Closed Thread
 Old 07-29-2008, 10:56 PM   #1
708
Erich's Avatar
Posts: 4,274   (View Stats)
Default Second bung on CP-e downpipe
On the cast mouth downpipes, is the second bung (or should I say the first bung, the one that is originally cast) usable with the stock exhaust manifold? Doesn't seem like there is enough clearance to put a sensor in there.
Erich is offline
 Old 07-30-2008, 10:16 AM   #2
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
You've got it right. The cast bung is a provision for a thermocouple if you want to monitor exhaust gas temperatures. You can buy oxygen sensor to EGT probe adapters that you can use with that threaded hole.
www.cp-e.com is offline
 Old 07-30-2008, 02:13 PM   #3
708
Erich's Avatar
So a thermocouple for EGT will fit under the stock manifold? Do I need to be concerned with what gauge I am buying or should the thermocouple that comes with pretty much any EGT gauge fit?
Erich is offline
 Old 07-30-2008, 02:17 PM   #4
The thermocouple is actually just a thin piece of steel (I forget what alloy the K-type thermocouples are) so it's actually very easy to install in terms of space useage. I *believe* all EGT gauges use type K thermocouples, so it shouldn't make any difference really.
 Old 07-30-2008, 10:30 AM   #5
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
wait i'm confused. so they both accommodate O2 sensors - if you want to run EGT you need an adapter?
a lot of people say you should run a heatsink if you're putting in a new wideband - has it been necessary in your experience?
xcoldricex is offline
 Old 07-30-2008, 02:14 PM   #6
Actually only the wideband bung that we weld on the pipe can accommodate a wideband. If you want to run a secondary wideband (i.e. not the factory wideband) then we can add an extra bung for a small fee. The bung that is cast and threaded for a wideband cannot accommodate a wideband because it hits the manifold. You can however buy an adapter that will thread into that oxygen sensor provision so you may install an EGT probe.
We've heard that before too. I think the Bosch sensors are rated for 1400°F, but I don't think they specify for what period of time. Also, any sensors accuracy is going to be highly dependent upon the heater controller attached to the sensor, and I'm not sure if a heat sink would disrupt that feedback loop.
Translation: I'm of no help
Honestly, I'd just run the sensor and see if it eventually fails. If it does they're not a lot of money so they're (relatively) cheap to replace. But if you were really clever, you'd call Bosch (NGK, or whoever) and ask them directly. Sorry I couldn't be of more help!
 Old 07-30-2008, 03:19 PM   #7
ILL3ST
xcoldricex's Avatar
eh? so what's the point of having the second O2 bung if you can't use it because it hits the manifold?!
just to make things clear - I want to run a Innovate LM-1 in the second bung in the cast bellmouth - is this not possible?
 Old 08-09-2008, 08:14 AM   #8
7mileshome's Avatar
Posts: 350   (View Stats)
7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world
subbing
7mileshome is offline
 Old 08-09-2008, 10:29 AM   #9
Threads on EGT TK's are different across many manf's. You could do the standard o2 sensor bung, than get an adapter for your own TK threads... Or, just tap it yourself.
Haltech is offline
 Old 08-09-2008, 10:32 AM   #10
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
yea i just noticed this, it looks like a aftermaket wb MIGHT fit witht the pg manifold, but i was under the impression that it was there for a wideband lol
Laloosh is offline
 Old 08-09-2008, 10:55 AM   #11
I think the PG's are tapped for an aftermarket WB opposed to a EGT. YOu can find the adapters online as long as you know what NPT your EGT is.
Haltech is offline
 Old 08-09-2008, 12:11 PM   #12
ILL3ST
xcoldricex's Avatar
so where's the best place for a second wideband bung if that second one is unusable?
also where's the best place for the EGT? turbo housing? manifold? i didn't think the DP would be a good place...?
 Old 08-09-2008, 03:35 PM   #13
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Innovate reccommends installing the WB O2 at least 18" away from the turbo, but before any flexpipes or couplings that could skew the reading. I have mine installed at the bottom of the DP just past the stock 2nd O2 sensor.
The EGT should be in the runner coming from the leanest cylinder or in the collector of your manifold where it will get an average reading across all the cylinders..
SSinstaller is offline
 Old 08-09-2008, 03:28 PM   #14
kingpin748's Avatar
Posts: 2,611   (View Stats)
Groans: 78
EGT - Turbo Manifold
AFR - Some people put them on the DP others put them on the MP.
In reality I love lenny
kingpin748 is offline
 Old 08-09-2008, 03:54 PM   #15
ILL3ST
xcoldricex's Avatar
alright, i'll just go to an exhaust shop and have one welded in near the stock 2nd. then i won't have to worry about a heat shield either. awesome.
Closed Thread
Stock exhaust manifold bung??? supergoose MazdaSpeed 3 - Engine, Transmission & Driveline 7 06-23-2008 04:56 PM
downpipe babcockxmx Mazdaspeed3/6 General Discussion 38 05-08-2008 07:47 PM
Anyone with a Downpipe speed3 MazdaSpeed 3/6 - Turbo Induction 1 03-30-2008 03:47 PM
Page generated in 0.35327 seconds with 27 queries
