| Custom Performance Engineering (cp-e.com) cp-e™ has been a front runner in pushing the L3-VDT engine since its inception; offering a solution for all your needs. Our motto is serious performance from serious engineering. Everything we do is a sentiment to this motto; from rigorous R&D, designing everything in a 3D software environment, to providing you with a Made in the U.S.A product paired with a lifetime warranty. cp-e™ tries to give you the best product available on the market through constantly engineering new products and re-engineering old products. We continue to push the L3-VDT, and are proud to say that 52% of our whole product line-up is for Mazda vehicles! When you are serious about performance, contact the company that is serious about engineering! www.cp-e.com |
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
(Thread Starter) | Not Ranked : 0 score Here are two screen shots from the SB logs. One with our Full Control Flash (throttle) one with out. With out FC flash: (Note, not that it needs to be said, however, yes I was pressing the gas pedal all the way down) ![]() It's interesting to note that the throttle isn't even all the way open at its peak voltage. It's only about 3.6V at peak, which assuming 4.5V is 90%, is only open a peak of 70% for a portion of time. With FC flash: ![]() There is a brief interruption of throttle at the beginning of the pull, however if you look at the scale of the graph this holds 90-100% the entire way. I know the FC has been around for a bit, however its nice sometimes to see a graphical representation of what you're paying for! Here are the dyno comparisons between the two. ![]() If you see the peak value of 268 (Wheel corrected on our MD-500), directly below that is the dotted red line at 220 (without the FC flash). That's a solid 48 HP at that RPM point. Just cool info, IMO. -Sander
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe Last edited by www.cp-e.com; 12-21-2010 at 06:58 PM. |
| The Following 7 Users Say Thank You to www.cp-e.com For This Useful Post: | Dano (02-01-2011), djuosnteisn (12-21-2010), MPSdriver (12-23-2010), Poohster (12-24-2010), SilverDemon (12-21-2010), the_caruch (12-21-2010), _Toxic_ (02-01-2011) |
| Not Ranked : 0 score what were the mods/car on that dyno?
| The Following User Says Thank You to superskaterxes For This Useful Post: | FreeFlyFreak (12-21-2010) |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score I have always been curious of CPE's thoughts on this Cobb document stating holding full throttle duty cycles all the way to read line does not increase power output...thoughts CPE? |
| The Following 3 Users Say Thank You to TRex For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score That is a very detailed and comprehensive analysis of the theory and objective of DBW, however, it is somewhat of an apples to oranges comparison of stock vs. flashed throttle mapping. They are making evaluations that are interesting however, not completely applicable to our discussion here. COBB is saying that the power gain is negligible between 50% and "100%" (which to note, on their relative throttle graph is only approximately 75%) throttle. I am displaying the power difference which is definitely quantifiable between stock throttle mapping (which is as low as 40-44% at 6200 rpm) and our Full Control flash (which is approximately 90-95% at that same data point). Our comparison is over a dynamic change, not a static comparison between two values. Also to note, this is the same car, on the same day, on the same dyno. I am not attempting to dis-credit COBB's research, however, on our dyno the differences were fairly remarkable.
