Like Tree5Likes
  • 1 Post By iammike
  • 1 Post By iammike
  • 1 Post By www.cp-e.com
  • 1 Post By iammike
  • 1 Post By aromig
 Old 05-15-2014, 06:18 PM   #1
iammike's Avatar
Posts: 1,415   (View Stats)
Default Review: Full CP-E engine mounts.
Stage 2 RMM - been on the car over a year.
60A PMM - been on the car a few weeks.
60A TMM - installed today.
Today I completed the full mount set on my car and wanted to share my impressions both individually and as a whole. This is coming from someone who did not want a lot of vibes as this is my daily driver...but wanted the security of beefed up motor mounts knowing how pussy the OEM ones are.
Stage 2 RMM: Quite honestly, this is the best RMM on the market IMHO. The only one that might compare is the recently released Matt Diamond RMM since it too reorients the load on the bushing but the CP-E mount is time tested and a more complete kit. Increase in NVH was negligible. Engine felt noticeably more planted and controlled. Installation was a breeze.
60A PMM: Wanting to avoid turning my car into a vibrating sex toy, I chose to continue with CP-E's mount solution and to go with the 60 durometer option. Adding the PMM had a mild impact on NVH upon initial installation but within a week, the added vibes were almost gone. Engine felt more controlled and planted than just having the RMM. (at this time, I had the CS TMM insert in as well) Installation was very basic and quick.
60A TMM: This completed my target for motor mounts. No additional NVH noted while cruising but I can hear additional transmission noise in 1st and 2nd but nothing bad. Get a little bit of vibe resonance when idle and AC compressor is on but going by the break-in of the PMM, I expect that will settle in a week or so and it's certainly not bad even now. Installation was by far the most difficult of the 3 and removing the stud from the transmission was a royal shit fest. My tip for removing that stud can be seen here: Tip/Trick: Installing CP-E TMM - Removing the stud from the transmission.
As a full set, I'm very pleased with the route I chose to go considering my goals of a more secure mounting solution than OEM while not trying to set off seismographs in the area. If you don't mind the vibes and want an even more solid setup, CP-E does offer higher durometer options for the PMM and TMM. All in all, highly recommended if you can spend the money.
www.cp-e.com likes this.
Mike
 Old 05-15-2014, 06:37 PM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I want to be respectful here and offer a counterpoint. I would pretty much challenge anyone going for all 3 mounts and ask why... The stock mounts do a good job working together for the side to side stuff with good isolation for NVH to the cab. How much do you really think the engine moves around lengthwise perpindicular to it's rotation axis? All you are doing is reducing isolation and passing NVH straight into the chassis with no benefit because the engine doesn't really rotate rotate on its long axis between the PMM and TMM.
The rear mount is definitely the weakest link by far, in the MS6 or MS3 for the torsional load the engine places on that mount. That is by far the most crucial mount of the 3 for street/occasional track driving. I think changing the side mounts is superfluous assuming the OEM mounts are in good shape.
I don't know; I was fully bolted with three mounts at one point and absolutely hated the car. I even went back to stock and put the three mounts BACK on to make sure I wasn't just being a pussy. It was unbearable. I then went to the stock PMM and TMM and the CP-E RMM, and IMO that does everything the car needs. The RMM alone prevents that heavy torsional feel from the motor moving around and pulling on the shift cables when you are trying to find 3rd gear. If someone can prove otherwise, through time slips or lap times that PMM and TMM improve their car's ability to put power down, then I will accept that.
The NVH from the 3 mounts is pretty terrible in MS3s or MS6s. OP, I tell you what, drive on the mounts for a month and go back to stock PMM and TMM. I guarantee you won't go back. It's like driving a Cadillac wrapped in bubble wrap on foam tires for the first few days. The only thing that will keep you from going back is because you feel the need to justify your purchase. If you are being completely honest with yourself and us here, do you really feel the PMM and TMM made a tremendous effect on the car's handling/performance relative to cost and increase in harshness/noise?
I don't mean to harsh your gig and I understand this may be kind of a dick move so I apologize in advance, I'm just offering a counterpoint for people to think about when they decide to go this route. I have been off of the fully mounted bandwagon for a while. I always read thread after thread about people having to bolt on all 3 mounts like it's a MUST do, and I just don't get it...
