Closed Thread
 Old 01-22-2009, 01:09 PM   #41
crazyitalian041's Avatar
Posts: 611   (View Stats)
Originally Posted by Sacrilicious View Post
don't you have an AP as well?
He's using it as a paper weight.
Fully Built short and long block biatches
Sponsored by Cp-e and built by P3.
"giddy-up"
crazyitalian041 is offline
 Old 01-22-2009, 01:14 PM   #42
interesting.
What has to be understood by anyone tuning this car is that in these GDI engines, you have to be very careful about how fuel and air is delivered. They are inflexible to changes since there is little wiggleroom in how the air/fuel mixture is created on the top of the piston right before the spark plug is fired.
Lex is offline
 Old 01-22-2009, 01:18 PM   #43
I know, im fully built short and long block with a gt3071r. Just wanting to see what happens to randy is all.
"giddy-up"
 Old 01-22-2009, 01:40 PM   #44
wakeboarddude's Avatar
Posts: 860   (View Stats)
wakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the world
Good luck man and hope everything turns out the way you want it to!! Remember your making history for all of us!! We're all counting on you!
wakeboarddude is offline
 Old 01-22-2009, 02:00 PM   #45
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
i do too...it doesn't need to be plugged in...
Sacrilicious is offline
 Old 01-22-2009, 02:10 PM   #46
dcs191919's Avatar
Posts: 73   (View Stats)
dcs191919 is a jewel in the roughdcs191919 is a jewel in the roughdcs191919 is a jewel in the rough
I'm curious to see what comes out of this. My strong belief for the reason this car does not "respond" to mods the same way port injection does is because there is a very specific design to the piston and combustion chamber that makes the car perform in stock form.
Once you alter that you mess with the stratified air/fuel mixture around the spark plug and you just don't make the power you expect. I am curious how these aftermarket pistons will perform.
Which is why vdubs with a similiar design (direct injection, similar fuel system) are making 5-600 WHP. Maybe you are correct, but Im pretty sure with more boost and fuel power will be made.
dcs191919 is offline
The Following User Says Thank You to dcs191919 For This Useful Post:
phailerider (01-22-2009)
 Old 01-22-2009, 02:13 PM   #47
Driverman5777's Avatar
Posts: 685   (View Stats)
Driverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the worldDriverman5777 is the leader of the world
Groans: 76
lolz ^
Driverman5777 is offline
 Old 01-22-2009, 03:04 PM   #48
phailerider's Avatar
Posts: 4,639   (View Stats)
it also why the new direct injection bmws are adding frigging piggybacks, that only raise boost on the twin turbo setup....and then cranking out over 400 whp!!!
i think the philosophy is an interesting one but not accurate. the limitations have more to do with quirky mazda engineering in the ecu, in the sensors, weak rods necessitating a built motor, in the flow design of the head perhaps.
but the bottom end is just displacement. if i can fill it with air, spark and fuel then power can be made. its all the other bullshit thats stood in our way. I REALLY expect a breakthrough moment for us here. VWs were stuck down around us for years and then when they figured out a fueling solution to go along with the tuning..... boom... they made 600whp. I am hoping for a similar experience with our cars here. if we make power up to the limit of the fuel... i think we could see 450-500whp spraying meth. thats what im hoping for here guys.
phailerider is offline
The Following 2 Users Say Thank You to phailerider For This Useful Post:
gsrtype1 (01-22-2009), lidokrantz (01-22-2009)
 Old 01-22-2009, 03:44 PM   #49
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
When are we gonna see some race gas being run through the family wagon?
"08, I hate to break it to you, but if it gives kevin a boner, its porn"
NATOR PERFORMANCE
Nylon washer sponsered
mexicant is offline
 Old 01-22-2009, 05:04 PM   #50
Derek88's Avatar
Posts: 773   (View Stats)
Derek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the world
It felt like a beast at 346whp... I cannot fathom 100-150whp more. I'll shit myself.
-Derek
No longer in the Mazdaspeed Family
Derek88 is offline
 Old 01-23-2009, 07:10 AM   #51
Anklh's Avatar
Posts: 166   (View Stats)
Anklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond reputeAnklh has a reputation beyond repute
First off, can there be a sticky made with the various peeps and their builds in one thread? Including who built them and if they are running how long they have been? My messages to various folks have gone unanswered save for CP-E. I guess you all are either too busy or think that I am not a serious buyer.
Secondly, to those pioneers with our grocery getters I wish you the best of luck.
Anklh is offline
 Old 01-23-2009, 08:18 AM   #52
SneakyP86's Avatar
Posts: 1,162   (View Stats)
Originally Posted by spheed3 View Post
I'm tempted to make the trip myself....700 miles is a bit steep though. Damn location...