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe |
| The Following 3 Users Say Thank You to www.cp-e.com For This Useful Post: |
| Not Ranked : 0 score In your post you said we are assuming 4.5V means 100% plate opening...how did you arrive to this? Also aren't you comparing apples to oranges as well by showing a car with the stock throttle limit and then again with out the restriction? Did you not introduce a different throttle map? Back to the cobb document, it is believed that if we can open the throttle plate more we can make more power correct? They showed that there is no difference between 50% TPP and 75% TPP (which is the recognized stock max)...But they did take the 75% all the way to redline...that doesn't happen on the stock map...why would we believe that their is a difference between 75% and 100% when it was shown already at one point that opening wider and staying open all the way didn't yield any results? Also a question regarding safety. It is my understanding (and please correct me if I am wrong) that the FC flash is merely to force the TP open to 100% when APP is at 100%? No other changes made to ECU logic (fuel, spark, ect...). Am I correct in this? If that is the case how can I be sure that the stock fuel/spark tables can compensate for this increase air flow at the top end? I'm assuming that it was programmed to see no higher than 75% but when all of the sudden we are forcing it open 100% how do I know the turbo isn't over running itself (which imo is one of the reasons for the stock map throttle plate close off) or my fuel trims can compensate and not cause a lean condition. I am speaking merely of a stock turbo car...I do see the benefit of running the TP wide open on a BT car as BT's can handle the increased air flow (along with compensating fuel and spark). The little K04 is almost maxed out as it is, I see the throttle plate closing down as a safety net. Could you post more data on these particular runs? Stock turbo? mods? AFRs? and the like? Also also, can you comment on if on the stock map under every case when you go WOT you see 75% TPP? Or does it change...i.e. the ECU picks the best TPP position based on load conditions for optimal air flow? Where you will see TPP at 65% one day and 75% another day ect. (Note I am talking before throttle plate close down at red line) (Please don't take any of this as attacks or trying to disprove you or anything, I am trying to educate myself about how all of this works) Last edited by TRex; 12-21-2010 at 12:58 PM. |
| The Following User Says Thank You to TRex For This Useful Post: | www.cp-e.com (12-21-2010) |
| Not Ranked : 0 score There is a definite difference between the stock throttle mapping and completely open throttle mapping.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | xcoldricex (12-21-2010) |
![]() Join Date: Jul 2009 Location: Keene, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
Groaned at 68 Times in 44 Posts
| Not Ranked : 0 score The fact that you use a Mac to tune does absolutely nothing to further your cause.
__________________ 08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's 253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune 97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup 89 Kawasaki 650SX Stand-Up Jetski |
| Not Ranked : 0 score If both tunes were trying to maintain a given boost pressure in the intake manifold, one could argue that an open throttle could potentially help a smaller turbo more than a big turbo. A semi-closed throttle plate will create a pressure drop, much like a shitty intercooler. And in order to achieve a given boost in the IM, the turbo will need to output that much more to compensate for the throttle plate drop. A big turbo will have no real issue with this, as a couple psi more is no big deal and doesn't budge the operating point too far from high efficiency islands on the compressor map. But a small turbo (which is already no the ragged limits) needs to spin much much much faster to make up those few psi. Aside from much hotter charged air, it also results in much higher exh mani pressures, and decreases the VE of the motor. This is why you can actually make less power by running too much boost on a small turbo. ...so not sure if OP was using SB to tune before and after the flashes, but if it was, and targeting the same boost pressure on both maps... that may explain the difference in results between cobb and cp-e. *one more thing... Cobb's study was done with an otherwise stock car, and an otherwise stock tune. We know the mazda ecu targets a given load, rather than boost. So if it was meeting the target already with a partially closed throttle plate, why would one expect to see gains even with a fully open plate. I haven't read that document in quite a while (and don't have time right now), but does cobb show boost curves with both throttle setups? If not, I would venture to guess that the high throttle tune resulted in lower boost, in order to maintain the target load. Much like how MAP performance resulted the same hp with a ported intake manifold, but at 2 psi less boost, on before and after dyno runs.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com Last edited by djuosnteisn; 12-21-2010 at 01:33 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 8 Users Say Thank You to djuosnteisn For This Useful Post: | Alpha (12-21-2010), Crarrs (01-28-2011), FreeFlyFreak (12-21-2010), MPSdriver (12-23-2010), SilverDemon (12-21-2010), TRex (12-21-2010), wankular (12-21-2010), www.cp-e.com (12-21-2010) |
