Closed Thread
 Old 02-27-2011, 01:54 PM   #1
Meder's Avatar
Posts: 1,065   (View Stats)
Meder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the world
Default Possible Cpe nano issue
I am having some issues the the nano for the first gen speed3. The intake has been great and is giving me great trims but it does seem like it has some issues with poor fitment. From the pcv hose having to be nearly forced into place to the silicone not being able to sit flush the nano seems like a rushed product. A combination of the pcv hose along with the mount make for a tight install that just can not line up correctly no matter what you do. I've seen all the pictures from threads here in search and they all seem to be the same. I've had 3 different intakes, they all fit like a glove compared to the nano. No real reason to dig into this too much, we all know how the nano fits. Much like the cobb shifter and FMIC i called out years ago, no one seems to speak up.
Cpe was quick to send me an email telling me about how great their made in the usa products are but when the nano actually arrived it has all sort of scratches and metal flakes inside. With so much care put into making these how could this be overlooked? Of course some of this is expected, but to the extent I had it the housing looked used. Is it normal to have metal flakes falling out from the PCV hose hookup on the maf housing?
Has anyone else had these issues with the nano for the 1st gen ms3?
Meder is offline
 Old 02-27-2011, 02:04 PM   #2
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
Got mine used, it fits well, metal flakes could be from the polishing process, I have heard that before. If you think it looks like garbage send it back and get the sure aeros with guaranteed cel included
ScarMS3 is offline
 Old 02-27-2011, 02:25 PM   #3
Meder's Avatar
Part of the reason I has the cpe is because I had to ditch the sure. Any pictures of your install?
The pcv hose is basically keeping the intakes silicone from sitting as flush as it should. There is no real wiggle room with the pcv hose and you sort of have to make up for it by adjusting the silicone at various angles.
Meder is offline
 Old 02-27-2011, 02:41 PM   #4
ScarMS3's Avatar
Groans: 97
Searched this guy has same issue but I didn't read the whole thing
CP-E SRI Installation Issues
I would imagine you aren't rotating the connector on thepcv hose enough for It to fit properly
ScarMS3 is offline
 Old 02-27-2011, 02:45 PM   #5
MarkyMark's Avatar
Posts: 1,624   (View Stats)
Groans: 62
Meder we have new Aeros housings getting machined that fix the trim issues.
MarkyMark is offline
The Following User Says Thank You to MarkyMark For This Useful Post:
etchv10 (02-27-2011)
 Old 02-27-2011, 03:09 PM   #6
Meder's Avatar
I've heard, what is changing? I wish sure and SU luck on the new aeros.
Either way, the nano works amazing compared to the other intakes ive had, but the fitment isn't so great. I've turned the hoses on both and in every way possible and this seems to be just how it is. Everything I could find here seems to suggest that this is how the nano fits. Its not that big of a deal, but for the fame this intake has I was suprised no one really mentions this.
Meder is offline
 Old 02-27-2011, 02:50 PM   #7
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
yea...so suck it meder
Monotonous ONE is offline
 Old 02-27-2011, 03:26 PM   #8
NCZ13's Avatar
Posts: 1,268   (View Stats)
I have had 0 issues with my nano, and Ive had it almost a year. Fit like a glove. It fit just fine with my PG inlet as well. Put that on I believe in April?
2008 Cosmic Blue Mazdaspeed3
1986 Mazda RX7
NCZ13 is offline
 Old 02-27-2011, 03:30 PM   #9
Meder's Avatar
Then I dont know what I am doing wrong. I'll go see what I can do to get it to sit better again.
Meder is offline
 Old 02-27-2011, 03:31 PM   #10
Grumpyjap's Avatar
Posts: 1,839   (View Stats)
Take a pic of it installed
Grumpyjap is offline
 Old 02-27-2011, 05:44 PM   #11
Meder's Avatar
Here is the best I could come up with which is better than before.
Meder is offline
 Old 02-27-2011, 05:55 PM   #12
Groans: 819
looks normal
my shit is snug too
but its all good ninja
Meder (02-27-2011)
 Old 02-28-2011, 09:19 AM   #13
ScarMS3's Avatar
Groans: 97
stock tip or aftermarket, because the stock is so stiff(since its plastic) that could be the issue, if its silicone aftermarket then i just dont know.
ScarMS3 is offline
 Old 02-28-2011, 09:22 AM   #14
Meder's Avatar
Stock tip
Meder is offline
 Old 02-28-2011, 10:02 AM   #15
TRex's Avatar
Posts: 3,139   (View Stats)
...mine looks way better than that...looks like your tube is about to come off...will take some pics when i get home
TRex is offline
 Old 03-01-2011, 02:06 PM   #16
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Mine is a tight fit as well and is in constant contact with my recirc tube (HKS). It runs fine, but the fitment is less than ideal. I'll have to go out tomorrow and fiddle with it. I'll try and snap some pics for reference.
08.5MS3 is offline
 Old 03-01-2011, 04:10 PM   #17
nmmazdaspeed3's Avatar
Posts: 173   (View Stats)
nmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond reputenmmazdaspeed3 has a reputation beyond repute
Here's what mine looks like.
nmmazdaspeed3 is offline
 Old 03-07-2011, 11:53 AM   #18
TRex's Avatar
o shit forgot to take pictures lol
will do today
TRex is offline
 Old 03-08-2011, 11:13 AM   #19
HAHA
Anxious to see how yours looks.
 Old 03-08-2011, 11:15 AM   #20
TRex's Avatar
i know right? i am good at the suspense
TRex is offline
 Old 03-12-2011, 08:27 AM   #21
TRex's Avatar
o snap look who finally pulled through
TRex is offline
The Following User Says Thank You to TRex For This Useful Post:
nmmazdaspeed3 (03-12-2011)
 Old 03-12-2011, 05:59 PM   #22
Now that right there is funny. Thanks for the pics.
 Old 03-17-2011, 05:20 AM   #23
Whiteboy's Avatar
Posts: 2,032   (View Stats)
Whiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the world
Groans: 142
Mine was a little snug too but I'd rather it be snug then loose and have the potential to fall off
~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~
Whiteboy is offline
Closed Thread
DDM HID Issue PapaSmurf Exterior 17 06-23-2010 08:22 PM
ECU/PCM issue 08ms3_spirit MazdaSpeed 3/6 - ECU Computer Tuning 2 05-26-2010 09:12 PM
Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon Haltech Automotive News 3 04-17-2010 08:40 PM
:: new issue :: :: Gusto :: MazdaSpeed 6 - Engine, Transmission & Driveline 10 09-14-2009 10:00 PM
Page generated in 0.41536 seconds with 30 queries