AH come on man its about 620 for me.........LOL
SneakyP86 is offline
 Old 01-23-2009, 01:10 PM   #53
Grim's Avatar
Posts: 2,395   (View Stats)
Groans: 70
1500 for me =[
Grim is offline
 Old 01-23-2009, 03:35 PM   #54
Demi's Avatar
Posts: 1,107   (View Stats)
Demi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the worldDemi is the leader of the world
Groans: 61
Groaned at 16 Times in 11 Posts
2350 miles for me... but i went last time!! Course randy was standing in his engine bay at that time.
Beginners guide to turbos<- New to this? Give it a look!
-And for the rest of you, if it comes from Autozone and doesnt replace something that broke off your car or make your cabin smell like Coco Butter, its fucking rice.
Demi is offline
 Old 01-25-2009, 07:35 AM   #55
yeah... you definitely hold the record...lol
it looks like were gonna have a full house next weekend. if anybodys interested in coming out let me know.
ive got a 3.5bar aem boost sensor upgrade to go on too, btw. medieval mounts and traction bars are a maybe... if they arrive with the mani. i requested them. i keep going round and round to make sure all my bases are covered here. dynotime is gonna be available sunday or monday were trying to line up. im excited.....
 Old 01-25-2009, 08:00 AM   #56
ms3guy22's Avatar
Posts: 530   (View Stats)
ms3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond repute
I'll be the one with some race gas.......we'll see what race gas and wate meth will do.
I hate my mazdaspeed3 more than anything else in this world!
ms3guy22 is offline
 Old 01-25-2009, 08:03 AM   #57
if you bring race gas... you better bring enough for the whole class!!
 Old 01-25-2009, 08:09 AM   #58
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
im gonna try and make it, put ALL your gas mileage numbers to shame!!
Laloosh is offline
 Old 01-25-2009, 08:13 AM   #59
what do you mean "try". and bring Rose.... kyles girl is gonna be there too. Shes gonna need a shopping/ sightseeing/ drinking buddy. my wifes out...lol.
 Old 01-25-2009, 08:15 AM   #60
ms3guy22's Avatar
for sure< btw mpg = 18.......fail
ms3guy22 is offline
 Old 01-25-2009, 08:28 AM   #61
Laloosh's Avatar
its superbowl sunday randy lol. I got money to win/lose. We have this lil tradition, a shot everytime some1 scores....last year was boring cause we were only like 10 or 11 in lmao. Im not driving home while the game is on.
Laloosh is offline
 Old 01-28-2009, 10:02 AM   #62
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
All of us up there are excited about what this may mean for the platform. I dont think its unreasonable that we could get a number far above what weve even been shooting for. it just depends on when i lose fuel pressure.... or even crawl above 12 a/fs. as far as im concerned 12.0-12.5 ... Im done. Im not interested in a bullshit number. i want to see where we "really" stand.
Be very careful of aiming for 12-12.5:1 if you are using a lot of methanol.
Stoichiometric air-fuel ratio for methanol is about 6.4:1.
If you are running significant amounts of methanol you need to aim for a lower total AFR to keep from going lean.
For example if you are supplying 30% of your total fueling with Meth you need to aim for something closer to:
12*0.7 + 6.4*0.3 = 10.3 AFR.
Good luck.
cld12pk2go is offline
 Old 01-28-2009, 11:23 AM   #63
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
Its confirmed I will be able to make it this weekend. Ill be getting the flash and an inlet also hopefully. Looking forward to seeing you all.
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline
 Old 01-28-2009, 12:12 PM   #64
good stuff. im excited...
a perrin ebcs
egt guage
extra allen bolts and studs
3.5 bar sensor
maf flash/ maf
manifold goes out tonight overnight from utah
yada yada... all the little stuff for a number this time.
 Old 01-28-2009, 12:34 PM   #65
SgtP's Avatar
Groans: 106
Sounds like a fun filled weekend. I have that fuel line from whoosh I might want to throw in if possible. I want to see if it will even make a difference.
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 01-28-2009, 04:58 PM   #66
killa cam's Avatar
Posts: 450   (View Stats)
killa cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the world
this should be a fun filled weekend...
killa cam is offline
 Old 01-28-2009, 05:42 PM   #67
bombdotcom's Avatar
Posts: 816   (View Stats)
bombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the worldbombdotcom is the leader of the world
Groaned at 40 Times in 20 Posts
how come everythings on the other side of the country damnit! haha
no speed love in so cal
(RIP) 08' MS3---MODS:COBB AP- COBB SRI AND TIP- COBB RSB- COBB KNOB- CP-E TMIC- LIMITED EDITION HKS BOV- CORKSPORT DP AND TP- TRZ REARMOUNT- MD OCC- PTP IM COOLER KIT- COSWORTH BSD- EIBACH PROKIT- TWM SHIFTER BUSHINGS- JBR SHORT SHIFT KIT-
13' CWP MS3
bombdotcom is offline
 Old 01-28-2009, 06:41 PM   #68
well baby... last piece is done... being overnighted as we speak.
