| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
![]() Join Date: Nov 2010 Location: Stormville, NY
Rep Power: 1415 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,027
Groans: 155
| FY"IED"N ![]() Join Date: Nov 2010 Location: Alexandria, VA
Rep Power: 602 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 919
| Not Ranked : 0 score read through this. Check Engine Light (P2098) i know the code is a bit dif but its a place to start. cold weather also leans out trims
__________________ 2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint. ![]() |
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
| Not Ranked : 0 score That is actually a pretty comprehensive thread. The P2096 fault code basically identifies that the rear (post-cat) oxygen sensor is reading irregularly low voltage (or a lean condition, same thing). On newer cars the rearward oxygen sensor is actually also responsible for fuel trims, along with the forward sensor. It would be helpful to see a log of your rearward oxygen sensor, relative to your forward sensor, to see if we can identify a problem with the sensor, or if the cat is plugged. Sander
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe |
| The Following User Says Thank You to www.cp-e.com For This Useful Post: | skeeter149 (12-05-2010) |
Groans: 155
| The Following User Says Thank You to Tommy For This Useful Post: | SilverDemon (11-30-2010) |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4725 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
The logs that were posted in that thread were the voltage readings from the 2nd O2 sensor. Mine had the sensor already set at 90*(with a 1" extension on the bung) to the exhaust flow, and smitty's was set at an odd angle to the exhaust flow. My sensor readings came back with a rang of .2v - .9v depending on the load of the engine, smitty's car came back with a reading .0v - .9v, again, depending on the load of the car. It seemed that anytime the O2 sensor reading would drop below .2v after the car is up to normal operating temp, it would throw the P2196 code. In turn the ECU would dump more fuel to help warm up the cat. causing mileage to suffer, fuel trims to act up, and the closed loop AFR's to run extremely rich. The only CEL (to my knowledge) that smitty is seeing is the P0421 inefficient cat. which hurts nothing to the performance of the car. I mentioned this in the other thread that wrapping the area around and including the sensor with some heat wrap might help out, but this is just an idea for a short term fix........
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. | |
| The Following User Says Thank You to SilverDemon For This Useful Post: | smitty5788 (11-30-2010) |
Groans: 155
| Not Ranked : 0 score A great design on the down pipe.....they just might of looked a little closer at where the bung was located in the exhaust flow, or maybe when the testing was done on the shop car it was an extremely hot summer day and the sensor never dropped below the .2v Too many variables to know what exactly went on. Hell, it could have even been that Mazda changed manufactures of the sensors from the time CP-E bought their shop car to the time a few of you guys are having the problems.
| Neutral : +1 score unfortunately no company will promise a product wont throw a cel. im not sure if you are gen1 or 2 but it seems with the 2's that catted dp's dont require an extended or angled bung. they work just fine with the rear sensor directly in the exhaust stream. some non-catted pipes benifit from extended bungs or defoulers since they allow the rear sensor to see a change in temp. im not saying its a bad design, it clearly works for most gen1's, but gen2 is still a newer platform and companies are working the kinks out. i believe UR may actually be changing their bung setups on catted pipes.
| The Following User Says Thank You to dMuze For This Useful Post: | SilverDemon (11-30-2010) |
Groans: 155
(Thread Starter) | Not Ranked : 0 score I can not remember the angle on the cp-e bung - anyone know? Also, where can I get soem heat wrap to give that a try? |
| The Following User Says Thank You to SilverDemon For This Useful Post: | Tommy (11-30-2010) |
![]() Join Date: Dec 2009 Location: Cincinnati, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,608
Groans: 215
| Not Ranked : 0 score Yes Im saying it was a bad design, same thing I said in the linked thread. Its Custom Performance ENGINEERING ... key word there and any engineer will know a fluid isnt going to turn a corner and go the direction oposite of the main flow into a dead end. Thats why at high load with high levels of exhaust flow the O2 sensor would cool down and exhaust wouldnt travel up the bung. So if you catted pipe bung was like my catless one it is extended about 4 inches back up towards the turbo. That being said, it may be that the Gen2 is different but I beleve Tommy had a Gen1 so I guess not that much different. And CPE has been told, weather they fix it is another issue.
