Closed Thread
 Old 04-08-2011, 06:55 AM   #1
the_caruch's Avatar
Posts: 698   (View Stats)
the_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the worldthe_caruch is the leader of the world
Default SB software limit of 20psi?
So i was going to type in 21 psi this morning into my boost table. And it says invalid value.
Then i realize that the range for my boost target can only be 0-20? Never noticed this before as this is the first time I'm going over 20
Am i an idiot and missing something here?
I'm using the latest 2.6.0.5 software
Sander, can cp-e raise this value?
cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC
the_caruch is offline
 Old 04-08-2011, 07:03 AM   #2
EvilMonkey's Avatar
Posts: 476   (View Stats)
EvilMonkey is the leader of the worldEvilMonkey is the leader of the worldEvilMonkey is the leader of the worldEvilMonkey is the leader of the worldEvilMonkey is the leader of the worldEvilMonkey is the leader of the worldEvilMonkey is the leader of the worldEvilMonkey is the leader of the worldEvilMonkey is the leader of the worldEvilMonkey is the leader of the worldEvilMonkey is the leader of the world
Looks like you are still on the stock snail. 21 psi? If you wanna run hot air go for it.
ZOOM-ZOOM-BOOM-BOOM
EvilMonkey is offline
 Old 04-08-2011, 07:07 AM   #3
the_caruch's Avatar
I know.
It's during my mid-range RPM's 3.8-5k. I run 19psi with low WGDC values so i have room to grow
I would never run 21psi flat out til redline on the K04
 Old 04-08-2011, 09:23 AM   #4
EvilMonkey's Avatar
Surely I would hope not.
PS...I didn't call you Surely. LOL!
ZOOM-ZOOM-BOOM-BOOM
The Following User Says Thank You to EvilMonkey For This Useful Post:
the_caruch (04-08-2011)
 Old 04-08-2011, 12:45 PM   #5
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
~21psi is the limit of the resolution of the stock MAP sensor. The 3.5bar sensor upgrade with the SB allows for more - but thats a whole different calibration within the SB.
Website: www.cp-e.com
www.cp-e.com is offline
 Old 04-08-2011, 05:23 PM   #6
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
actually 22.34 is the limit of the stock sensor. i can post multiple logs showing myself pegging the MAP sensor (before ATR had the ability to re scale one).
you should atleast give your customers that extra 2 psi so they can run 21 or 22 if they would like. not like you dont already have a smorgasbord of other problems to solve........
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
superskaterxes is offline
AZSPEED3 (04-15-2011), the_caruch (04-08-2011)
 Old 04-08-2011, 07:57 PM   #7
the_caruch's Avatar
Does it just get inaccurate past that point? I've seen spikes of 24psi before with stock MAP sensor
Kind of a bummer it's maxed at 20psi.
 Old 04-08-2011, 02:35 PM   #8
MattJackson86's Avatar
Posts: 1,407   (View Stats)
Could you please link to where people can purchase the 3.5bar map sensor (or part #) you guys used with the SB? There are a couple threads on upgraded sensors but I want to be sure that we get the right one if we go that route.
MattJackson86 is offline
 Old 04-08-2011, 03:47 PM   #9
The SB supports the AEM 3.5bar sensor out of the box for now.
 Old 04-08-2011, 09:43 PM   #10
For those that are curious of the AEM PN:
30-2130-50
You can download the voltage chart relative to pressure from AEM. If you're smart and thrifty, you can search for another Bosch or other equivalent sensor that has the same voltage / pressure curve, and save some money. The AEM one is pretty expensive for a basic pressure transducer. I think they were $150.00 last time I checked.
-Sander
 Old 04-09-2011, 03:07 AM   #11
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Cheap part number: 30-2131-50
The number you posted is for the stainless version, this number is for the brass version, everything is the same, less than half the price.
Amazon.com: AEM 30-2131-50 3.5 Bar or 50PSIA Brass Sensor Kit: AutomotiveAmazon.com: AEM 30-2131-50 3.5 Bar or 50PSIA Brass Sensor Kit: Automotive
$57.00 at Amazon
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
SilverDemon is offline
The Following 4 Users Say Thank You to SilverDemon For This Useful Post:
doubleflusher (04-10-2011), MattJackson86 (04-09-2011), pebenito (04-10-2011), sbspeed (04-09-2011)
Closed Thread
Standback Tuning Software, Drivers, and Logging Software www.cp-e.com Custom Performance Engineering (cp-e.com) 24 04-24-2011 11:49 AM
K04 @ 20psi vs 3071R @ 20psi Questions Alpha MazdaSpeed 3/6 - Turbo Induction 109 04-11-2011 02:37 PM
cant hit 20psi !! Kydizzle
Cobb ATR Support
12 01-15-2011 12:11 AM
Gt3076 dyno 20psi 18psiWhiteMS3 MazdaSpeed 3/6 - Dyno Sheets/Discussions 184 08-03-2010 10:15 AM
20psi DH log shucky Mazdaspeed3/6 General Discussion 17 05-19-2008 02:17 PM
Page generated in 0.32795 seconds with 26 queries