Its GAME ON!!!
 Old 01-28-2009, 06:55 PM   #69
Derek88's Avatar
Damn that is nice!
-Derek
Derek88 is offline
 Old 01-28-2009, 07:00 PM   #70
Thermonuclear Skeet
FantasmoNegro's Avatar
Posts: 2,810   (View Stats)
FantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the world
Groans: 188
Groaned at 333 Times in 222 Posts
Yes Sir
El Fantasmo Del Negro
Helicopter Cat LIVES
FantasmoNegro is offline
 Old 01-28-2009, 07:33 PM   #71
hey its gboro boys!!!
you guys want a trip. come on!!!!
 Old 01-28-2009, 08:25 PM   #72
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
Its ON!!!
this has my vote for most bad azz serious business mani out there
looks good man
2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008)
2008 Caliber SRT4 / 11.8 @ 120
whoosh@Realtune is offline
The Following User Says Thank You to whoosh@Realtune For This Useful Post:
phailerider (01-28-2009)
 Old 01-28-2009, 08:26 PM   #73
Superstretch18's Avatar
Posts: 318   (View Stats)
Superstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond reputeSuperstretch18 has a reputation beyond repute
Medieval needs to invest in a fucking better camera. Good deal though dude. Can't wait to see some numbers from the beast!
Old - 2007 CX-7 Sport FWD
New - 2010 WRX Hatch
who has the most care? me 0 care.
Superstretch18 is offline
 Old 01-28-2009, 10:39 PM   #74
medieval's Avatar
Posts: 213   (View Stats)
medieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the worldmedieval is the leader of the world
LOL. We have a good diggy camera. That picture I sent to randy through text message and email. It went overnight and I did not have enough time to set it up and take quality pictures, however, Randy will be posting plenty of pictures for al to see.
medieval is offline
 Old 01-29-2009, 07:45 AM   #75
killa cam's Avatar
good stuff!
 Old 01-29-2009, 07:57 AM   #76
Boonestafa's Avatar
Posts: 204   (View Stats)
Boonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the world
Smile
just to make sure.. everyone is coming down this saturday the 31st right?
the wife and i are going to swing by the shop on our way to the rockville earth trecks for some climbing... so what time does everyone plan on being arround the shop?
i also just got my first overtime check for the year so i'll have a bit of money to spend if i see something worth it!
2008 True Red MS3 GT HKS ssqv black, JBR SRI, JBR TIP, CPE ToW PlatE.
JBR RMM, HPFP Internals, cobb AP in near future!
Boonestafa is offline
 Old 01-29-2009, 07:58 AM   #77
SgtP's Avatar
Groans: 106
cant wait! its going to be fun ripping all the way from here to cali after this flash and the inlet!
13.2@111
Sponsored By: CP-E
SgtP is offline
 Old 01-29-2009, 08:17 AM   #78
SneakyP86's Avatar
I should be coming up need to get the flash and get my PNP harness looked at,I should be there sometime Friday afternoon probably stay till Saturday maybe Sunday morning sometime.Wheres a good place to stay Randy thats not gonna be tto damn expensive?
 Old 01-29-2009, 08:36 AM   #79
i always stay at the hampton inn in college park...99 bucks a night with a starbucks next door. close and convenient to cpe, and the beltway.
 Old 01-29-2009, 08:58 AM   #80
y2kc0wb0y's Avatar
Posts: 808   (View Stats)
y2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the worldy2kc0wb0y is the leader of the world
Nervous thinking about all the work that needs to be completed this weekend. I'm sure were going to make some good power with that 35r...I cannot imagine you will not hit a strong number. Thank you who ever said watch leaning the car out with Meth..I've been saying that for over a year now.
For those that want to spend some OT money...I think Jordan has a brand new meth pump he'd like to sell.
Z00m Z00m
y2kc0wb0y is offline
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f330/palerider-update-thread-400-450-500whp-here-19656/
The moment of truth....... Blown engine thread - Mazda6 / Atenza This thread Refback 04-29-2009 02:06 PM
Tonite she left me stranded on the highway.... - Mazda6 / Atenza This thread Refback 03-24-2009 01:36 PM
Day of 2/3/2009: Top 50 of 288 Referring Pages This thread Refback 02-04-2009 08:06 AM
How much would you pay for 500WHP? y2kc0wb0y Mazdaspeed3/6 General Discussion 73 12-01-2008 11:37 AM
Page generated in 1.29636 seconds with 45 queries