| Not Ranked : 0 score ^thanks for the explanation that puts a lot into view... so in my own words... If I am targeting X boost in my map, by letting the throttle plate open wider I am helping my turbo achieve that X boost more efficiently which results in more HP....did I get that right? But, in the Cobb document because they were more than likely using load targeting and not boost targeting, they were not gaining any HP due to the fact that they were already at the target and no increase of air flow was needed. So is it fair to say that if you are doing load based tuning...the FC flash or any throttle mapping beyond 75% may or may not be necessary or produce results? The Cobb document does not log any boost levels... |
| The Following User Says Thank You to TRex For This Useful Post: | djuosnteisn (12-21-2010) |
Yeah, but most people who run the flashes are tuning with the SB, which is a boost targeting system. And the flashes are incompatible with the AP, so i don't think anyone would be mixing and matching the tuning methods.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | ||
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | TRex (12-21-2010), www.cp-e.com (01-04-2011) |
| Not Ranked : 0 score Great, I understand now...was just a little confusing when I was looking at to sets of data without knowing the difference in parameters between them |
(Thread Starter) | Not Ranked : 0 score I'm sorry, Ive been busy on the dyno today. I will comment on your questions when I get back home. djuosteisn covered most of it though, I probably should have been a little more clear from the get go on a few items. Thanks, -s
| Not Ranked : 0 score Were you tuning with the SB before and after the flash suite? Also, did you guys include the secret sauce in that throttle flash? Cause i know lou will usually include it in most flashes now a days. Lastly, what were the tune differences between the two dyno pulls, if any (was it same boost, same AFR, same timing etc... with only the throttle opened up)? Thanks for posting up some dyno info and quantitative results as well. Your lucky to have a dyno to play around on all day lol. I just get to play with soldering irons and a keyboard.... hahaha.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | www.cp-e.com (12-21-2010) |
(Thread Starter) | Not Ranked : 0 score So, to start with, I'm going to try and answer the questions you guys have. But if I seem to miss any, please ask again, I won't be offended by any means. - As far as the mods on the car, it is a mostly stock Gen 2. Exhaust, Top Mount Intercooler, Stock turbo / manifold, Intake and an SB (with flashes and with out). HKS SSQ, recirculated. We have 93 Octane in MD, and this is what is in the car. - I derived 100% from 4.5 from the general theory of automotive 5 volt potentiometers. Most cars use a voltage range from 0.5 - 4.5 as a representative voltage range, with the remaining 0-0.5 range and 4.6-5v used for diagnostic reasons of detecting a sensor fault. I must admit, that I was slightly incorrect in this assumption. See below: ![]() (Source, Alldatapro.com) This is a test parameter, indicating when the APP is completely pressed down that the TP1 should be 4.7-4.9V. Automotive TPS sensors are generally always 5V references, so it can not possibly read above 5V. The TP1 voltage value of 4.7-4.9V is safe to assume at 100% throttle, maybe not my previous assumption of 4.5V (which is based on most of my previous experience of Bosch PFI systems). But even if 4.7-4.9V is assumed as 100%, 4.5% would be approximately 90%. - I should state that my only purpose in making this thread was to show the throttle plots, because I just think that kind of stuff is nice to see in a qualitative graph format, I wasn't even going to post the dyno chart in fear of this happening, however, I'm glad that we're being open to discussion regarding this. Here are the data points on the graph. They are somewhat different in the timing curves but not enough to warrant the discrepancies in power. I had to be fairly conservative with these to accommodate for possible lower octanes. And, these are just intended to be base maps, nothing really earth shattering. djuosnteisn covered the load table "lookup" discrepancy between the AP and SB in a very logical way, and I appreciate that! With flashes: ![]() With out flashes: ![]() Dyno with AFR: ![]() There are slight differences between these, but the boost, timing, AFR, and RPM are within reasonable similarities to show the main difference being the throttle opening. I hope that answers some of your questions. Thanks. -Sander djuosteisn, I sure do like having a dyno to play with, it really lends to determining what does what, and helps you figure out why!
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe Last edited by www.cp-e.com; 12-21-2010 at 07:03 PM. |
| The Following 5 Users Say Thank You to www.cp-e.com For This Useful Post: | djuosnteisn (12-21-2010), MPSdriver (12-23-2010), qtrmile beast (01-28-2011), the_caruch (01-28-2011), TRex (12-21-2010) |
![]() Join Date: Jul 2008 Location: Canton, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,233
Does the standback itself still tune based on load? or boost? Reason I'm asking is that i always see these AP logs people post with the absolute load WAY above what I'm running with my current tune and setup. (mods in sig, K04@18psi) Here is a graph of what my logs looks like for rpm and abs load. Would getting the cp-e flash eliminate the ECU doing a load table lookup? Does Lou put his "secret sauce" in each cp-e flash? The dark blue numbers on the graph are hard to read but i spike at 210% and then within 1 second i drop down 50% load and continue to drop until i shift.
