensor too for good measure. So far, I have put 180 miles with no CEL but 250 has been the magic number. I'll hit that in a couple of days and report back. Hopefully the DP can be saved. |
![]() | | #58 | ![]() |
| Not Ranked : 0 score Thanks, just keep me posted.
![]() | | #59 | ![]() |
Groans: 155
(Thread Starter) | Not Ranked : 0 score Ok, the CEL is back. Any other ideas before returning the DP? |
![]() | | #60 | ![]() |
| Not Ranked : 0 score Try resetting the ECU by disconnecting the battery. I know that may sound odd but I will say that I have not received that CEL code in over 1500 miles as shortly after I posted I reset the ecu.
| In stock now CNT Racing Mazdaspeed 3 catted and non Catted downpipe | ERZperformance | ERZPerformance | 325 | 08-04-2013 05:13 PM |
| Catted or non Catted dp? | MSP611 | MazdaSpeed 3/6 - Turbo Induction | 18 | 11-28-2010 05:32 PM |