__________________ 2011 DGM STI Sedan - Fully Bolted FP Green Setup 368WHP / 335WTQ SOLD: Black Mica 2010 MS3 - Tech Package -CPE Catless DP - CS CBE - SURE Aeros - SURE Sidewinder - TS BPV - CPE HPFP - JBarone Shifter Bushings - TRZ RMM - MD OCC - Progress RSB - DashDAQ - 18x8.5 +45 Rays Gram Light 57F - 235/40 Potenza RE760 |
Groans: 155
(Thread Starter) | Not Ranked : 0 score Yes, I'm in a 2007 Gen1. I'm going to try to get under the car tonight and look to see how the bung is set up on the catted cpe dp. |
Groans: 215
| Not Ranked : 0 score If it is longer than about an inch I can bet thats your problem unless you actually have a bad sensor. Check for leaks at the sensor and the DP while your under there.
Groans: 155
(Thread Starter) | Not Ranked : 0 score WIll do, the cig test works for me |
Groans: 215
| Not Ranked : 0 score haha there ya go man ... i prefer smokeless so i didnt try that one.
Groans: 155
(Thread Starter) | Not Ranked : 0 score Ya know, Sander, you could save me some of the trouble here and just tell me how your current catted dp (just bought mine at the last dyno meet) has the bung installed. At 90°? |
Sander
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe | |
| The Following 2 Users Say Thank You to www.cp-e.com For This Useful Post: | skeeter149 (12-05-2010), Tommy (11-30-2010) |
Groans: 155
(Thread Starter) | Not Ranked : 0 score Thanks. What kind of damage am I doing to my car in the mean time by driving around with this CEL? Anyone know? |
![]() | | #19 | ![]() |
| Not Ranked : 0 score no real damage running rich...stay off the WOT driving. it will just make you hatch and plugs filthy...and your mpg will suck
![]() | | #20 | ![]() |
Groans: 155
(Thread Starter) | Not Ranked : 0 score It's Thursday! I hope to hear from you on this soon. I did not get a chance to get under my car yet due to the crap weather. Thanks. |
![]() | | #21 | ![]() |
| Not Ranked : 0 score Hey Tommy, Sorry about this, I've been very busy with stuff here. I promise I'll get some pictures tomorrow and ask the manufacturing guys about it. Thank you, Sander
![]() | | #22 | ![]() |
| Not Ranked : 0 score It is at 90 deg. This shouldn't really be an issue. I've put in a request to the mechanical side for an evaluation on this, I'll report back when I hear what they have to say. Still could be a sensor issue though. And, try to avoid running around town running overly rich. This can in-turn destroy the catalyst.
![]() | | #23 | ![]() |
Groans: 155
![]() | | #24 | ![]() |
| Not Ranked : 0 score if its so loose that gas is escaping then maybe it could cause an issue...starting to think the sensor may be bad though.
![]() | | #25 | ![]() |
Groans: 155
(Thread Starter) | Not Ranked : 0 score Well, after PM'ing SD, he pretty much made me feel my gut is right and when I say it was loose, I mean I got a few turns on it by hand. The fact that it was that loose and I was getting this code says to me to go the simple route and just tighten the sumbitch. The sensor being bad and being loose would just seem too out there for me. |
![]() | | #26 | ![]() |
| Not Ranked : 0 score yup...tighten, reset and drive for a day...hopefully all is well. would def be the end of a headache for you and the cheapest fix!
![]() | | #27 | ![]() |
Groans: 155
![]() | | #28 | ![]() |
| Not Ranked : 0 score its a standard o2 socket. if the bung is too long you may be better off with a set of channel locks or vice grips...just dont go too tight, and use anti-seize
![]() | | #29 | ![]() |
| Not Ranked : 0 score 7/8ths or 22mm is standard oxygen sensor hex sizes.