__________________ cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC Last edited by the_caruch; 01-28-2011 at 01:51 PM. | |
Much simpler way to evaluate 2D tables. The load capping that the ECU does is based off of calculated load and a time interval. Our flash alters the time and load interval.
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe | |
| The Following User Says Thank You to www.cp-e.com For This Useful Post: | the_caruch (01-28-2011) |
If i understand correctly the Mazda ECU, even with the SB, will target the stock load values. And that you must get the flash to have that adjusted like you said(along with the other improvements). Gotta get that flash!
__________________ cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC | |
| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2120 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
| Not Ranked : 0 score or an AP for a lot less $$$ and have way more flexibility ....
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy |
![]() | | #19 | ![]() |
| Not Ranked : 0 score Not to restate the obvious but the flash just completely (or makes really really high) the load cap? |
![]() | | #20 | ![]() |
The Flash can make the load cap higher, and it can also lengthen the period of time before the load threshold is triggered to cut the fuel.
![]() | | #21 | ![]() |
![]() Thanks for the info!!
![]() | | #22 | ![]() |
| Not Ranked : 0 score The SB completely takes over control of the boost control solenoid, and such it controls the boost entirely. It's similar to a standalone in that regard. But i have seen logs on cars running a SB without the flashes, and the ECU still attempts to limit the load by closing the throttle as it does in stock form as well, even though your trying to force the load by running more boost. This is the main reason cp-e introduced the full control flash, to make the throttle stay completely open while the pedal was matted. It works wonderfully, and removes a giant restriction (partially closed throttle) from the intake path. AP has this same ability... 2 ways to kill the same cat. IMO, evey SB should be complemented with a full control flash to take full advantage of what it has to offer. Or the SB should be modified to directly control the throttle in a similar fashion that it drives the BCS.
| The Following 5 Users Say Thank You to djuosnteisn For This Useful Post: | FORZDA 1 (01-31-2011), ljudgeii (01-31-2011), MPSdriver (02-01-2011), pebenito (02-01-2011), the_caruch (01-31-2011) |
![]() | | #23 | ![]() |
![]() Join Date: Nov 2008 Location: Europe
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,476
| Not Ranked : 0 score which will be achieved once the TC3 unit comes to the market? |
| The Following User Says Thank You to MPSdriver For This Useful Post: | djuosnteisn (02-01-2011) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score TC3 will be a complete standalone... controlling everything from fueling, to the spark event, to throttle interpretation, to knock sensor interpretation etc etc etc. IMO it'll end up running in conjunction with the oem ecu, and just feed the ecu dummy signals to keep it happy and make it think it's constantly idling (or something to this effect). That way the ECU can still manage all the can activity with other modules on the car, and you don't lose the form, fit and function of a nice modern vehicle. It'll also allow the ECU to respond to OBDII queries and stuff, to help with passing emissions. OBDII emissions tester - "do you have any CEL's?" OEM ECU - "oh, no no no... i've just been idling for 10k miles." With the right setup, the skies the limit on the tc3. It basically gives the designer complete control to accommodate any fancy dancy race car ideas he can come up with. Not sure when it's slated for release, but i've heard good things on the progress...
![]() | | #25 | ![]() |
| Not Ranked : 0 score not trying to start an AP vs SB/Flash shootout here just wanting to clear up terms/ learn something. Didnt know it you guys covered this but. All this throttle closing can also be eliminated w the AP DBW tbls. That is to say you can run~76-77 TPS. Vs 68ish or less on stock or Cobb OTS mapping Does the FC flash give you more TPS than 76ish? Just think perhaps saying 100% open may be the same as 77TPS Yes? No?
| The Following User Says Thank You to Dano For This Useful Post: | djuosnteisn (02-01-2011) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score It definitely does. Both solutions have abs control over the throttle.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | Dano (02-01-2011) |
![]() | | #27 | ![]() |
![]() Join Date: Jun 2008 Location: Harrison, AR Heart of the Ozarks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,768
| Not Ranked : 0 score Stupid noob question.... What are the differences (results) in the various SB display chart choices - rpm vs tps or rpm vs map/maf, etc? Type slowly and use small, simple words please.