MINI H1 6.0 - CAR LED TAILS
ArmanRus (05-18-2014), brandon3212 (07-19-2015), LumberJack (05-16-2014), MS309 (05-29-2014), Playaj (05-15-2014), SarcasticOne (05-15-2014), SLOWHATCH (05-15-2014)
 Old 05-15-2014, 06:43 PM   #3
iammike's Avatar
Well, all I can and will tell you or anyone is that the engine is obviously moving around less with the PMM and TMM in. If that's needed or not is up to each persons opinion IMHO. I like knowing that all 3 mounts are beefed up and different from you, I've heard too many stories of PMM and TMM failures.
As for NVH and how "horrible" it is. I'm pretty damn sensitive to vibes. At one point the only mount I had on my car was the JBR 88 Dogbone. It was too much and it got replaced and sold. All 3 of these mounts together do not transmit the NVH of the dogbone. @Cyclops; became the new owner of my dogbone and got to hear me bitching about the vibes from it. lol
Mike
The Following 2 Users Say Thank You to iammike For This Useful Post:
Cyclops (05-15-2014), dale_gribble (05-15-2014)
 Old 05-15-2014, 06:53 PM   #4
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
I'll throw my hat into the ring as I have the 88 duro trilogy set from jbr. At first it was pretty much terrible all the time but now that the mounts have settled in I can't say it is perfectly quiet, but it also isn't terribly loud. There are certain rpms, mainly 1750 to 3000, that are horrible. I'm not upset because I knew what I was getting into when I did it. I cant say that i noticed much difference from stock after changing the tmm and pmm in performance, but vibes were greater. I'm picking up the Damond RMM and I think that will fix my nvh problem. I'll review it once I install and compare. Performance wise it was more peace of mine than this will make my car faster. I know things won't move with the way they are now.
tapatalk, it sucks for free.
 Old 05-15-2014, 07:08 PM   #5
iammike's Avatar
1. Same here, it wasn't to make my car faster...but instead to put in some supporting mods instead of worrying that I'm gonna pop an OEM mount.
2. The CP-E set I have does not have any bad vibe ranges in the RPM and only mild resonation at idle with AC on which will likely work itself out since I had that as well with the PMM and it was gone within the week. The RPM ranges of bad vibes especially just on tip in of the throttle is a big part of why I got rid of my dogbone.
Mike
 Old 05-15-2014, 07:26 PM   #6
But are you guys putting on mounts for the sake of putting them on? I have only read about 1 PMM on an MS6 leaking out in all my years. Do these cars break/rip PMM/TMM's regularly and at the power levels most of us run at/aspire to run at (300-400WHP)? I think @LumberJack; only has a RMM on his 790WHP Speed3 and the other stockers have survived so far.
If there are cases where PMMs/TMMs have broken as a result of 300-400WHP then I would buy that as a good reason. Otherwise they are just noise makers.
 Old 05-15-2014, 07:30 PM   #7
iammike's Avatar
With all due respect, I bought them for peace of mind...my mind. I don't buy parts to impress or satisfy anyone but myself.
If you're not concerned with the OEM mounts, then by all means, keep the OEM mounts. I'm not telling people they need mounts...simply giving my impressions of CP-E's mount offerings for those who might be looking at buying mounts.
Mike
Cheapspeed (05-16-2014), dale_gribble (05-15-2014)
 Old 05-15-2014, 07:32 PM   #8
I'm of the mind that any reduction in the engine moving means that powers going to the ground. It wasn't a worry about the mounts taking a crap.
 Old 05-15-2014, 07:33 PM   #9
Fair enough. Points noted. This is what makes MSF good is debate and what not which helps us all learn.
brandon3212 (07-19-2015), monkey.bones.007 (05-15-2014), Vader (05-16-2014)
 Old 05-15-2014, 07:35 PM   #10
I've never had a mount crap due to power. The idea is to make sure the power you make goes to the ground.
 Old 05-15-2014, 07:39 PM   #11
iammike's Avatar
Lets not forget the reduction in torque steer and wheel hop as well. FWD problems.
bertrand_CX_7 likes this.