![]() | | #30 | ![]() |
Groans: 215
| Not Ranked : 0 score Glad you figured it out, one of the things to check from the service manual for that code is a leak between the O2 sensors so I bet the loose sensor is the issue. If that doesnt fix it I bet its the sensor itself.
![]() | | #31 | ![]() |
Groans: 155
(Thread Starter) | Not Ranked : 0 score Well, so far so good but it may take more than the 40 miles I put on since reset to get the CEL to go again. Anyone have any clear pics of the harness the o2 sensor plugs into an how it unplugs? I am pretty sure I am twisting the wire more than I would like and just thought it best to unplug before tightening. |
![]() | | #32 | ![]() |
Groans: 215
| Not Ranked : 0 score On the gen2 the clip is on the drivers side of the plug if that makes sense. Its a pain to get to from under the car but its really easy if you remove the battery box. It sits on a bracket right under the inlet pipe.
![]() | | #33 | ![]() |
Groans: 155
(Thread Starter) | Not Ranked : 0 score Ok, so I have not been able to tighten it yet with anything other than my hand so far. I have since put 124 miles on it in the save driving conditions and no CEL. I'll put another 100 miles on it tonight and if I still see no CEL, I think it's safe to say that the problem has been identified and fixed (or will be fixed when I properly tighten it.) |
| The Following User Says Thank You to Tommy For This Useful Post: | www.cp-e.com (12-07-2010) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Good, thanks for reporting back on the issue. Sander
![]() | | #35 | ![]() |
Groans: 155
(Thread Starter) | Not Ranked : 0 score Well, the CEL came back after 220 miles. At this point, I will assume that the hand tightened o2 sensor came loose again. I will confirm it is the same code tonight, clear it and hopefully tighten the o2 sensor down again with a proper wrench. |
![]() | | #36 | ![]() |
Groans: 155
(Thread Starter) | Not Ranked : 0 score Ok, so I pulled the codes with the Advance Auto scan tool and it turns out I had 5 codes in there: p0420 - Catalyst efficiency below threshold bank p2181 - Engine cooling system perform? p0300 - random/multiple cylinder misfire detected p0304 - cylinder 4 misfire detected p0301 - cylinder 1 misfire detected ANy ideas? Related to the o2 sensor being loose? Shoudl I start a whole new thread? |
![]() | | #37 | ![]() |
Groans: 155
(Thread Starter) | Not Ranked : 0 score Anyone have any ideas on these other codes? I will be under the car tonight to check to see if the o2 sensor backed out again and to properly tighten it with the right tool. Could a loose o2 cause any of these other issues? The cooling one really has me worried. |
![]() | | #38 | ![]() |
| Not Ranked : 0 score sry man i havent seen those before
![]() | | #39 | ![]() |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
Second, I think the loose O2 sensor may have caused other problems like an overly rich condition maybe fouling the plugs and causing a misfire. If the sensor was loose and was registering oxygen coming in from a leak, it may have caused the car to run rich and foul the plugs. The cooling system code may have been a fluke, but I would start by monitoring what your engine coolant temps do while you're driving around. It may be a simple problem. | |
![]() | | #40 | ![]() |
Groans: 155
(Thread Starter) | Not Ranked : 0 score Plugs are pretty new too. What shoudl I use to clean them, assuming they are fouled? Wire brush? *edit* I have brake cleaner and MAF cleaner. Will either of them clean plugs? |
| In stock now CNT Racing Mazdaspeed 3 catted and non Catted downpipe | ERZperformance | ERZPerformance | 325 | 08-04-2013 05:13 PM |
| Catted or non Catted dp? | MSP611 | MazdaSpeed 3/6 - Turbo Induction | 18 | 11-28-2010 05:32 PM |