__________________ "I only do what the voices in my wife’s head tell her to tell me to do" |
![]() | | #28 | ![]() |
The SB provides you this choice.
![]() | | #29 | ![]() |
| Not Ranked : 0 score Some input selections are more appropriate for certain tables, as opposed to others. For instance... for the boost target table, you wouldn't want to use MAF or MAP signals.... cause those depend on boost. It's best to use TPS (throttle) as the input. For fueling (MAF table), it's more effective to use an input that is more directly related to the loading of the car, like MAP or MAF voltage. If you were to use TPS, theoretically you could hit that same TPS vs RPM point in the MAF table at various boost levels, and it'd make for a somewhat erratic and inconsistent fueling map. For fuel pressure, again, it's smarter to use a load based input like MAP or MAF. So that your only increasing fuel pressure when the car is in boost and high airflow. And lastly, for spark timing, it would be best to use MAP or MAF (MAF probably being the best) vs RPM, for the same reasons above. That way your tweaks are consistent with what the ECU's base logic is doing.
| The Following 6 Users Say Thank You to djuosnteisn For This Useful Post: | CosmicArkie (02-02-2011), MattJackson86 (02-03-2011), MPSdriver (02-05-2011), pebenito (02-02-2011), the_caruch (02-01-2011), www.cp-e.com (02-01-2011) |
![]() | | #30 | ![]() |
However I thought it would be interesting to point out an exception to this rule (NOTE: This does not apply to ANY turbocharged car, unless you can do 4 dimensional mapping like some of the Motec ECU's can do). On naturally aspirated engines with large camshafts or individual throttle bodies, the engines do not develop much vacuum. If the engine does not develop vacuum, there will not be much of a variance of a MAP sensor (assuming speed density load referencing), therefore not being much good as a load axis. This is a good example of an application where TPS as a load axis is a good idea. This is also called "Alpha-N" mapping. /end of random rant. -Sander
| The Following 4 Users Say Thank You to www.cp-e.com For This Useful Post: |
![]() | | #31 | ![]() |
and it worked great. Near instant throttle response. (ps... why does the boobies emoticon look she has a mustache??)/end of enjoying Sander's random rant.
![]() | | #32 | ![]() |
| Not Ranked : 0 score Thanks you guys for the good info. After several days of mulling it all over in my little pea brain its starting to make perfect sense. Now the question is, how much difference does the rpm vs tps and the rpm vs map/maf actually make? Last spring while playing with my SB I left all the displays at the default rpm vs tps because I didn't have a clue. I tweaked fueling to get closer to stoic and backed out a little timing to clear up a couple of consistent spikes of KR. If I change the displays to rpm vs map for the fuel and timing, should I start over with a clean slate or log and see what it looks like? I never played with the pressure because there never was an issue there. Thanks again for your patience. Jim
![]() | | #33 | ![]() |
| The Following 2 Users Say Thank You to www.cp-e.com For This Useful Post: | CosmicArkie (02-04-2011), the_caruch (02-05-2011) |
![]() | | #34 | ![]() |
Look at my attachment i had a few posts ago. You should run it like that. That's what Jake set mine at when he was helping me.
| The Following User Says Thank You to the_caruch For This Useful Post: | CosmicArkie (02-05-2011) |
| Airbag light flashes | treyclash | 2010 MS3 - Car Audio & Electronics | 1 | 12-17-2010 10:58 AM |
| cp-e flashes | 2fst_4u | MazdaSpeed 3/6 - ECU Computer Tuning | 35 | 04-22-2010 09:01 AM |
| SB flashes review | cageyvet | MazdaSpeed 3/6 - Turbo Induction | 8 | 04-02-2010 05:26 PM |
| Spy Shots: MINI Crossman flashes its rump | Haltech | Automotive News | 0 | 04-02-2008 07:40 AM |