Mike
The Following User Says Thank You to iammike For This Useful Post:
bertrand_CX_7 (05-18-2014)
 Old 05-15-2014, 07:47 PM   #12
Ingle's Avatar
Posts: 421   (View Stats)
I'll way in on this to give another case sub 300AWHP at 100+k. My PMM cracked in the bottom and leaked all over the damn place, I investigated my TMM since the motor was on a hoist and it tore like construction paper. The RMM I got Cullinspenis a few years ago so that was obviously crap.
I don't believe it's common, but the other mounts do fail, I don't know if the 3 has one - but I like the front mount for the 6.
@iammike; Thanks for the review - I was debating between this and the 70A JBR and decided to go that route. I don't mind a little 'added excitement' when driving
 Old 05-15-2014, 09:49 PM   #13
LumberJack's Avatar
I know have an rmm, and an 88 duro JBR TMM
10.36@148 Fastest Gen 2
 Old 05-15-2014, 11:16 PM   #14
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
My cpe stage 2 tmm vibes way more than my jbr did. When it was new the jbr was horrible, but after break in it was awesome, I'd go back if I still had it.
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 05-15-2014, 11:29 PM   #15
Goodrich27's Avatar
Posts: 678   (View Stats)
Goodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the world
I second the op, I have Cpe mounts all way round and best IMO
Sent whilst bojanglen.
Go fasters:Manley H beams and Wiseco 87.5mm Forged pistons with stock compression, GTX3076 with Tial 38mm EWG, Full Race exhaust manifold w/2000* ceramic coating, MD meth injection TB spacer and Devils Own DC30 WMI with DO14 nozzle, Cobb 3 port ebcs, Ultimate Racing V2 Catless DP, Relentless Customs PNP IM with VTCS delete, TR11 core with HTP under route piping,ACT 6 puck, Corksport catless RP and CBE, CPE Stage II RMM,Cpe side mounts, perm plate with MD sealed and VTA OCC, HTP 4in Intake,ISC N1 coilovers, CS RSB, Tial BPV, Auto tech internals, Cobb ap v3, CPE injector seals,ngk step colder plugs, JBR throttle body TIG and coolant bypass, Corksport polyurethane exhaust hangers, Motorcraft unicorn juice, t6 rotella, Stoptech slotted and drilled front rotors with posi quiet pads.
Rice:corksport led fogs, Corksport eyelids, Corksport hood struts ,blacked out genpu rims, red evil M front and rear, red calipers, Corksport black mud flaps, Corksport shift knob, powder coat red valve cover, Intercooler pipes, and black gloss intake manifold A pillar gauge mount w/ AEM AFR, Oil temp, and Oil pressure gauges.
Goodrich27 is offline   Reply With Quote
 Old 05-16-2014, 05:33 AM   #16
Coats's Avatar
Posts: 580   (View Stats)
Coats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the worldCoats is the leader of the world
+1 cp-e RMM
Immediate improvement in driveability. Slapped it on 5 years ago with less than 1k on the odo. The rest of cp-es' mounts are salty but probably worth it.
2013 Dodge Ram Laramie
GONE 2009 335i xdrive coupe COBB AP V3 CPe DCI
SOLD 2009 FREEKED Mazdaspeed3 GT
Coats is offline   Reply With Quote
 Old 05-16-2014, 05:40 AM   #17
Spec's Avatar
Posts: 4,472   (View Stats)
Did you by chance snap some pics of your tmm? I bought one recently and I was a little on the ropes about how this is welded only on one side, in two places. I would think both sides is what you want. This is top and bottom shots. Everyone else's look like this?
 Old 05-16-2014, 05:55 AM   #18
iammike's Avatar
I did not take pictures.
Mike
 Old 05-16-2014, 06:01 AM   #19
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Contact cp-e, I have had all 3 mounts for over 2 years and do not remember what it looked like.
Spec (05-16-2014)
 Old 05-16-2014, 06:01 AM   #20
Spec's Avatar
I emailed pics to support like 2 or 3 days ago. Usually I'm more patient but, I'd like to go to the track tonight. unless I get an answer I can't. Not trying to launch my ride and then drive 110 OK OK 108 mph down the track if it might bust on me.
08.5MS3 (05-16-2014)
 Old 05-16-2014, 06:07 AM   #21
08.5MS3's Avatar
Groans: 89
Call them. I have some photos, but unfortunately I am not home.
Maybe @Grumpyjap; can chime in?
