 Old 07-18-2014, 06:59 AM   #1
anotherneon's Avatar
Posts: 128   (View Stats)
anotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant futureanotherneon has a brilliant future
Groaned at 14 Times in 7 Posts
Default Part install
I am wondering if you could provide me with a quote to install a HPFP and test pipe. PM me if need be.
Thank you
anotherneon is offline   Reply With Quote
 Old 07-18-2014, 10:28 AM   #2
nilashish's Avatar
Posts: 468   (View Stats)
nilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the world
nilashish is offline   Reply With Quote
The Following 7 Users Say Thank You to nilashish For This Useful Post:
alaskazero (07-18-2014), derek13p (07-18-2014), Frenchy11 (07-22-2014), Oalmon (07-18-2014), Raider (07-23-2014), Shampu (07-22-2014), Trey-Z (07-18-2014)
 Old 07-18-2014, 10:45 AM   #3
Trey-Z's Avatar
Posts: 918   (View Stats)
Trey-Z is the leader of the worldTrey-Z is the leader of the worldTrey-Z is the leader of the worldTrey-Z is the leader of the worldTrey-Z is the leader of the worldTrey-Z is the leader of the worldTrey-Z is the leader of the worldTrey-Z is the leader of the worldTrey-Z is the leader of the worldTrey-Z is the leader of the worldTrey-Z is the leader of the world
Groaned at 9 Times in 5 Posts
There's a ton of info here of DIY. It's not that bad. Hit up ur local Nator for some assistance. Saves you more money.
2006 MazdaSpeed6 WhiteWaterPearl
Trey-Z is offline   Reply With Quote
 Old 07-18-2014, 11:21 AM   #4
 Old 07-18-2014, 11:24 AM   #5
[R]usty's Avatar
Posts: 2,204   (View Stats)
It's easy. I swapped back to stock yesterday took me 15 minutes.
2010 Mazdaspeed3 w/tech
 Old 07-18-2014, 02:18 PM   #6
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
Thank you
you can either fill out the appointment scheduler here: cp-e? | Custom Performance Engineering
or email install@cp-e.com and we'll get back to you with a quote.
Website: www.cp-e.com
 Old 07-22-2014, 06:13 AM   #7
Frenchy11's Avatar
Posts: 832   (View Stats)
Frenchy11 is the leader of the worldFrenchy11 is the leader of the worldFrenchy11 is the leader of the worldFrenchy11 is the leader of the worldFrenchy11 is the leader of the worldFrenchy11 is the leader of the worldFrenchy11 is the leader of the worldFrenchy11 is the leader of the worldFrenchy11 is the leader of the worldFrenchy11 is the leader of the worldFrenchy11 is the leader of the world
I'll do it for you for free. Just come to CT.
Murica'
Freektune (300 whp/ 349 wtq) Cobb Accessport/Autotech HPFP Internals/ HTP 3 Inch Intake/ Cobb Downpipe/ ETS TMIC/ Corksport Short Throw Shifter + Bushings/ JBR RSB/ JBR 88 RMM
Frenchy11 is offline   Reply With Quote
The Following User Says Thank You to Frenchy11 For This Useful Post:
Micha (07-24-2014)
 Old 07-22-2014, 01:03 PM   #8
Raiders Bitch
Shampu's Avatar
Posts: 803   (View Stats)
1800 VOL-TRON
Instagram: Genpu_Drew
235/40 Pilot Super Sports
Tuned by Nishan
25% E85
Micha (07-24-2014)
The Following User Says NO Thank You to Shampu For This Un-useful Post:
Adam is so pro (07-28-2014)
 Old 07-27-2014, 06:43 PM   #9
DaUberSchwebel's Avatar
Posts: 233   (View Stats)
DaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the world
Donate and check out the Nator chapter in your area. The test pipe install takes almost no time or tools at all. Some people have done the HPFP install so many times they could probably meet you at a gas station and have it installed by the time your car is filled up.
2013 VRM with Cobb AP V3/ CS SRI/TIP/SS/TP/ CP-E RMM CP-E TMIC Autotechs JBR TIG/IMG/EGR delete Stratified OTS tune
DaUberSchwebel is offline   Reply With Quote
 Old 08-08-2014, 10:00 AM   #10
The_Shocker's Avatar
Posts: 18   (View Stats)
The_Shocker will become famous soon enoughThe_Shocker will become famous soon enough
The worst part about putting in a HFFP is getting a vice if you don't have one, everything else is easy.
The_Shocker is offline   Reply With Quote
New part install post! JBR RMM mazda_axela Mazdaspeed3/6 General Discussion 1 10-22-2013 02:32 PM
Help identifying this part - after JBR TMM install IMASA MazdaSpeed 3 - Engine, Transmission & Driveline 4 06-07-2013 03:45 PM
Page generated in 0.29526 seconds with 29 queries
