Closed Thread
 Old 12-10-2010, 09:00 PM   #41
Click Here's Avatar
Posts: 202   (View Stats)
Click Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the worldClick Here is the leader of the world
Originally Posted by Tommy View Post
Plugs are pretty new too. What shoudl I use to clean them, assuming they are fouled? Wire brush?
*edit*
I have brake cleaner and MAF cleaner. Will either of them clean plugs?
Right, the plugs may be new, but if air was leaking past the sensor and making the car run rich in closed-loop that could absolutely foul the plugs in short order. Understand that I'm just taking a best guess here though. If it were my car the plugs are the first thing I'd check if I got a misfire code, especially if my O2 sensor was loose enough to trigger a CEL. Plugs are often the cause of misfires and they're also relatively easy to check.
Yeah, brake cleaner will work great if they are all gunked up. Wire brush should work fine but be gentle. Also while you have the plugs out double check the gap. If they're anymore than like 0.032" that may have contributed to the misfire as well. I'll be curious to know what you find.
And dude, I didn't read your post closely enough last time. Have you not tightened that sensor down with ah wrench yet? I know it's tough to get at but you really really need to get that taken care of asap. What is the issue exactly? Can you not even get an open ended wrench on there?
Click Here is offline
 Old 12-13-2010, 10:31 AM   #42
Tommy's Avatar
Posts: 2,309   (View Stats)
Groans: 155
Alright, so I finally got the sensor tightened up on it Saturday. About 130 miles driven on it since. The codes I cleared last week and no CEL since but should I rest the ECU again or just ride it out as is? I did not have time to pull the plugs but I gave it a few WOT runs after it was tightened down so hopefully that cleans up the plugs enough but I will check them before the week is out.
Tommy is offline
 Old 12-13-2010, 10:44 AM   #43
Click Here's Avatar
Nah, you shouldn't have to reset the ECU so long as you cleared the codes. Let us know what you find after you've put some more miles on it. If the CEL does return make sure you check which codes popped back up.
 Old 12-23-2010, 06:18 PM   #44
Tommy's Avatar
Groans: 155
Ok, so I', l;ate with the update. I got it tightened down a couple fo weeks ago and all was fine until last night when I got anohter CEL. I had it checked and it is now the P0421 - Warm up Catalyst Below Threshold Bank.
I clear it out but the CEL came back on tonight. WTF?
Tommy is offline
 Old 12-23-2010, 08:00 PM   #45
Click Here's Avatar
That's another code commonly associated with a cat that is not functioning properly.
 Old 12-23-2010, 09:15 PM   #46
smitty5788's Avatar
Posts: 1,065   (View Stats)
smitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the world
Groans: 215
that says your cat isnt working. Its CPE's problem now, you need to tell them that. I have the same code with their catless pipe.
2011 DGM STI Sedan - Fully Bolted FP Green Setup
368WHP / 335WTQ
SOLD: Black Mica 2010 MS3 - Tech Package -CPE Catless DP - CS CBE - SURE Aeros - SURE Sidewinder - TS BPV - CPE HPFP - JBarone Shifter Bushings - TRZ RMM - MD OCC - Progress RSB - DashDAQ - 18x8.5 +45 Rays Gram Light 57F - 235/40 Potenza RE760
smitty5788 is offline
 Old 12-23-2010, 10:34 PM   #47
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Unfortunately, it should be noted that catalysts are fragile pieces. If you were running around excessively rich for an extended period of time (due to your original problem, and loose secondary oxygen sensor), you may have damaged the catalyst, causing the in-efficiency fault.
If you would like to email me on the issue, I will see what we can do.
smarques@cp-e.com
-Sander
Website: www.cp-e.com
www.cp-e.com is offline
 Old 12-23-2010, 10:41 PM   #48
If you have a P0420 with a cat-less down pipe, this is to be expected, as there is no cat to measure the efficiency of.