 Old 05-18-2014, 08:03 AM   #22
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
PM sent
Website: www.cp-e.com
 Old 05-18-2014, 09:06 AM   #23
jasper's Avatar
Posts: 643   (View Stats)
jasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the worldjasper is the leader of the world
I have all 3 mounts(60), and they have been on the car since October. To be honest I'm not super over the moon about my mounts. I installed them because my PMM was broken, and couldn't tell if my TMM was weakened. My car still vibrates enough to not be able to see things in the rear view mirror between 2700-3200 rpm. The bad part, that's about 75% of the time. I was wondering if the solution was to loosen all the mounts and twist the motor a bit then tighten everything up. I question if the motor is slightly crooked, or being pulled to one side or the other. Any thoughts? I do wish the instructions were a little more detailed. I did wonder about installing the stock "weights" in case that helped. Any help would be appreciated.
09 SPEED 3 CWP
installed: CP-e DP, CP-e FMIC, CP-e CAI, Cp-e TIP, Cp-e S2RMM, Cp-e PSMM, Cp-e DSMM, Cp-e Cat back,
HKS SSQV, Steed manifold, DO meth injection with HP Controls controller, Cobb ap, Saiko Michi OCC
TWM Short shifter and bushings, Rallysport mud flaps, 5%tint all around, 55 w 8000 k fogs, low and high beams.
Led 6000 k switchbacks, Led reverse and turn signals. 18 X 8 45 offset w/245/40's, Raceland Coil overs
jasper is offline   Reply With Quote
 Old 05-19-2014, 08:42 AM   #24
How many miles do you have on those mounts? Depending on your driving most mounts might take up to a couple thousand miles to properly break in.
bertrand_CX_7 (05-20-2014)
 Old 05-23-2014, 06:05 AM   #25
iammike's Avatar
For those who were concerned with rear view mirror vibes.
Mike
 Old 05-23-2014, 10:09 AM   #26
Voltron's Avatar
Posts: 4,556   (View Stats)
Groans: 77
Someone said something about side mounts?
How about my trans just dropped while topping out 4th gear.
Jbr 88 trans mount. Bolt snapped at the threads. Took my axle out.
So yeah id say that shit moves around.
Also i might add. Have you ever watched a car launch on stock mounts?
The Following User Says Thank You to Voltron For This Useful Post:
darkstar5440 (05-27-2014)
 Old 05-24-2014, 07:20 PM   #27
rolanblack's Avatar
Posts: 2,110   (View Stats)
@El Beaner;
 Old 05-24-2014, 07:33 PM   #28
iammike's Avatar
Launch...on stock mounts...and the engine didn't come through the firewall? lol
Mike
 Old 05-27-2014, 03:23 PM   #29
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
I broke my stock PMM Auto'Xing and have talked to a gen1 speed owner that said he used to break one a SEASON.
2012 Velocity Red Mica
 Old 06-18-2014, 03:08 AM   #30
Goodrich27's Avatar
I have full Cpe mounts much better than stock IMO
 Old 06-18-2014, 07:12 AM   #31
El Beaner's Avatar
Posts: 4,262   (View Stats)
By all means this was not scinetific but between a fully mounted MS3 vs a fully stock MS3 torque steer was still ever present and almost identical.
Torque Steer Comparison: Fully Mounted vs Stock Mounts
SOLD 2012 LSM Tech - 11/17/17
 Old 07-18-2015, 08:58 PM   #32
white beast's Avatar
Posts: 30   (View Stats)
white beast is a jewel in the roughwhite beast is a jewel in the roughwhite beast is a jewel in the rough
Looking at getting these soon. Have cobb rmm right now.
white beast is offline   Reply With Quote
The Following 2 Users Say NO Thank You to white beast For This Un-useful Post:
iammike (07-18-2015), MD1032 (07-20-2015)
 Old 07-18-2015, 09:01 PM   #33
iammike's Avatar
Worthless fucking bump...way to go.
monkey.bones.007 likes this.
Mike
aromig (07-18-2015)
 Old 07-18-2015, 09:28 PM   #34
tapatalk, it sucks
 Old 07-18-2015, 11:40 PM   #35
aromig's Avatar
Posts: 289   (View Stats)
Page generated in 0.54826 seconds with 38 queries