 Old 12-24-2010, 04:27 AM   #49
smitty5788's Avatar
Groans: 215
Im aware
368WHP / 335WTQ
 Old 12-25-2010, 07:14 PM   #50
Tommy's Avatar
Groans: 155
smarques@cp-e.com
-Sander
Well, I emailed you yesterday but with the holiday, I don't expect a response until next week. Anyways. assuming that the short time I drove with the car running richer than normal has managed to somehow clog up the cat, is there anything I can do to clean it out?
Tommy is offline
 Old 01-01-2011, 05:02 PM   #51
MattJackson86's Avatar
Posts: 1,407   (View Stats)
I just started throwing a P0421 code with my CP-E catted downpipe. I have had the DP for 30,000 miles ish I would say. I have cleared the code a couple times and it comes back after a day. Any ideas?
MattJackson86 is offline
 Old 01-01-2011, 05:56 PM   #52
Tommy's Avatar
Groans: 155
I'm gonna seafoam it in a couple of weeks when I change the oil since the can mentions cleaning the cat.
Tommy is offline
 Old 01-03-2011, 10:45 PM   #53
If you guys have made sure that the o2 sensors are tight, and that the exhaust system is free of leaks, we will take the catted DP's back with a copy of the original purchase receipt and either repair or replace the cats under warranty.
Any questions on this please email me at smarques@cp-e.com
-Sander
The Following 4 Users Say Thank You to www.cp-e.com For This Useful Post:
char181 (04-06-2011), Click Here (01-04-2011), MattJackson86 (01-04-2011), smitty5788 (01-04-2011)
 Old 01-04-2011, 05:58 AM   #54
smitty5788's Avatar
Groans: 215
At least some vendors here stand by their work
368WHP / 335WTQ
The Following 3 Users Say Thank You to smitty5788 For This Useful Post:
char181 (04-06-2011), Click Here (01-04-2011), www.cp-e.com (01-04-2011)
 Old 01-04-2011, 11:42 AM   #55
Thanks Sander. I am sure mine is good as its been installed for over a year. I will let you know what I decide to do. For now I am going to see how it goes as its not affecting driving. Will replace it probably when I replace the turbo. Only want to do the install once.
I really do love CP-E's customer service.
The Following User Says Thank You to MattJackson86 For This Useful Post:
 Old 01-05-2011, 05:15 PM   #56
Tommy's Avatar
Groans: 155
Thanks Sander. I'll still try to Seafoam it and see what happens. I don't have another car so I can't just take it off and wait for it to come back but if you are having another dyno day in the near future, I could come down there a day or two beforehand to get it done. I was planning on this anyway since I wanted to get tuned also.
Tommy is offline
 Old 01-25-2011, 10:35 AM   #57
Tommy's Avatar
Groans: 155
Ok, for Sander and anyone else that may be concerned. This weekend, I cleared the P0421 code out again and once again saw that I had the misfire code as well. So, with codes cleared, I seafoamed after getting it good and hot, cleared it out with a few strong highway pulls in 4th and then cleaned and regapped all 4 plugs. Two of the plugs were pretty blackened. I cleaned out the MAF sensor too for good measure. So far, I have put 180 miles with no CEL but 250 has been the magic number. I'll hit that in a couple of days and report back. Hopefully the DP can be saved.
Tommy is offline
 Old 01-25-2011, 01:57 PM   #58
Thanks, just keep me posted.
 Old 01-26-2011, 07:27 AM   #59
Tommy's Avatar
Groans: 155
Ok, the CEL is back. Any other ideas before returning the DP?
Tommy is offline
 Old 01-26-2011, 10:57 AM   #60
Try resetting the ECU by disconnecting the battery. I know that may sound odd but I will say that I have not received that CEL code in over 1500 miles as shortly after I posted I reset the ecu.
Closed Thread
In stock now CNT Racing Mazdaspeed 3 catted and non Catted downpipe ERZperformance ERZPerformance 325 08-04-2013 05:13 PM
Catted or non Catted dp? MSP611 MazdaSpeed 3/6 - Turbo Induction 18 11-28-2010 05:32 PM
Page generated in 0.39999 seconds with 24 queries
